Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm?
refractoryman
Which on is "most important" ... Ppk, Cpk, or Cpm? In other words, which one is the most practical to use for an operation that has yet to use any of these? Or are all three equally important? Please advise.
Thanks,
CUFF
antoine.dias
I would start with Cpk (based on spotchecks) and use the data for steering the process.
After a while - considerable number of spotchecks - you can calculate Ppk (based on all measured values). Actions should be taken to get both "in control"
Then I would start using Cpm to get the process more and more centered thus improving the process more.
Hope this helps
Darius
Thanks,
CUFF
You can have a long discusion about this question, :2cents:, any indicator is a simplification of the real thing, there are some things that you can't see on any of them, as trends, outliers, cyclical trends, etc.
IMHO, any of them could be a good thing to follow, if there is no outliers on the data. Most of the people could say that Cpk is better than ppk because, ppk is for non-stable process and being non-stable, you can't trust on it to predict the process capability (as Don Wheeler, Advanced topics on SPC), even they say that you shouldn't calculate it if the stability has not been proved.
Some say that Cpmk, is good if your process is not centered, but the good point is that it take in account the centering to the target, with cpk or ppk you can have the same or better index if you are farther from the target but with less variation, and that is wrong, cpmk is more robust to this kind of event. The problem with Cpmk/Cpm is that just a few use it.
The question of ppk or cpk is ... when is stable?
If your customer does not require you to report these - just plot your data. these indices are far more trouble than they are worth.
If you are interested in capability, you should be plotting your data in time series against the specification limits. Look up multi-vari charts. this is the best graphical format for capability and the best place to start understanding and visualizing your process variation without the confusion of summarized indices. (I do use these before implementing SPC)
RoxaneB
Thanks,
CUFF
Most important to whom? Who is the data for and what is the purpose for collecting it? Is there value to calculating these values for any particular Stakeholder?
The answers to those questions might help your organization determine what is "most important".
refractoryman
Steve:
Please expound on "none of the above."
bobdoering
Stop X-bar/R Madness!!
One of the biggest problems with Cpk, etc. is it is one number used to represent a very dynamic issue - process capability or performance. The only person that is impressed with the power of one number is a lottery winner.
Also, there are strict limitations as to when these values are applicable, such as the variable must be bilateral with target in the center, the process distribution must be normal (and not normal because poor gaging and measurement are masking the true process distribution). The target in the center must be supported by an accurate specification with a narrow loss function. Otherwise, chasing the center is a waste of resources.
It is a requirement often rubber stamped by people looking for a cheesy 10,000 foot feel for the process. I hold very little decision making power, unless the process is horrible (in which case you likely don't need this index to tell you that).
refractoryman
bobdoering:
Please explain "bilateral with the target in the center" and "specification with a narrow loss function" for me please
I want to be absolutely sure that I am understanding all of this in detail. I appreciate your patience with me.
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
M Medical Device News Brexit - Withdrawal Agreement and Political Declaration laid before Parliament following political agreement. EU Medical Device Regulations 4
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
S Supplier Classifications - Please give me a good definition of the following terms ISO 13485:2016 - Medical Device Quality Management Systems 5
K Nonconformance on training - Not following own processes (IATF 16949) Internal Auditing 14
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
M Please explain the following Automotive Acronyms IATF 16949 - Automotive Quality Systems Standard 3
C Following Order of Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 23
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
T What to do when Employees are not following Instructions Human Factors and Ergonomics in Engineering 65
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R QA Manager and Disciplining Employees for not following Processes Quality Manager and Management Related Issues 28
I Medical Device Registration details for the following Countries ISO 13485:2016 - Medical Device Quality Management Systems 5
M Sampling Inspection at QA - Inputs on the following sampling plan Statistical Analysis Tools, Techniques and SPC 3
N My FDA auditor asked the following: Other US Medical Device Regulations 12
Q How to determine the average baseline for the following data in SPC Quality Tools, Improvement and Analysis 3
M 7.6.2 Revisions following Engineering Changes - What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 4
Marc Software gives visual representation of who?s following you online After Work and Weekend Discussion Topics 1
Ronen E European Commission calls for action following PIP's Breast Implant Saga EU Medical Device Regulations 1
T Employee not following Purchasing Process Other Medical Device Related Standards 27
Marc US east coast in chaos following rare October snowstorm - 2011 Coffee Break and Water Cooler Discussions 14
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
L Consultant not following Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
Q Can I use Regression Analysis in the following scenario Statistical Analysis Tools, Techniques and SPC 18
Q Supplier Disqualification - High Rejects and not following established Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Change Order Process - Stake holders not following through - Suggestions wanted Manufacturing and Related Processes 5
D Manufacturing Execution Systems (MES) - People Not Following Work Process (WPs) Manufacturing and Related Processes 5
L Fitted Splined Connections following DIN 5480 - Inspection Problems Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
eternal_atlas Not following the Procedures is a Nonconformance? Sales department General Auditing Discussions 61
H Meeting following an interview, what should I expect? Career and Occupation Discussions 15
T Labeling Control and trouble with labelers not following procedure ISO 13485:2016 - Medical Device Quality Management Systems 11
Ajit Basrur Teva recalls drug following Jackson death probe Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A Audit NC (nonconformance) for not following guidelines on calibration! General Measurement Device and Calibration Topics 9
S Consequences of Shipping product with label not following CE rules EU Medical Device Regulations 2
Q Corrective Action - CAPA - Root Cause - Not following the training procedure! Problem Solving, Root Cause Fault and Failure Analysis 13
S Why people not following SPC charts regularly Training - Internal, External, Online and Distance Learning 10
G Not sequentially following steps in a work instruction Process Audits and Layered Process Audits 85
Q Work Environment - Which of the following is to be addressed as nonconformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Z How to Establish Quality Manual Not Following the Structure of the Standard? Quality Management System (QMS) Manuals 3
D How do we interpret the following XmR Trend Chart data? Statistical Analysis Tools, Techniques and SPC 3
L Corrective action following a wrong answer of the auditee ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
T In the following statement, what does "Z" stand for? ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Failure where the Root Cause was the Material Handler Not Following Procedure Problem Solving, Root Cause Fault and Failure Analysis 20
Q Personnel Not Following Procedures - How do you write up an audit finding? Internal Auditing 43
A Non-conformance logged following a TS16949 Stage 2 audit - APQP Control Plan IATF 16949 - Automotive Quality Systems Standard 15
