Which GR&R study to use?
P
pawski4
Hello all,
Quick background then my question. I have recently completed my Bahelors in Quality Management, I hired in with a young company that does inbound inspection of parts for a large manufacturer. I am currently an auditor, but have applied for a different job internally (had to start by learning the basics). After discussions with my GM, he assigned me a task. Put together a Gage R&R program.
My problem: The GM wants a way to find the effectiveness of the auditors (approx 50) to determine if any of them need to be trianed better how to use the gaging. The first gage he wants checked is a digital caliper. Every auditor will use a pair many times each night. With the goal of deciding competene of the user, i thought the attribute tables would be the easiest to use, however my problem becomes when how to decide a pass or fail using a variable gage?
thank you for any help.
Do not use an attribute study on a variable gage. Perform a variable MSA, then analyze the Average and Range charts for differences between operators.
An operator that needs training will typically have higher ranges in the Range chart, or apparent differences in the Average chart (e.g., higher, lower, more variable, etc.).
Don't use this as a punishment method or everything that you try to accomplish with MSA will eventually fail. If operators are singled out for training, it could also cause issues. Consider training all operators, but give extra attention to those with issues.
David DeLong
I agree with Miner. The R & R variable study is for the appropriateness of the gauge in the application. Make sure all people involved in the study are "trained".
If you are using a micrometer, do not re-zero it between Operators.
A variable study is used to determine whether the measurement system, including the operators (not just the gauge), is appropriate for the application.
I assume you're referring to a digital micrometer. If so, the same would apply to calipers (or other digital devices). The method for use of digital micrometers or calipers should include having operators make sure that the device has been properly "zeroed out"; if an operator feels the need to re-zero the thing, it means that there is lack of consistency in using the device, which is part of what you're looking for. MSA results are sometimes found in places other than the mathematical calculations.
David DeLong
Jim:
Performing R & R studies, make sure that the people are "trained". After that, it is the measuring system (rather than gauge alone) that we are reviewing for its application.
I don't think we can "cherry pick" Operators today in high volume but we certainly can change the gauge.
Just some thoughts.
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 7
S 95% UCL - Attaching an excel for recovery study Statistical Analysis Tools, Techniques and SPC 0
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
E Use of OQ cleared batch for stability and clinical study use ISO 13485:2016 - Medical Device Quality Management Systems 0
S Study sign off question / responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M Case study resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S A clinical performance evaluation study with an IVD product as Investagional Use product - Clinical Monitor requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
A CE Mark and PMCF study EU Medical Device Regulations 3
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K IATF & Attribute Study requirements IATF 16949 - Automotive Quality Systems Standard 9
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
L ASQ CBA biomedical auditor - CBA primer material is enough to study? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Brazil forced degradation study requirements Reliability Analysis - Predictions, Testing and Standards 0
P RAC-US Spring 2020 Study group_Discussions Professional Certifications and Degrees 19
M Custom Medical Device For Clinical Study Other Medical Device Regulations World-Wide 1
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
R PMCF plan to justify that our product not require PMCF study EU Medical Device Regulations 4
E How much a bioequivalence study will cost in the UK Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
N MSA Study for a Leak Testing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
Ajit Basrur How do I label this commercial product ready for clinical study? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
H Safety and efficacy study for CE marking CE Marking (Conformité Européene) / CB Scheme 1
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
A Audit purpose - case study - What is the role of SQE in such case? General Auditing Discussions 3
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Case study - If the restaurant (ISO 9001:2015 certified) was run by 2 persons covering cooking and purchasing processes (Mother and Father) supported ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Student wanting Case Study about Internal Audit Report Internal Auditing 1
T RAC US certification - Study group Professional Certifications and Degrees 7
M IVD Registration - Use of Prospective Study Data Other Medical Device Regulations World-Wide 1
