Which of these 2 ways would you implement a Quality System?
Christian?
Hello :)
This company have no quality system as of right now. but the paperwork for it is complete (instructions, procedures etc.).
you can categorize the different elements of the quality system. Down below is some examples:
- Management of document (Procedure + instruction)
- Subsupliers (procedure)
- Production equipment (procedure + instruction + list)
and so on.
Would you implement the system on a logical basis (make sure equipment are OK then make sure personal is OK, then make sure required documents for them to use is OK and etc.)
OR
Would you implement the system based on current customer demands?.
The system is tailored for welding. this means WPS / WPQR (Welding procedure specifikations) and more, often demanded documents. they sometimes ask for equipment list which holds all spec's. they ask for a welding coordinator or that your measure instruments are calibrated and that is documented.
Would you implement the system unlogically, so you can meet the customers demand faster (many accepts there is no quality system as a whole, but certain things are implemented, like the proper WPS). or would you still implement it in the most logical way, but with the sacrifice of not being able to please some customers as fast as possible?.
Its hard to describe it. but the princip of it, is what i'd like to hear your thoughts on. and is it possible to implement a complete quality system in different ways at all?
K
kgott
Re: Which of these 2 ways would you implement?
Hello :)
and so on.
OR
You document how the processes in your business work then you look for how the requirements of 9001, or whatever standard you are working to, applies to those processes. Then you build in those requirements of the standard which are not currently being applied in your business, to the processes in operation.
ISO 9001 is a framework for managing any business of any sort of any size. It's not perfect in its wording but it requires no more than what any well managed business would be doing.
Christian?
The documentation is done. so the processes are described including the new changes to meet the standards demands.
But you can't implement everything at once, with only one person working with the quality. So there needs to be a plan for how to do it.
Currently, no one follows a procedure or instruction, so for the most part, its quite some changes. therefore i suppose some areas should be implemented before another one.
Some processes are linked to a previous one so that is something to consider.
There is alot of focus on having a documented quality system now and forward.
But getting this new quality system up and running will not be done in 2 days.. it will problaly take months to get it up and running and certified.
Where would you start if you were to implement a quality system, when there is none already?
SmallBizDave
Perhaps we're missing something. If your documents are done you should start doing audits to compare your actual work practices with what the procedures call for. You'll find mismatches where people aren't following what the document says to do.
For those situations you'll need to decide whether to change what people are doing or change the document to match what they are doing. You'll need to do this at least once for each procedure in each affected area.
In terms of where to start, I'd suggest starting with the area that will most directly affect the quality your customer gets in your product. Typically this is the production area, covered by section 7.5 of the standard. That will lead you into other areas like purchasing, document control, and so on.
Wes Bucey
Prophet of Profit
Just for the sake of conversation, how did " the paperwork for it is complete (instructions, procedures etc.)" get complete? Is this a set of documentation from someone else's documentation with only the company name changed or did someone actually watch how the processes and activities happen at your company and document them?
How many people from the company who actually perform operations were involved in formulating the documentation? Do ALL the employees already know about the existence of this documentation or are you going to spring it on them once you figure out which way you will implement them?
Did you perform a gap analysis of current operations against a Quality Management System Standard and discuss the discrepancies and gaps with ALL the personnel?
Alas, I'm old and tired, but not so old and tired that I don't care about letting someone go off half-cocked, wasting time and money on a plan grafted from another company's documents.
Give us some details about what went into creating this "quality documentation" and we'll try to steer you in the right direction.
Christian?
Hey again :)
I like the princip of going after what impacts quality the most.
Wes. Unfortunatly they are made without having spoken much with the people themself. so they are based on:
- What the standard says
- What we do now
So it is not someone else's paperwork with the company name simply changed.
So the best way would to do a pre-audit. Taking notes on what is currently fullfilled, and find out what is exactly done right now then try edit the documents to match as much as possible, as long as its within the standard (and if it doesent harm the end quality either).
I am new to this, thats why there surely is some errors here and there and you guys are experts. Dont be too harsh on me hehe :)
Besides Wes. i know you can't force something down their throats, its a company wide project, not just something one person can make.
I will take these suggestions with me to help.
mlaurie
We actually did this last year in preparation for our AS 9100 certification that we achieved in March 2013. Most business are meeting most of the standard anyway. It?s that shove by Top Management that?s needed to complete the deal. I don?t see how it?s possible to do the documents first. Walk the processes and the procedure writes itself. Responsibility & Authority define it and stick to. In hind sight our Q manual could have been 10 to 15 pages max. We tried it the other way on our 13485 Medical division, we wrote procedure?s by copying and pasting someone else?s system. It still a mess and taking a lot of re-write to get to current practices.
If top management is pushing it and you have the green light keep it real.
