Which ISO 9001 Clause applies to "Procedures are outdated"?
Sidney Vianna
Post Responsibly
#21
Internal audits are revealing the dichotomy betwixt the process documentation and the process actual, documents are getting updated.
That’s a good thing, but in a true process approach system, process owners should be controlling/documenting the changes to process. Internal audits should not be the primary mechanism for that, just like product inspection is not what makes a product conforming to requirements.
I know that in a workforce reduction mode, process owners see their resources stretched, but, still it would be preferable to have process owners responsible for managing change within their sphere of control, rather than relying on audits to identify the mismatch.
#22
Hello Readers,
I am doing my first internal audit in this company, During the audit , I found out that the supplier evaluation procedure is not up to date. We are not currently perform some of the activity which are written on procedure.
So I am writing the NCR for this finding and can't figure it out which ISO clause should i mention in the Non-conformance. Should it be 7.5.2 (c)?
Thank you for your help !
Regards
First, you shouldn't be writing NC statements against the standard. We should be able to assume that our processes are designed and executed in accordance with the requirements of the standard. If the documented process for supplier evaluation isn't being followed, the nonconformity should reference the documented supplier evaluation requirements.
The other thing is that it might not be so important in the grand scheme of things that the documented procedure isn't being followed. The important thing is why it's not being followed. Oftentimes procedures aren't faithfully observed because they're defective, illogical, unnecessarily vague or onerous and/or don't represent the most efficient way to accomplish the task at hand. In other cases, people responsible for executing the process are ill-trained or just negligent, perhaps purposefully so. Find out why the process isn't working as designed and fix it.
#23
norm,
Don’t forget that between to actual process (aka work) and the out of date documented procedure you have the actual undocumented procedure.
We quite often make the mistake of thinking the way we carry out the process is the process when it’s actually the procedure.
There are senses in which "procedure" and "process" are synonymous. What is the difference between "undocumented procedure" and "undocumented process"? We need to be more careful about differentiating between the document and the actual work being done. The map is not the territory.
So, if the process is effective and working in accordance with the undocumented procedure is the documented procedure necessary?
The argument could be made that there is no way to gauge the effectiveness of the process in the absence of documented requirements.
normzone
#24
Yeah - when I have somebody complaining about why they need documentation for a given process when "everybody knows how to do it", I just ask what the consequences of that process not happening reliably would be.
Too often I've had employees tell me they've never seen the process documentation before when I ask their input regarding it being fact/fantasy.
#25
It's at least theoretically possible for people who have never seen and never will see the documentation to do the work as they were trained to do it. While work instructions must be available, that doesn't mean that they must be read. People should understand why the process has been designed and structured as it has been, the potential consequences for not doing it that way, and be able to suggest improvements.
John Broomfield
#26
Jim,
You asked "What is the difference between "undocumented procedure" and "undocumented process"?""
Process is work by machine, human or animal or by a combination of these "workers".
Document the process and you have a documented procedure or the beginnings of one.
So I see no difference between a documented process and a documented procedure but a process is not a procedure.
It is very helpful for us to see clearly the difference between process and procedure because it can focus our attention on the work itself.
John
#27
Jim,
John
John:
I seem to recall that a (previous) ISO definition was that a procedure was a way to carry out a process... Now, I'm not fully in agreement, since I'm not certain that everything is considered a process, but hey, what do I know?
John Broomfield
#28
Andy,
Only work is process and we both know what work is surely? ;)
We've both seen functions and departments (such as HR) called processes. This may be because some departments are named for their process such as Engineering or Training.
In resisting ISO 9000's process approach many of us convinced ourselves that process was just a fancy name for a procedure so this confusion may be two decades old.
I try always to use both terms correctly because our failure to distinguish clearly between process and procedure must be very confusing for newbies.
Cheers,
John
#29
If this is the case, what is the difference between a documented process and a documented procedure? If there is such a thing as a documented procedure (where the word "procedure" is meant to refer to a document) what is an undocumented procedure, if not a process that's not documented?
John Broomfield
#30
Jim,
In my experience when people say “undocumented process” they usually mean that it is a process that may or may not conform to an undocumented procedure.
I may first seek clarification by asking if they mean the way the work is done is undocumented.
John
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
A ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
B Clarification of ISO 9001:2015 Clause 8.5.6 Control of Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001:2015 Clause 8.2.1 e) - Requirements for Contingency Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Application of ISO 9001:2015 Clause Interpretations for Service Industries Service Industry Specific Topics 2
J Organizational Knowledge Requirements - Meeting ISO 9001:2015 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 60
