Which 'customer' in 8.2.4 Monitoring and Measurement of Product?
Q
qualitymanager
This one is for the experts:
The middle paragraph in clause 8.2.4 Monitoring and Measurement of Product reads "Records shall indicate the person(s) authorizing release of product for delivery to the customer".
Since the ISO/TC176 Interpretations stopped in Aug 2006 (http://www.tc176.org/Interpre.asp), I turn to you guys to give me your interpretations - does this usage of "customer" mean one external to the QMS, or does it cover the range given in the ISO 9000:2005 (particularly wrt Internal Customers)?
Thanks in advance.
Sidney Vianna
Post Responsibly
Obviously the intent of word customer is to refer to an "external" customer.
While ISO 9000:2005 does mention "internal customers", as I have addressed in another recent exchange, a valid example of an internal customer is a Ford engine assembly plant shipping products to a Ford car assembly plant.
The idea of one department (or process, or assembly line) being an internal customer to another department has never been the intent of ISO 9001. Departments have processes, not systems. Organizations have systems.
And don't forget:
Q
qualitymanager
Thanks for the quick reply Sidney (blessings to you & the other night owls out there :D).
The question is in the abstract, but I can see a situation where there may be difficulty in applying your answer above:
I'm working with a company which has Section W going for API Q1 certification, and Section D is outside of the QMS. External customer P requires all work of a specified type done for Section D be carried out by a Q1-certified supplier. Section D (not required to have Q1-certification) directly provides services to External customer P.
None of the output provided by Section W is usable by the external customer. 90% of the output from Section W goes to Section D; the remaining 10% is for external customers other than P, none of whom currently require Q1-certification from Section W.
As such, we have defined the customers of Section W along the 90/10 split. However, as both Sections W and D are within the same legal entity, Section D is considered an Internal Customer to Section W (the basis for this stems from ISO/IEC 17025 in one of the early clauses where it speaks about labs being a legal entity or part of a legal entity).
Further comments are appreciated.
Stijloor
Thanks in advance.
Look at 3.3.5 in ISO 9000:2005.
Stijloor.
Q
qualitymanager
Thanks for the reply. I'll check it tomorrow (I don't have a copy any more :( ) and hopefully sort it out to my satisfaction.
JaneB
Stijloor.
Indeed yes. Qualitymanager, this is clear from the fact that the document Stijloor refers you to is quoted as a Normative Reference in the Standard itself.
Any questions about the definition of a particular term should start with the definition given in ISO 9000!!
M TS 16949 Clause 8.2.4 Monitoring and Measurement of Product - Customer Scope? IATF 16949 - Automotive Quality Systems Standard 3
G Problem Resolution Report Monitoring - Customer complaint or PRR as general motors use Customer Complaints 12
T Supplier monitoring - The meaning of "8.4.2.4 " Customer disruptions IATF 16949 - Automotive Quality Systems Standard 1
I Monitoring Supplier Performance when our Supplier is also our Customer Supplier Quality Assurance and other Supplier Issues 8
M 8.2.1 ?NOTE- Is Monitoring of Internal Customer Satisfaction a requirement? IATF 16949 - Automotive Quality Systems Standard 1
Sidney Vianna ISO 10004:2012 - Customer satisfaction - Guidelines for monitoring and measuring Other ISO and International Standards and European Regulations 18
D 8.2.1 Monitoring & Measuring customer satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Monitoring the monitoring process - Customer complaint process isn't being monitored IATF 16949 - Automotive Quality Systems Standard 7
P Obtaining information from Customers for Monitoring Customer Satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
G Special Status Customer Notifications - Supplier Monitoring - ISO 16949 Par. 7.4.3.2 IATF 16949 - Automotive Quality Systems Standard 5
D Customer Specific Requirements - Does anyone use a web crawler for monitoring these? Customer and Company Specific Requirements 5
Sidney Vianna All the TC 176 documents - ISO 10020 - Customer Satisfaction Monitoring and Measuring ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Sharing best practices in customer satisfaction monitoring process Customer and Company Specific Requirements 17
S SPC monitoring software - Our customer recommended MINITAB (we use Excel) Quality Assurance and Compliance Software Tools and Solutions 3
W Supplier monitoring / Customer satisfaction - Different performance indicators IATF 16949 - Automotive Quality Systems Standard 7
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
