Which documents to control apart from QMS related procedures?
JaneB
#11
Everything is done on SAP Business One and the templates for all those documents are all held on this system and I am the only person who has access to change the document templates and assign them to the system. Ie. the users have no option but to use the template which I have assigned, it is impossible to use a previous version in error.
OK - that's a document control system you've described. YOU control these documents by being the only person with access to change/modify. Great system - I like electronic methods of control because they're highly efficient.
I would ideally like to exclude most of these documents
Why? What's the point? (You're already controlling them!!)
K
kgott
#12
Re: Which documents to control
Welcome to the Cove, RunnyBabbit,
Templates and Forms are documents.
I cant beleive it, but I've got someone who has a Doctoroate and a PHD arguing empahaticly that forms and templates are not the same thing for the purposes of creating links in a spreadhseet to the underlying document.
Keep it simple I cry. :nope:
RunnyBabbit
#13
In reply to all:
Many thanks for all the responses, it is very much appreciated.
Just got through the audit yesterday with no non-conformities so I am a happy bunny.
I went with just refering to our use of the SAP system in the Control of Documents/ Records procedure which seemed to satisfy the auditor. So the only documents I listed in the controlled documents schedule were ones which are not handled by SAP and so need to be controlled manually with an issue number etc..
I hope to have a much better understanding of ISO by the time of the surveillance audit next Feb so I will probably be back here!
Thanks again
RunnyBabbit
#14
Hi Jane,
Yes it's dawning on me as I am getting more of an understanding of what ISO is about that I am as you say already controlling them in another system. I think what I was getting at is that I want to avoid the time/effort of having to put footers on all the SAP documents and record reasons for any changes I make etc. as my time as General manager is highly stretched already..
I've also realised that in fact SAP is very well designed as even as a 'superuser' with maximum permissions I still cannot print a blank document from SAP, when I am in edit mode for a template 'print' is disabled. I can only save the changes and then print an actual filled in document - ie. a record not a document... does that make sense?
In addition SAP prevents any changes being made to certain documents such as delivery notes and invoices. These have to be corrected by means of another record being posted on the system. Other items such as quotes and sales orders can be changed and revised... but I've discovered that SAP records all the changes and when/who made them.
JaneB
#15
RunnyBabbit
I now understand more - I'm not sure where you're getting your info on doc control from, but you appear to be laboring undr a few misapprehensions. You don't NEED a document control schedule/log/what have you for example! (I haven't ever even created one for any of my clients.)
The clause is quite general, it talks of the controls 'needed'. Interesting choice of word - I read it as meaning the controls that you decide you need in your organisation and your environment in order to control your documents suitably.
All you need to do - ALL - is to meet the requirements of clause 4.2.3. That's it, game, set and match. I suggest that you read what's there closely and then start thinking about what you already do, before making any major changes.
You probably need some kind of ID on SAP docs, although even that is arguable to some extent. (If there's only ever one current version... then that's the current version.) Just because many people mistakenly believe there 'must' be a doc control sheet/log/whatever doesn't mean they're correct. And they're certainly operating or thinking in a pre-computerised environment and have almost certainly never used or come across SAP or something similar.
As GM, why not delegate the actual doing of it (updates) to someone else, and maintain the authorising of it yourself?
As you say, SAP records all the changes and when/who made them. So... combined with who sets/gives the permissions, there's your control. And you can use some internal audit to satisfy yourself it's working OK.
V
vanputten
#16
This is why I suggested that Runny Babbitt was already controlling the documents, why I suggested some thought on what the "control of documents" means, and why I referred back to the text of 4.2.3 in 9001. Move away from preconceptions and compliance thoughts and look for the value in what is actually required. I suggest maybe not waiting to the next external audit and moving beyond a simple compliance approach.
shallowmike
#18
Hi guys/gals,
This is my first posting in a while so greetings to one and all. I have just been launched back into the world of internal auditing for my new company, so getting back up to speed. I have an issue that during a recent audit I found several unsigned advice notes for receipt of raw material. These have been passed back to our purchasing manager conveniently in his absence. I take this as an uncontrolled part of the process...albeit our purchasing process doesn't stipulates the handling responsibilities of this document.
My question is , is it a non-conformance ( I think minor ) and would it be against purchasing or document control.
Thanks in advance,
Mike
Golfman25
#19
Hi guys/gals,
Thanks in advance,
Mike
Why do the advice notes need to be signed? And where are they supposed to go? Does it really matter? Answer those questions and you'll be further along.
SpinDr99
#20
I have a question for you Pancho. Do you believe forms need to be approved? I know the standard requires approval of controlled documents, but in some (mostly larger) organizations, reviewing and approving of a form is looked upon as unnecessary. I made an exception in our Document Control SOP for approval of forms.
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
qualityegghead ISO13485:2016 4.2.4 Control Of Documents - Lifetime of the Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B Control of Duplicate Documents - Limited Scope (long) Document Control Systems, Procedures, Forms and Templates 5
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
S AS9100 Control of Documents and SAP Implementation Document Control Systems, Procedures, Forms and Templates 1
M Control of External Documents such as customer manuals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 28
Gman2 Control of Documents and (FORMS) on a Computer Network ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Information Gathering Documents and Document/Record Control Requirements Document Control Systems, Procedures, Forms and Templates 9
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
drgnrider Control of External Audit Notes and Documents Document Control Systems, Procedures, Forms and Templates 8
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
U Do we have to have foreign legal documents? (ISO13485 4.2.3 document control) ISO 13485:2016 - Medical Device Quality Management Systems 3
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
C Document Control - Details to include on Documents Document Control Systems, Procedures, Forms and Templates 2
N Control of Documents Scope - Product Specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J ISO/IEC 17025 - Which External Documents require control? ISO 17025 related Discussions 6
S Read Only & Password Protected - Sufficient to Control Documents under 4.2.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Control of Obsolete Documents Document Control Systems, Procedures, Forms and Templates 21
T Are Control Plans "Summary Documents" not meant to replace Work Instructions? IATF 16949 - Automotive Quality Systems Standard 3
C Control of Documents Procedure - Audit Nonconformance Document Control Systems, Procedures, Forms and Templates 30
Q Control Of Documents and Forms - Formats and Numbering Document Control Systems, Procedures, Forms and Templates 3
Q Control of Customer Documents (Documents of External Origin) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Document Control Master List for Obsolete Documents Document Control Systems, Procedures, Forms and Templates 6
K Control of Documents or Control of Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
S Referencing other documents in Control Plans Quality Manager and Management Related Issues 5
F Nonconforming Product Procedure vs. Control of Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L How to control some Documents and Records (ECN's and ECR's) Document Control Systems, Procedures, Forms and Templates 1
P Electronic Record Control (Specifically editable records not fixed documents!) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Document Control using Wiki - Cannot Create all Documents as Wiki Pages Document Control Systems, Procedures, Forms and Templates 10
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Reusing paper of Obsolete Documents to Control Waste Document Control Systems, Procedures, Forms and Templates 12
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
K Link between Control of Documents, CPAR & Control of Non-Conforming Product Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Control of Documents - Converted online in SharePoint Document Control Systems, Procedures, Forms and Templates 9
T External Document (Documents of External Origin) Control Template example wanted Document Control Systems, Procedures, Forms and Templates 14
A Designing a Documents Control System from scratch (in a php intranet) Document Control Systems, Procedures, Forms and Templates 5
R Control of Documents - Drawing (soft copy) for further work by other Consultants Document Control Systems, Procedures, Forms and Templates 1
H 4.2.3 Document Control using Microsoft Sharepoint - Visibility of Draft Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
T Control of Safety Documents Required? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
