Which Business Function should Approve Suppliers and maintain the ASL
fialor
Hi All,
I am currently having a debate internally on which function in the business should approve suppliers and maintain the ASL (approved supplier list).
Has anyone come accross this operational question and what has worked for you?
Fialor
Marc
Fully vaccinated are you?
It depends on the company size and how it is structured. Typically if the company has a purchasing department, it is responsible for approving suppliers and maintaining the approved supplier list. The QA department may or may not have an input. For example, if the company needs envelopes for invoicing, QA typically will not be involved.
How does your company do it currently?
shimonv
From my experience - supplier controls is usually done by either QA or the Operations group. It usually starts with the QA group who, obviously, has a better idea what the regulator wants to see. Later on it might shift to the Operations group who, obviously, have a lot more resources. And in large organizations, due to complexity, it goes back to QA.
That's the lifecycle of supplier controls as I know it. :)
Cheers,
Shimon
Marc
Here is an example of where that typically fails: A department needs toner cartridges for printers. For toner cartridges there is no reason to tie up people in QA to come up with specifications, etc. Yes, you can but is it a wise use of resources?
The idea of a purchasing department is controls and coordination to ensure the appropriate inputs are gathered. If any department needs something, whether it be manufacturing, the design group, personnel, etc., they come up with their requirements (e.g.: HP toner cartridge A1154 or T6061 aluminum rods, 3/8" or 12" mailing envelopes). Those requirements are passed on to purchasing. In the case of T6061 aluminum rods, 3/8" QA will probably have an input to purchasing.
You can, of course, put QA in charge, but burdening them with approving paper clip suppliers is somewhat useless.
Some existing discussions:
Responsibility and Authority in a QMS - Approval of Supplier Accreditation
ISO 9001 Clause 7.4.1 Purchasing Process (Supplier Approval)
Vendor (Supplier) Approval Procedure - Scope of the procedure
Some Supplier Approval specific Discussions
1010011010
In my opinion, Purchasing should always have the general responsibility for their supply chain.
However, the approval decision, should always be joint decision of Purchasing and Quality, as both look at different aspects
  • Purchasing --> Commercial Topics
    • is the suppliers business commercially stable enough for a long term relationship?
    • is the pricing attractive?
    • is lead-time acceptable?
  • Quality --> Technical Topics
    • is the supplier capable of producing a part?
    • does the supplier have a quality management system?
E.g. the best, technologically capable supplier won't be any good, if they are about to be shut down because of mismanagement, over-indebtedness, ...
Also, as Marc has already pointed out, not everything should go through Quality. So a reasonable differentiation between Production and Non-Production Material should be made.
normzone
It's been my experience that:
Purchasing wants to buy from suppliers that deliver to spec and on time at competitive pricing
Engineering wants to be able to get prototypes from the fastest provider regardless of performance or price
Everybody wants it to be Quality's responsibility when something goes amiss
I try to let all parties use who they want and be available to assess as requested and to counsel suppliers when they need it. I just ask that they let me take a look at potential suppliers before big commitments are made.
Ronen E
Problem Solver
Moderator
My opinion, in a nutshell:
Purchasing should be responsible for the final approval of suppliers and the maintenance of the approved suppliers list, but they must follow unambiguous (and detailed enough) procedures that dictate who they have to consult before approving a new supplier / deciding to extend engagement / deciding to strike out a previously approved supplier.
Where there is no formally appointed "Purchasing" function it should default to the Operations function.
myusoffice
First Time Right...
As mentioned in some of the comments, it all depends on how your organization is structured. If your organization has sufficient departments, i.e Quality, Supplier Quality, Purchasing, Supplier Account Management, Operation, Procurement Engineering then some of the world-class organization use following workflow:
Request to Add New Supplier in ASL:
- Anyone from the organization
Initial Approval :
- Supplier Account Manager /Commodity Manager and/or Purchasing Manager (Also responsible to make sure purchasing, sustainability, or other agreements are in place)
Supplier Assesment, Qualification and Final Approval:
- Supplier Quality / Quality (Also responsible to make sure quality agreement is in place)
Adding to / Maintaining the ASL:
- Supplier Quality / Quality (Ultimately responsible to make sure all supplier in ASL are compliant to all internal and external requirements. Performs periodic audit and supplier development activity.