T Starting down the 14001 path - Ways to implement 14001 at my organization ISO 14001:2015 Specific Discussions 1
John Broomfield Five ways to botch your supplier management program Misc. Quality Assurance and Business Systems Related Topics 7
C Design Control - Ways of capturing inputs from manufacturing Other Medical Device Related Standards 5
S Ways to attract clients - Flyer distribution in Toronto, Canada Service Industry Specific Topics 1
S Ways to demonstrate objective evidence that employee is trained and competent ISO 13485:2016 - Medical Device Quality Management Systems 28
J AS9100D - Good ways to document an internal audit plan / schedule Internal Auditing 25
S What are some ways to demonstrate Effectiveness of Training? ISO 13485:2016 - Medical Device Quality Management Systems 29
L Ways to improve testing on our department - Project Kickoff Misc. Quality Assurance and Business Systems Related Topics 4
E Best Ways to Close a Project APQP and PPAP 3
F Supplier Audits - Creative ways to gain confidence in the next Supplier Training - Internal, External, Online and Distance Learning 6
M Can Six sigma support ISO9001? If yes, in what ways? Lean in Manufacturing and Service Industries 5
N Ways to Destroy Scrap Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A Creative ways to access Expert Information when you can't afford a top $ Consultant Misc. Quality Assurance and Business Systems Related Topics 7
C Appropriate ways to address Competency? Generic vs Specific ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Ways to check to see if the gage is being used General Measurement Device and Calibration Topics 11
AnaMariaVR2 3 Ways To Deal With People Who Play Office Politics Against You Coffee Break and Water Cooler Discussions 7
Marc Retail stores plan elaborate ways to track you After Work and Weekend Discussion Topics 0
S Change in Career Path - Logical Steps Up and Ways Forward Career and Occupation Discussions 3
R 6.2.2 - Any other ways to satisfy it if No Performance Evaluation carried out? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Recognition of team members in ways other than money? Customer Complaints 5
K Ways to Improve Document Control Document Control Systems, Procedures, Forms and Templates 10
L Creative and powerful ways of Communicating your QMS to your Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Different Distribution Parameters when analyzing the same data in different ways Using Minitab Software 8
J What are the best ways to capture Customer Perception? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
bobdoering Dr. Wheeler on "How Measurement Error Affects the Four Ways We Use Data" Measurement Uncertainty (MU) 0
M Ways to encourage participation of other dept in preparing for the surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Other ways to Measure Customer Perception apart from Surveys ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Plastic Mold Approval - What are the ways to reduce mold approval cycle? Manufacturing and Related Processes 8
V Ways to Recycle Paper Miscellaneous Environmental Standards and EMS Related Discussions 15
P 5 Ways to Ensure Mediocrity in Your Organization Lean in Manufacturing and Service Industries 2
N Ways to avoid injected bugs while Bug fixing (software) Problem Solving, Root Cause Fault and Failure Analysis 5
A Ways of Gathering Customer Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Definition Modify, Magnify, Minify, and Substitute - Seeking practical ways of differentiation Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 17
S Lean - Ways to Measure Equipment Flexibility - Flexible Manufacturing System (FMS) Lean in Manufacturing and Service Industries 2
C 5 Ways to Find Product Standards AQL - Acceptable Quality Level 0
V ISO 9001 Virtual Audits - Ways to audit remote locations such as design centers General Auditing Discussions 6
R CMM Machine upgrade - Ways to reduce CMM inspection cycle time Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Ways where a Document Controller's Effectiveness could be enhanced. Document Control Systems, Procedures, Forms and Templates 2
K Creative Ways to Communicate Customer Complaints to Manufacturing. Customer Complaints 10
Y Perform 2 ways ANOVA in minitab with non normal data involved Using Minitab Software 5
T "Creative" ways to handle Early Production Containment Misc. Quality Assurance and Business Systems Related Topics 9
A How many ways do you classify your scrap? Quality Tools, Improvement and Analysis 15
apestate Vibration, Measurement and Isolation - Good ways to isolate M&TE from vibration? General Measurement Device and Calibration Topics 9
A Sampling Plans and Cpk - Ways to Calculate the Sample Quantity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
R Looking for Advice on ways to collect Inspection Data Electronically Quality Assurance and Compliance Software Tools and Solutions 7
B 20 Ways To Annoy Your Public Bathroom Stallmate Funny Stuff - Jokes and Humour 7
K Inspection: Looking for ways to check 10 x 20 foot "checking aid" mylars Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Training to ISO 14001 - Effective ways to get the ISO information across to trainees Miscellaneous Environmental Standards and EMS Related Discussions 38
J ROI NPV HRV DIF or payback time? Ways to calculate cost benefit analysis Misc. Quality Assurance and Business Systems Related Topics 11
K Seeking Guidance on the most effective items and ways to Benchmark Preventive Action and Continuous Improvement 4
