Which parameters to be addressed in Control Plan from FMEA?
rcm_mech
Hi friends ...:cool:
I am confused about parameters to be addresed in control plan from process FMEA ?
I mean to say that while perparing the new process FMEA for new product ,we make FMEA from data available such as current similar control methods for prevemtion & detection that are being used... ?
If such case, is it necessary to addressed that particular parameter in CONTROL PLAN which is PREVENTED by current various methods in process FMEA ?
I have heard that that number of parameters in CONTROL PLAN are to be less than numbers parameters in Process FMEA...or else ...?
plz highlight these points.
Thanks in advance.
qusys
In case of new product your approach is valid.
When you performed PFMEA, then you should consider RPN high for potential failure, you shall act on control for detection and prevention and then reflect this control in your control plan.
Successively, you re-consider FMEA analysis in case of return from field based upon customer complaints.:bigwave:
Thanks in advance.
The primary purpose of the PFMEA is to determine what gets controlled in production, and why. This means that there will often be characteristics of parts or processes that are considered in the PFMEA but don't appear on the control plan. The number line items in the PFMEA isn't always greater than the number of items in the control plan, but it can be.
D How should "Set-up" Parameters be Addressed in Control Plans? FMEA and Control Plans 1
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
B WEDM Taguchi and Anova Analysis - L16 array with 5 parameters at 4 levels Manufacturing and Related Processes 9
I Quality of Potable Water Testing Parameters during Purified Water Validation Qualification and Validation (including 21 CFR Part 11) 1
E IEC 60601-2-57 item 201.12.4.2 - Indication of parameters relevant to safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
M AS9100 D 8.3.4.1 a - Parameters to be recorded" - What is this asking for? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Insights on Transactional Ticket Audits such Parameters, Weighting Points, etc ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 11135 Monitoring Routine ETO Sterilisation Parameters Other Medical Device Related Standards 3
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
D minitab macro to pull access query with parameters Using Minitab Software 1
Roberticus MSA for gaging which specifies process parameters and 7.6.1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L How do you specify your receiving inspection parameters? Misc. Quality Assurance and Business Systems Related Topics 2
T What to do if parameters are found to be Outside of Control Limits Document Control Systems, Procedures, Forms and Templates 5
S Testing software-only device on hardware - What are the hardware parameters? Software Quality Assurance 6
0 Visualizing ranges of 3 parameters with 6 variables Quality Tools, Improvement and Analysis 5
M New Calibration Laboratory Set Up Measurement Parameters and Equipment General Measurement Device and Calibration Topics 4
P MSA requirements for Systems that Measure Process Parameters Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Problem with the Classification of the Process Parameters IATF 16949 - Automotive Quality Systems Standard 6
K Data Analysis of Milk Composition (Seven Parameters like Protein, Fat, Lactose, etc.) Using Minitab Software 18
R How to assess capability for parameters which has got either Min values or Max values Statistical Analysis Tools, Techniques and SPC 2
M The General Parameters of IQ, OQ & PQ - Depyrogenation Tunnels and Autoclaves General Measurement Device and Calibration Topics 2
A Comparing Effect of Process Parameters on Equipment Performance during Start Ups Statistical Analysis Tools, Techniques and SPC 3
A SPC for Metal Foundry Parameters like Metal Temperature, Sand Moisture Statistical Analysis Tools, Techniques and SPC 5
N Different Distribution Parameters when analyzing the same data in different ways Using Minitab Software 8
R Analysis of Welding Parameters - Can Taguchi methods provide equation? Using Minitab Software 11
V The approach/criteria of setting Acceptance Limits Method Validation Parameters Statistical Analysis Tools, Techniques and SPC 1
P General Parameters to Approve Supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
J Critical Process Parameters vs. Critical Performance Parameters - Definitions Qualification and Validation (including 21 CFR Part 11) 2
O Correlation of 2 Test Devices - 2 samples (13 parameters) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D Problems with DOE - Different levels in parameters of a full factorial experiment Using Minitab Software 1
M True Position of a Hole Capabilty - Appropriate parameters to use Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Equipment Parameters in Control Plan? IATF 16949 - Automotive Quality Systems Standard 4
V Process Parameters in Textile Lamination Manufacturing and Related Processes 2
D Subjective parameters and Quality costs - VDA 16 IATF 16949 - Automotive Quality Systems Standard 6
T Process Specifications and Control Parameters Document Control Systems, Procedures, Forms and Templates 4
W Surface Finish parameters - Mechanical stylus based testing of a cylindrical part Manufacturing and Related Processes 2
U Minitab Distribution Fitting 3 Parameters? Using Minitab Software 1
J Run Charts and Alternative Process Control Parameters Statistical Analysis Tools, Techniques and SPC 5
A Information About Benchmarking Parameters of Castings Used for Automobile Sector Benchmarking 2
A Is zero defects possible? We are dealing with 25 to 30 parameters Quality Tools, Improvement and Analysis 21
D Is the Equipment for Measuring Process Parameters covered by ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Process Performance Parameters for efficiency and effectiveness Manufacturing and Related Processes 1
O Clause 4.1 process - Is it necessary to map and identify performance parameters? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Quality Parameters for Service Industry - Call Centers Service Industry Specific Topics 3
A Process Measurement Parameters - Purchasing, design and production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Sample Sizes and A2, A3, B4, d2 Factor Parameters Statistical Analysis Tools, Techniques and SPC 4
