Which kind of document is the Quality Policy?
SteelMaiden
#11
It would seem that the quality policy would be a "policy" and along with that would probably be your quality manual, as that also sets out policy?
bubonic
#12
Re: Which kind of document (is the Quality Policy?)
As it sets the tone for the quality system I suggest it is the first document and fittingly I would suggest it is named QP001 (I have subsequent quality procedures QP002 etc). Additionally in my humble opinion it should have a review interval of one year (reviewed at AMR) to ensure it remains fit for purpose.
I accept there are many other quite acceptable numberring conventions but this has worked for us.
"Keep it simple" & "Less is more"
JaneB
#15
I want to make a code title to our quality policy, for that, i have to define which kind of document it is.
Selena, if you have to define a type, and there isn't one for Policy in your system, then I also think you need one. If you have a type something like a 'Standard', it could fit into that, but definitely don't make it a record.
I am assuming from your saying you 'have to define it' that your system (an electronic document management system perhaps?) has document types or categories or what-have-yous.
Cheers,
Jane (type: female, Caucasian, consultant, Victorian, Australian)
selena15
#16
Hi All
thanks for replies
Yes it is our quality policy Randy
Our documentation system include a categorization of document ( Workflow; Procedure, Instructions; Plan; Specifications; Catalog/List)
this is why i'm in very restricted area to change. the updating of our procedure is scheduled but until this; we have to work with the current procedure; isn't it ?
this is why i'm confused
I also thought to don't give it a code but just title and revision code in order to control it but here i can't included it in our Electronic documentation system.
' standard' is the kind of document of the policy ; i'm asking about the common way to consider it . ? we don't have this type defined
I'm agree with you Jim to avoid this kind of categorization but for this moment this is what we have and the update is posponed for some internal considerations
This is my issue :frust:
selena15
#18
ok Randy
I got it, it is a document not record but which kind of ?
it is really not possible to involve it into any kind of document that i discribed above ? :truce:
#19
ok Randy
Don't confuse the container with the thing it contains. You can categorize it however you want to, and it won't alter the content of the document, or its purpose. Either create a new category or shoehorn it into an existing category--either way, it's the same document.
JaneB
#20
As Jim says, if you have to 'shoehorn' it into an existing type, then do.
But for my part, I think any classification is a rather strange one if it doesn't allow for any Policy. (But yes, I DO understand that changing an embedded system could be difficult! You could probably argue for several different types - I'd be inclined toward a 'specification' on the grounds that it 'specifies' what should be done at a very high level, but I"m sure there's other points of view.
I wouldn't spend a lot of time worrying about it - and no, you definitely don't have to give it a number or a code or anything like that.
To take a leaf out of Randy's book, you could even call it 'Jack & Jill Go up the Hill' and make it a 'form' type, provided the content has what is required. Though I wouldn't recommend this approach & it might take a little bit of explaining to your people & your auditor if you did though ;)
J Process within Quality Pyramid - Create a new kind of Document IATF 16949 - Automotive Quality Systems Standard 16
L Document review is a kind of verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Is a Production Plan a kind of Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I What kind of information needs to be in a calibration record? General Measurement Device and Calibration Topics 25
A Why I get a different kind of regression equation when I do the same data in a differ Using Minitab Software 7
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
T Is Sorting a kind of Rework? IATF 16949 - Automotive Quality Systems Standard 3
R What kind of Objective Evidence - AS9100 Cl. 7.1.6 - Organizational Knowledge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Mixed Reality - What kind of possibilities can you imagine? Coffee Break and Water Cooler Discussions 1
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
V What kind of audit for a production transfer? Internal Auditing 3
A What kind of test is described in subclause 56.3(c) of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J What kind of beauty/skin products should 20-25 year olds use Coffee Break and Water Cooler Discussions 1
N This is my kind of flow chart ;) Funny Stuff - Jokes and Humour 5
W What kind of data is expected for a PPAP Material Analysis Report IATF 16949 - Automotive Quality Systems Standard 7
D Template for the kind of naming convention on my test setup Manufacturing and Related Processes 2
K What kind of people are suitable for Quality Management? Career and Occupation Discussions 12
J What kind of a visual aid is this? Document Control Systems, Procedures, Forms and Templates 10
C What kind of information you provide when conducting QMS Orientation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
H What kind of training would you recommend to start on the process improvement world? Training - Internal, External, Online and Distance Learning 8
Marc Interrupted Sleep Might Be the Best Kind Coffee Break and Water Cooler Discussions 2
V What kind of Data should support Fit/Function Characteristics? APQP and PPAP 1
D What kind of ISO 14000 do I have to use on this Company? ISO 14001:2015 Specific Discussions 9
E What kind of questions will you ask on a quality quiz? Misc. Quality Assurance and Business Systems Related Topics 8
J Which kind of medical equipment must comply with IEC60601-1-8? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B What kind of insulin syringe is this for? ISO 8537:2007 Section 8, Table 1 Other Medical Device Related Standards 1
M FMEA for Drilling Process - What kind of failure can happen during drilling process? FMEA and Control Plans 8
N ISO Standards Applicable to Our Kind of Work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Are Withdrawal and Recall a kind of Control of Nonconformity? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Y Halogen Free - What kind and type of plastic resins contain Halogen? RoHS, REACH, ELV, IMDS and Restricted Substances 3
Jim Wynne My Kind of Job Funny Stuff - Jokes and Humour 3
D What kind of DMR must a Medical Importer have? Other Medical Device and Orthopedic Related Topics 8
J Kind of Changes that affect the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Internal Auditor Training - How much training and what kind of training Internal Auditing 18
S What kind of certification do we need in our medical equipment company? World News 11
W What kind of materials should I prepare for passing ISO IEC 60601-1-4 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
S Strategy for implementation Lean Six Sigma - What kind of research? Six Sigma 4
G What kind of documents shall be prepared by a Multidisciplinary approach? IATF 16949 - Automotive Quality Systems Standard 1
H No Final Inspection - Can this kind of a policy meet ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L What kind of Gage R&R is needed for a Pull Test Machine? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Appearance Approval Report (AAR) - For what kind of product is AAR applicable? APQP and PPAP 5
E Machine Set-Up Sheets for More Than One Kind of Equipment FMEA and Control Plans 15
SteelMaiden What kind of corrective action is this? Lead based paint in childrens' toys Nonconformance and Corrective Action 13
Q Improvement Initiatives - what kind of meetings or activities are relevant? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Help: What kind of doc is this and that? Document Control Systems, Procedures, Forms and Templates 2
S What is IMDS? Does Any kind of other thing other then four wheel manufacturing? RoHS, REACH, ELV, IMDS and Restricted Substances 3
ScottK Realistically - What kind of DPMO and sigma for a $5.00 part? Six Sigma 30
