Re: Which control chart for incoming inspection
I'm not sure you can do what you would like, by running a control chart at Receiving. Somewhat along the lines that Bob says, would your supplier give you a copy of their process control charts, instead?
I struggled with the same kind of issues at Receiving and, frankly, without knowing the supplier's process capability, it's a bit of a gamble setting any sample, plotting the results and trying to detect any oot parts. I'm not convinced of the value. If it's a propriety component design (is it your spec or the suppliers?) you could ask them for their results for a specific parameter which is critical to you. I certainly don't see anywhay to detect any out of tolerance items this way, but you might see a long term drift from a large amount of sampling.
