Which type of study would be better for Solder Paste Height Measurement system
sowmya
Involved - Posts
Hello Experts,
We are contract manufacturers in EMS industry and we have a process called solder paste printing on the Printed circuit board.The process is we have a stencil (of defined thickness -4 to 6 mils) and paste is applied over it by automatic paste dispensing system. The height of paste is also measured by the Height measurement machine. We want to conduct MSA for it.
Which type of study would be better. Could anybody please advise?
The viscosity of the paste will change as time passes. so we need to do the study in short duration. Max. 1 hour.
Thanks in advance:thanx:
Sowmya
harrysons
Realistic Quality
Hello Experts,
Sowmya
Hi Sowmya
I think you look better the SPC system... so you can find the Cpk on it..
hope it can help. or may others expert can share better study you are looking for.
Rgds,
Harry
sowmya
Involved - Posts
It is not AOI harry. A laser beam is passed across the board and wherever the paste is there, the beam shifts littlebit and the shift is measured by the machine.
The machine is caltex SPM-300
http :// www. caltexsci.com/solder_paste_measurement.htm - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS
Sowmya
bobdoering
Stop X-bar/R Madness!!
I would collect 10 boards, measure the solder height on the same location for all 10 three times. If the paste is degrading over time, have one operator measure, then the next, then the final, then go back to the first operator for the second trial. If there is any operator intervention (which I doubt, but wouldn't hurt to prove) have two other operators perform the measurement. Pretty much a standard gage R&R. Now, that is only one facet of a full MSA. You still need to look at calibration, including linearity and stability. I am guessing your question was primarily Gage R&R, though.
E
e006823
A lot of variables can effect the solder volume, paste viscosity, stencil thickness, aperture size, snap off height, squeegee wear, pressure,hardness, print speed and flatness of the PWBs to name a few.
I would treat this the same as I would a MSA on a destructive measurement (e.g. pull strength).
There's a good article here:
Industrial and Systems Engineering | P.C. Rossin College of Engineering & Applied Science
and the Non-Replicable Study article here:
Aiag Gage R R PDF | Download Free Ebook Aiag Gage R R
and this might be helpful:
http :// www. cyberoptics.com/client_files/documents/SE300_Gr_r_TV.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS
bobdoering
I agree, and the gage R&R specimens should be representative of as many of those conditions to ensure the gage can detect the variation. That may require more than 10 samples - and if so, that is OK.
I disagree, the measurement itself is not destructive. Each specimen can be measured more than once.
http ://www. lehigh.edu/ise/documents/99t_007.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS
This is a good article. They do not treat it as destructive. They do over think the issue, as one would expect them to do in an academic article. They measure everything about the volume of the solder paste. Does the OP need to know all of these factors - or just the height?
Bob has it exactly. this isn't a destruct test; it's a straightforward R&R study.
I would recommend an alternative sample structure: 30 boards, measured twice each by 2-3 operators. It's the same number of measurements, but there is more statistical - and informative - horsepower in measuring more parts twice than in measuring fewer parts 3 times...
E
e006823
Agreed.
My comment was based on past experience supporting a PWB assembly line. Operations didn't want any boards "laying around" or non production related experiments tying up production assets. As a work around we decided to treat this as a destructive MSA. Samples measured once and then continue through the manufacturing process. It was an effective compromise.
This may have no bearing on the OPs operating environment or production needs
bobdoering
I agree, that would be better than just 10 boards (just didn't want to be greedy).
But be sure it is the same pad location on each of the boards. As the article states, there can be a lot of variation and I suggest you just want to capture the variation limited to one location and it's particular effects. The rest of the variation issues across the board are the realm of the process capability study, not a gage study. Need to keep them separate.
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
W Using MPE (Mean Percentage Error) for Linearity and Type-1 study Measurement Uncertainty (MU) 1
E Bias and Type 1 Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P What is a Type 3 Gage Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
H Type 1 Gage Study Interpretation Question Using Minitab Software 7
S Minitab: Type 1 Gage Study vs. Gage R&R Study Using Minitab Software 5
B NDC relates which type of MSA Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
M Type 1 Gage Study - What's your opinion on this gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Ford MSA - Ford TYPE 1 study on a Marposs post process gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Type 1 Gage Study Excel Template Excel .xls Spreadsheet Templates and Tools 5
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Are EC type examinations still being conducted under MDR? EU Medical Device Regulations 5
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Marcel DS GOST-R (Type approval for Vehicles in Russia) Other ISO and International Standards and European Regulations 0
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
P Surgical masks ( type IIR) - Cleanroom Requirements EU Medical Device Regulations 3
W Insulation requirements of BF type infant skin temperature probe IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
N Infant radiant warmer - Heater Quartz Element type Other Medical Device Related Standards 0
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
M SI #7 8.4.2.1 Type and extent of control_supplemental IATF 16949 - Automotive Quality Systems Standard 3
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
K F-TYPE APPLIED PART IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
I AS9100 8.4.2 Type and Extent of Control - External provider test reports Manufacturing and Related Processes 24
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
R In this type of Legal Manufacturer-CMO arrangement, what happens to the DHR? ISO 13485:2016 - Medical Device Quality Management Systems 1
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
T Type BF or CF (Direct conductive contact with the heart) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P IVDD - IFU related requirements - Type of information/statement expected EU Medical Device Regulations 1
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
P Definition Business Type - Definition of what we do-Business Type Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
L Valid reasons to omit an "ear-tag" type label on a cable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P 2x MOOP for type B AP - Therapeutic device - Heater/cooler with pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
