Which documents must be updated upon product validation?
Since all my QMS experience is working with startups that had not yet gotten to the point of releasing a product for Manufacturing, I’m unsure about what happens after the product is validated.
Imagine the QMS is structured with revision numbers using Alphabetical identifiers for pre-validation engineering documents, i.e. Rev A, B or C. Then, after product validation, the engineering documents are supposed to move to a numerical revision, i.e. Rev 0, then 1.
When the product achieves validation, and you have several dozen or hundred engineering documents that are in Alpha versions, are you supposed to update them all to “Rev 0” with no actual changes, just to show the product was validated? That would be a great deal of time and work.
And if this is what is supposed to happen, then which engineering documents are updated?
  • Only the parts and procedures listed in the BOMs, or
  • All the documents in the DMR, or
  • All the documents in the DMF?
Thank you for your assistance.
Scott
Randy
There are no rules so do what you want when you want, make sure it's understood by people that really need to know (which isn't the entire world), make sure everything lines up, and be consistent in the process...In the end it isn't anyone else's business how or when and there's no right or wrong.
F Electronic Signatures (21CFR Part 11) - Must They Appear on Printed Documents Document Control Systems, Procedures, Forms and Templates 9
S Integrating a Multi-Management System - What documents & records must we have? Various Other Specifications, Standards, and related Requirements 6
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
F Must the AS9100C quality manual contain the procedures and QMS documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C How do you know what documents must be under control? Document Control Systems, Procedures, Forms and Templates 13
D Controlled Documents - ISO 9001 4.2.3 - What documents must be controlled? Document Control Systems, Procedures, Forms and Templates 9
N PPAP Third Edition Documents - Can we make our own forms or must we buy them? Document Control Systems, Procedures, Forms and Templates 10
L Must All Documents be on a Document Matrix including Each Job Description? Document Control Systems, Procedures, Forms and Templates 32
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 4
J Requirement for Retention of Records of Withdrawn Documents of External Origin Document Control Systems, Procedures, Forms and Templates 3
T Sharing SharePoint Documents Document Control Systems, Procedures, Forms and Templates 4
M Retention period of documents and records ISO 13485:2016 - Medical Device Quality Management Systems 1
D Offsite storage of QMS documents ISO 13485:2016 - Medical Device Quality Management Systems 9
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A QMS Overhaul - Reorganizing and Renaming Documents - Internal References Document Control Systems, Procedures, Forms and Templates 24
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
qualprod To set frequency to review documents in ISO 9001 7.5? Document Control Systems, Procedures, Forms and Templates 13
S Mandatory documents vs shall "something" but without mandatory documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
M Advertising medical devices in the U.S - Advertising regulations or guidance documents Other US Medical Device Regulations 3
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
C Identifying and Controlling External Documents Document Control Systems, Procedures, Forms and Templates 3
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
M EU MDR - Annex II 3b - What documents fall under this requirement? EU Medical Device Regulations 3
H New 510K VS Documents about design change. Other US Medical Device Regulations 1
M Informational EU – Manufacturer incident report (MIR) for serious incident- template 2020 (Directives and new regulations) version 7.2 and related documents Medical Device and FDA Regulations and Standards News 2
M Informational EU – Some documents related to Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 0
R Implementing Design History Documents/ Technical Documents in the QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
R Approvals on QMS Documents - ISO 13485 Requirements Document Control Systems, Procedures, Forms and Templates 2
K Mandatory Documents for EU authorized Representative under MDR CE Marking (Conformité Européene) / CB Scheme 8
Sidney Vianna Interesting Discussion Hello IAF. Are you listening? Please explain the inconsistency in your IAF Mandatory Documents (2019) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
I QMS documents required at each stage of Software development IEC 62304 - Medical Device Software Life Cycle Processes 5
qualprod Controlling documents in two different Applications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Do we need to treat local law as external origin documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
I Sales Documents in scope for ISO-9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
shimonv Informational New guidance documents about EUDAMED - April 2019 EU Medical Device Regulations 1
L Digitalization of documents - FDA and ISO 13485 Other Medical Device Related Standards 1
G Correction fluid found on documents that are reviewed Qualification and Validation (including 21 CFR Part 11) 11
