Which test should I use? Binary Y, Continuous X
A Dub
Hi!
Title should read Which test should I use? Binary Y, continuous X
First time poster - been working in quality for the last 4 years or so in a service environment so my Lean Six Sigma training and certification hasn't focused much on statistical analysis at all. I'm trying to read as much as I can and Minitab is helping me in the process become familiar with the options available.
One situation that arises very often in my business is we try and find out whether speeding up a process results in customers being more likely to purchase from us. Essentially we have a continuous X, the TAT, and a binary response Y which is accept or not accept business. This is the foundation for many improvement projects that we work on and that I coach.
I started looking into using binary logistic regression however received an error. * ERROR * = and arguments needed.
My data is simply C1 contains the Y response (won/loss), and C2 the X TAT. In the test window I select C1 as the response and C2 as the factor
If it helps my continuous data is non-normal
A couple of questions:
1. Am I using the right test?
2. Is there any reason I would be receiving an error from Minitab?
Thanks!
Re: Which test should I use? Binary Y, Continuous Y
It sounds like you are using the correct test. There error is most likely due to how the test was specified, or how the data were entered. If you attach that data, we can help.
Ajit Basrur Should calibration range of Oscilloscope cover the test ranges? General Measurement Device and Calibration Topics 8
T What Test Certificate should accompany supply of Cable XLPE/SWA/PVC 4CX150MM2 Document Control Systems, Procedures, Forms and Templates 2
P What should be documented for Qualitative Test results for the FDA? US Food and Drug Administration (FDA) 3
R If equipment is rated at 50/60Hz, which frequency should be selected for heating test IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
Ron Rompen SAE J1677 - 5.2 (Reverse Flattening Test) and how it should be carried out Various Other Specifications, Standards, and related Requirements 1
W Who should test products for conformity? ISO 13485:2016 - Medical Device Quality Management Systems 9
D Inspection for Process Approval - How many batches I should test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
H Determining if I should Test Material - Aluminum Castings Manufacturing and Related Processes 9
A Validation Testing - How many unit should I test prior to launch? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M What distribution should I expect a tensile strength test to fit? Statistical Analysis Tools, Techniques and SPC 10
apestate Job Shop Inspection and Test - Where should we establish inspections? Why? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
K Should QS/TS certified internal test/calibration labs be required to be ISO17025 ISO 17025 related Discussions 16
K ISO 17025 Method Validation and Verification for Test Lab ISO 17025 related Discussions 4
J IEC60601-1: HiPot Test Method for Internally Powered Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Disinfection: Test recommended ISO 13485:2016 - Medical Device Quality Management Systems 0
H Microbiology count test failure Other Medical Device Related Standards 1
S AMS 2769 - weekly frequency test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W Conducting an MSA Test on scales Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Lot Release Test and Certificate of Analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
John Broomfield Construction Inspection and Test Plan Misc. Quality Assurance and Business Systems Related Topics 5
Z COVID-19 Antigen Test Kit (Self-test) Registration in Peru Other Medical Device Regulations World-Wide 0
R GearBox Test Bench Calibration General Measurement Device and Calibration Topics 2
N 60601-2-34 Electrosurgery interference Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
F Self-test minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Regarding the validity of EMC & Safety test reports without NABL & ILAC-MRA mark. CE Marking (Conformité Européene) / CB Scheme 2
Z Implement methods of Round Robin test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D 62304 code review, unit test, integration test example IEC 62304 - Medical Device Software Life Cycle Processes 2
D DOD First Article Test Plan & Report Manufacturing and Related Processes 4
Stoic Details of Operational Qualification (OQ) test design for plastic extrusion processes, effect of material property noise, and GHTF/SG3/N99-10 US Medical Device Regulations 2
A Earth (ground) leakage current routine test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Audit & Agreements for "Test Laboratory" Supplier? US Medical Device Regulations 4
G Developing our custom test methods and test equipment US Medical Device Regulations 5
K Looking for a tape to perform cross hatch test on powder coating parts Reliability Analysis - Predictions, Testing and Standards 3
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
MaHoDie Summative Usability test Human Factors and Ergonomics in Engineering 2
A Calibration of spring loaded test fixture General Measurement Device and Calibration Topics 5
E Pressure vessels hydraulic test IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Spinal implant predicate device test results 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Statistical Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Ed Panek Looking for Test Resource General Measurement Device and Calibration Topics 1
R Microbiological test (USP61, USP62, USP71, ISO 11137.1, ISO11137.2) --- Testing flow chart Other Medical Device Related Standards 0
S Discussion on OBL and OEM test data for submission as per new EUMDR EU Medical Device Regulations 0
E Do I need test reports for all standards mentioned in my 510k application? Other Medical Device Related Standards 8
C DV/PV Test Part Storage IATF 16949 - Automotive Quality Systems Standard 9
R Statistical Methods for comparing test and reference product equivalence for quality attributes US Food and Drug Administration (FDA) 3
Vader22 5 Why RCA for failure to test Contingency Plan IATF 16949 - Automotive Quality Systems Standard 9
