Which is the range for the validated batch size(for example ±5%, 10%) is acceptable?
Eva lee
:)Hi to Everyone.
We have complete our process validation of our product using the full scale batch size. However , I dont think we could product very just the batches size of what we validated for each batch.
So, Which is the range for the validated batch size(for example ±5%, 10%) is acceptable?
Is there a official document issued by any FDA/MOH in where is defined the range .
Do you also have information on this issue?
Thank you for you support.
optomist1
A Sea of Statistics
...pls clarify:
"Full Scale Batch Size?
"Range of Validated Batch Size?
Separately, sharing details (where not sensitive) re: the process/product in question will help..
Cheers Optomist1
Eva lee
Product: powder for injection
Size that validated by process validation: 400,000 vials
What we want know: the size range allowed /acceptable for real production of each batch, for example, 400,000 vials ± 10%
As far as I know, batch size is determined by whatever you or your customer think is suitable, or by materials, or sometimes by the production pace. Maybe it's because I'm not familiar with medical industry. It seems like that the batch size is pre-set by your company, can you share any specific reason for that if possible?
In fact, This question regarding the size range of products of the grouped batch is determined by you and your customer and it has not specified clearly this requirement in the medical quality management system. however, the change of size range would add your manufactured cost and time.
Enghabashy
the technical file for each medical product should be considered as reference of company procedures , specially QC , i.e , the following MS ISO 13485, clause :d) procedures for measuring and monitoring;
4.2.3 Medical device file
For each medical device type or medical device family, the organization shall establish and maintain one
or more files either containing or referencing documents generated to demonstrate conformity to the
requirement of this International Standard and compliance with applicable regulatory requirements.
The content of the file(s) shall include, but is not limited to:
a) general description of the medical device, intended use/purpose, and labelling, including any
instructions for use;
b) specifications for product;
c) specifications or procedures for manufacturing, packaging, storage, handling and distribution;
e) as appropriate, requirements for installation;
f) as appropriate, procedures for servicing.
Enghabashy
The determination of samples size should be outlined as the one of :7.3.6 Design and development verification which stated statistical techniques with rationale for sample size.
-The organization shall document verification plans that include methods, acceptance criteria and, as
appropriate, statistical techniques with rationale for sample size.
Semoi
In order to setup an acceptance sampling plan you need to choose four quality quantities:
1. The producer risk alpha,
2. The specified quality of the batch, which you ensure with the above defined producer risk,
3. The consumer risk beta,
4. The specified quality of the batch, which you ensure with the above defined consumer risk.
As an example: If the batch has a quality of 99%, we like have a producer risk <= 5%. However, if the batch has a quality of 91%, we like to have a consumer risk <= 10%. Assuming that we have a binomial distribution we are able to calculate that we need a sample size of 58 and that the allowed failure rate to pass is 2. These tips of calculations can be easily done for different distributions and different choose values. However, nobody can define the acceptable/needed values for you -- you will have to define them yourself.
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Simulate Tolerance Range with Real Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D How to calculate the A4 constants in Median/Range control charts? Statistical Analysis Tools, Techniques and SPC 2
Z GR&R: What if there are points out of limit in range charts? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
S How MR (Moving Range) in Z-MR chart is calculated Using Minitab Software 5
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
M Electropolishing Validation of Orthopedic Parts - What OQ parameter range Manufacturing and Related Processes 1
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
V Correlating Maximum 'Range' of Values for a given "RSD" (Control Limits) Statistical Analysis Tools, Techniques and SPC 3
Ajit Basrur Should calibration range of Oscilloscope cover the test ranges? General Measurement Device and Calibration Topics 8
S Supplier Evaluations of a wide range of suppliers and different products IATF 16949 - Automotive Quality Systems Standard 8
S Excel Help - Equivalent of "Range($G$14:$AD$121).Select" in R1C1 notation Excel .xls Spreadsheet Templates and Tools 5
S Calibration Documents that offer guidance on Calibration Range vs Use Range General Measurement Device and Calibration Topics 6
W Is the GR&R result caused by the wide spec range? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S What is the accepted range for "Inventory Reconciliation" for RM and FG ? US Food and Drug Administration (FDA) 3
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Long Range OC Curves - Acceptance Sampling Switching Rules Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Performing a Gage R and R with No Specification Range Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Main difference between X-bar sigma chart / X-bar range chart Statistical Analysis Tools, Techniques and SPC 4
R Count NDC from Graphik Sample Range vs R chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
L Remote Control Inspection Digital Indicator with a TIR (range) function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Method Comparison Design Onput Sample Range Requirement Design and Development of Products and Processes 3
M Validity of Calibration outside the Calibration Range General Measurement Device and Calibration Topics 7
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
Q What is the salary range per hour for a Quality Management System Coordinator? Career and Occupation Discussions 10
C Roundness Tester Gage R and R Frustration - Tolerance range of 20 microns Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
K Almost embarrassed to ask... SPC UCL/Data Range Quality Tools, Improvement and Analysis 4
T How Can I Change the Date Range on Charts in Minitab? Using Minitab Software 1
B AMS 2750 Furnace Instrument Calibration Operating Range AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Why a Lower Control Limit on Range and Sigma Statistical Analysis Tools, Techniques and SPC 7
S Using Range/Tolerance to Guesstimate NDC or % SV? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V Determining the Range and Limits for Differential Pressure ISO 13485:2016 - Medical Device Quality Management Systems 3
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
R GR&R (Gage R&R) - Average Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Individuals 2 Point Moving Range Chart Statistical Analysis Tools, Techniques and SPC 6
K Micrometer Calibration - Resolution, Accuracy and Range General Measurement Device and Calibration Topics 16
J Acceptable Tolerance Range for Freezer - Writing an IQ/OQ for a Freezer US Food and Drug Administration (FDA) 2
L Good Excel .xls sheet for Gage R&R that calculates both Anova and Range Excel .xls Spreadsheet Templates and Tools 9
E What is the temperature range for drug manufacturing? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
D How do I draw Graph a Mean & Range Chart & FIND CL UCL UCL for this data on Excel Statistical Analysis Tools, Techniques and SPC 4
V Operating Range & Calibration for Analytical Balance General Measurement Device and Calibration Topics 3
R Inspection Humidity Control - Range for Mechanical Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Influence of the Coverage Factor - Worksheets based on the Average and Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
