Which ISO 9001 Clause applies to "Procedures are outdated"?
Sidney Vianna
Post Responsibly
#12
The other side of this point is that I have seen a deviation of processes and procedure which has improved the effectiveness of the process but was not properly documented.
I agree. Sometimes, the mismatch between the deployed process and the documentation defining the process is because the process evolved and the documentation revision is lagging behind.
That is what I wrote in this post, over 8 years ago.
Failure to follow established procedures signify failure to implement PROCESSES, as devised. ISO 9001 is about process control & improvement. Documented procedures exist to describe how the process is supposed to work. Thus, and obviously, if you are not following a documented procedure, chances are, you are deviating from the intended way the process is supposed to be executed. Unless it is one of those instances where the documented procedure has not been revised to catch up with the intended process.
Tagin
#13
Hello Readers,
I am doing my first internal audit in this company, During the audit , I found out that the supplier evaluation procedure is not up to date. We are not currently perform some of the activity which are written on procedure.
So I am writing the NCR for this finding and can't figure it out which ISO clause should i mention in the Non-conformance. Should it be 7.5.2 (c)?
Thank you for your help !
Regards
I would think that it would be 6.3b Planning of Changes ("The organization shall consider: b) the integrity of the quality management system;").
At one time, the procedure matched the process.
Then, the process was intentionally changed but the documentation was not changed, which broke the integrity of the qms.
Hence 6.3b.
4.4.2a ("maintain documented information to support the operation of its processes") applies too, but since this NC was due to a process change that was not properly planned, I think 6.3b is the one to mention.
Another way to look at it is: if this happened in one process change, what corrective action will prevent it from occurring in another process change in the future?
I think the answer is: better planning of process changes; i.e., 6.3 Planning of Changes.
#14
Hello Readers,
Regards
Since this is your first audit, if I were your audit manager (IA Process owner) I'd be debriefing you along the lines of:
How did you determine the evaluation procedure is not up to date?
Which activities are not being performed? Why is that?
What is the effect of not doing these activities?
Before you worry about which clause of a standard to apply (which, frankly, management don't know or care to know about), let's make a compelling case for management to resolve the exact nature of what you have found. Simply "not following procedures" isn't going to capture anyone's attention...
normzone
#15
I'm involved in a similar situation at this time - significant reduction in force, so not all of the layers of management referenced in the documentation exist any more, and not all of the work referenced in said document is being done.
That said, some more efficient methods of getting the corn through the goose have evolved, so there are upsides to the challenge as well.
Sidney Vianna
Post Responsibly
#16
What are the methods used to capture this organizational knowledge of more efficient methods? Because, there is always a risk to lose this knowledge if and when the reduction in force affects more employees.
normzone
#17
Internal audits are revealing the dichotomy betwixt the process documentation and the process actual, documents are getting updated.
John Broomfield
#18
norm,
Don’t forget that between to actual process (aka work) and the out of date documented procedure you have the actual undocumented procedure.
We quite often make the mistake of thinking the way we carry out the process is the process when it’s actually the procedure.
So, if the process is effective and working in accordance with the undocumented procedure is the documented procedure necessary?
John
#19
norm,
John
I've found it common that the documents and the practices are different. Too many people draw process flows which are the "logic" of the process and not what actually happens. Again, this is often done in isolation of the people who have to deal with the issues of an ineffective process.
The need for documentation doesn't come from a process being effective. It comes from understanding the context of the organization and the need to retain knowledge!
John Broomfield
#20
I agree with you.
Our documented procedures could help us to manage organizational knowledge by giving the process team members the authority to mark them up so they accurately reflect their process.
Instead our documented procedures tend to become relics.
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
A ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
B Clarification of ISO 9001:2015 Clause 8.5.6 Control of Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001:2015 Clause 8.2.1 e) - Requirements for Contingency Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Application of ISO 9001:2015 Clause Interpretations for Service Industries Service Industry Specific Topics 2
J Organizational Knowledge Requirements - Meeting ISO 9001:2015 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 60
