Which class I accessory information should be kept in the Technical File
shimonv
Hi fellows,
Say you have a class I make item accessory with its own design input/output files. Will you include the detailed accessories information (requirements, V&V, labeling, etc.) in the technical file or just a brief description in the Technical Files and complete details in a separate DHF record?
I believe the second option is correct, but would appreciate hearing what is your experience with NBs.
Thanks,
Shimon
rob73
looking for answers
We have a separate DHF for accessories, with a document in the main product DFH listing accessories that can be used with the main product and the location of the DHF for that accessory.
shimonv
Thanks Rob, good input.
So following this line of thought - do you have two technical files, one for the device with a brief description of the accessories and one for the accessories?
Thanks,
Shimon
rob73
looking for answers
Shimon
Yes, as Ronen points out each devices has to have its own DHF, even accessories. That's not to say you cannot group them if their intended use and design are the same. For instance we manufacture a range of disposables. They vary in size and port configuration but are basically the same device. These are grouped as a product family, the DHF for these references the accessories and their DHF.
shimonv
Thanks Rob and Ronen,
I am adding input from another colleague of mind which should wrap it up:
"If the accessory has its own CE Mark based on its own intended use, then it would have its own technical file since it's a class 1 self-declare.
If the accessory is part of the medical device system/family that is being CE Marked and dependent on the bigger system's intended use, then I would include the information in the bigger technical file."
Best,
Shimon
Ronen E
Problem Solver
Moderator
In that case it might be an accessory in the everyday English meaning but it wouldn't qualify as an Accessory as defined by the MDD.
I was assuming all along we are discussing an Accessory in the MDD meaning.
D Software as an accessory to a Class I medical device EU Medical Device Regulations 4
I Class I Medical Device Accessory with Actual Risk EU Medical Device Regulations 7
Q South Africa Class I Medical Device Accessory Registration Other Medical Device Regulations World-Wide 1
C Compatibility of a Class II exempted accessory with a Class III device US Food and Drug Administration (FDA) 1
D Class I and Class II Medical Device Accessory Design Control Requirements US Food and Drug Administration (FDA) 3
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 3
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
D Electrical Medical Devices class I EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
L Class IIb devices marked EC according to the 93/42/CE - Portugal CE Marking (Conformité Européene) / CB Scheme 3
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
G Voluntary Class I Device Filing Other US Medical Device Regulations 4
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
D Can a diagnostic device be class I? EU Medical Device Regulations 1
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S IVD risk class II devices for Brazil and MDSAP Other Medical Device Regulations World-Wide 0
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L Radiology software Class I exemption Medical Device and FDA Regulations and Standards News 3
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
Z Class I marketing regulation and supply chain Other Medical Device Regulations World-Wide 0
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
S How is the service life for class I reusable medical devices described in MDR? EU Medical Device Regulations 7
S How is the service life described for class I reusable medical devices in MDR? Elsmar Xenforo Forum Software Instructions and Help 1
R Class 1 Convenience kits for home teeth impression, NOT smile direct or other for alignment purposes Canada Medical Device Regulations 0
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Intervertebral body fusion cage, MDR Class II or Class III? EU Medical Device Regulations 4
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
R Nanomaterials used as coating on class I MD - rule 19 EU Medical Device Regulations 4
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
D Class IIB Medical Device Accessories - OTS Tablets Other Medical Device Regulations World-Wide 1
K Doubt on insulation class of a device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
A First CE-mark class III implantable device under MDD EU Medical Device Regulations 8