You can follow the same logic to remove a supplier from the ASL
Regards
Ziaur
V Annual Performance Appraisal - Person vs. Function/Business Career and Occupation Discussions 5
S How do you Prepare your Business Plan for year 2008 - Focusing on QUALITY Function World News 3
R Starting an automotive containment business Service Industry Specific Topics 3
H Mapping QMS+business processes in a medical device with class I and IIa+b Process Maps, Process Mapping and Turtle Diagrams 3
Sidney Vianna A young Steve Jobs take on Quality, Marketing & Business Processes. Coffee Break and Water Cooler Discussions 0
A How to monitor new versions of external standards in your business Various Other Specifications, Standards, and related Requirements 2
M ISO 13485 Clause 7.3.8 ---- on Business Transfer ISO 13485:2016 - Medical Device Quality Management Systems 2
L Did anyone hear business registration ontario? General Information Resources 1
I Foreign manufacturer registered place of business in EU for CE certification EU Medical Device Regulations 1
M How to manage Sop's & other quality documents after business transfer Document Control Systems, Procedures, Forms and Templates 3
D QMS Realignment after business splits into 2 different companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E Business Continuity Plan Exercise for Outsourced Services Business Continuity & Resiliency Planning (BCRP) 7
G Microsoft Office 365 Business plan questions Business Continuity & Resiliency Planning (BCRP) 10
S Business Number versus Company ID? Canada Medical Device Regulations 3
K Business Process Flowchart Process Maps, Process Mapping and Turtle Diagrams 2
Sidney Vianna Informational ESG - Environment, Social & Governance issues gaining ground in the Business World Sustainability, Green Initiatives and Ecology 22
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E BCP (Business Continuity Plan) Call Tree Business Continuity & Resiliency Planning (BCRP) 14
H Expanding our business and the implications to our QMS Manufacturing and Related Processes 2
Richard Regalado Top 10 operational risks of 2019 for business continuity planning Business Continuity & Resiliency Planning (BCRP) 6
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Nicole Desouza ISO / AS Certification - Small business with less than 100 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Supplier evaluation and business needs in the context of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 2
M Informational Australia – TGA business plan 2019-20 Medical Device and FDA Regulations and Standards News 0
M SOP Sample for BC/ISO22301 (Business Continuity) wanted Business Continuity & Resiliency Planning (BCRP) 4
M BCM (Business Continuity) and BPM in a company with an IT System Business Continuity & Resiliency Planning (BCRP) 0
A Brazil: Termination of business relations with BRH – what happens to registrations? Other Medical Device Regulations World-Wide 1
Jen Kirley Conway Business Services LLC - Jen Kirley ISO 14001:2015 Specific Discussions 0
J Business Intelligence and 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 1
G Anyone working with or planning to do business in the CBD (cannabidiol) industry? US Food and Drug Administration (FDA) 1
M Supplier Management outsourcing - Business idea Supplier Quality Assurance and other Supplier Issues 8
T AS9100 Maintain Approval When Business Ownership Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
WCHorn US Citizen Traveling to Mumbai for Business Travel - Hotels, Motels, Planes and Trains 4
S New to the automotive business and VDA VDA Standards - Germany's Automotive Standards 5
R Process Mapping for a BPMS (Business Process Management System) vs ISO Process Maps, Process Mapping and Turtle Diagrams 1
F BREXIT - What/How are You and Your Business Preparing for It? EU Medical Device Regulations 20
P Suggestion for QMS platform solution + Business process automation Software Quality Assurance 3
A Should we do business in the automotive sector? IATF 16949 - Automotive Quality Systems Standard 7
F Business expanding - Campus vs Multi Site Certification Structure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P Definition Business Type - Definition of what we do-Business Type Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
A What does a good business practice Process Audit look like for AS9100D? Process Audits and Layered Process Audits 9
S Internal Audits performed by another local business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
R Business Benefits from IATF 16949 QMS IATF 16949 - Automotive Quality Systems Standard 4
S Business development and support - Getting business general liability insurance Career and Occupation Discussions 5
J Business Impact Analysis SOP Business Continuity & Resiliency Planning (BCRP) 2
B Seeking for an example or a template of a Business Plan Service Industry Specific Topics 3
Q Is ISO 9001 fully enough to manage a business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
supadrai d/b/a doing business as and the FDA US Food and Drug Administration (FDA) 1
