Who can perform ISO 9001:2008 Internal Audit prior to our Registration Audit?
L
Lincole
Hi guys,
I am the Quality Control Manager of the company, and we are at the internal audit stage before we can submit our manual to the API agent.
Here's my question, can I conduct an internal audit to audit the company? Or do I have to find someone else to do it? (I assume "internal" means within the company audition, and if finding someone else then it's consider as "external").:thanx:
mguilbert
Re: ISO 9001:2008 Internal Audit
1) You can perform your own internal audits. You will just need someone else (other than you) to audit the internal audit process,
2) You do not need to have an external party perform your internal audits. According to a statement made by our CB auditor, you can have a third party as your internal.
Hope this helps.
John Broomfield
Lincole,
Now that you have an internal audit programme (driven by top management's objectives) you should arrange auditing to execute the programme.
You can be the auditor to invoke any necessary corrective action and to report on the status of the management system to management.
If your management system has evidence of your competence and you avoid auditing your own work, your audits will also count as part of the management system's audit record.
John
qusys
Hi guys,
You should have formalized the internal audit program , supported by top management. To perform the internal audit you should be competent and not audit your own job.
"Internal" is referred do the company and not on the resources that you used for auditing. You should also "outsource" the internal audit to a consultancy organization . It will performed the internal audit for you as well, but you shall control it.
At the end of the story you can have a double choice. An advice could be to have a group of internal auditors ( competent and and trained), so that you can have the opportunity to share ideas and knowledge among more personnel and not concentrate the job in unique hands.
inspector625
Can I ask a question on top of a question? I am doing our internal audits here as well. My question is whether our manufacturing lead hand can audit my departments if I in turn report to him? Is this a conflict? :confused:
The simple answer to your question is, yes, you can - the only requirement is that you don't "audit your own work". Since you aren't actually supposed to audit people, as you are auditing process(es) there shouldn't BE a conflict. Now, of course, the other parts of the standard come into play where it talks about the audit process being free from bias etc. If, as personalities, you believe there could be some loss of objectivity or even a bias going in to the audit, then you should also consider that. The real issue here is that of "independence", which isn't being from another department, but being free of bias etc.:agree1:
I
ISO911
Do you have anyone who has gone through an auditing program such as ASQ or AQS and has received an auditing certificate? IF not do you have some type of auditor training program in place internally or have someone within the facility who has been trained to audit to a standard. In your case it would be ISO 9000. As long as you can show the person auditing has the verifiable knowledge to conduct an ISO 9000 compliant audit you are good. Even if your auditors were trained while working for another company they can still perform the audit there as long as you can prove they are qualified. Remember, it's not what you know, it's what you can prove you know in the eyes of "The ISO"
Hope this helped,
ISO911
Hope this helped,
ISO911
Hello and welcome! In actual fact, all that's needed is a competent auditor. As you say, they may have brought some experience from another company. Training isn't a requirement, however,neither is "qualification. Generally, training - however it was given - is just one part. Think of the training taken by new drivers. It's just makes them a little less scary on the road, really.
And I'm not sure what you mean by the "eyes of the ISO"... We're really talking about making sure management get an accurate report on their management system. "ISO" doesn't have anything to do with it.
Reg Morrison
We would not let an incompetent machinist touch a lathe. We would not allow an incompetent engineer develop a product design, etc. but we have no problems allowing incompetent internal auditors making a mockery of the function. A certificate does not make anyone qualified nor competent. Attending a class, either. Why? Because for most organizations, internal audits are inconsequential events, waste of time and effort.
Competence, not qualification, not certification, not training is what the 9001 document requires.
L Tasked to perform a gap analysis between APQP and ISO 9001:2000 requirements APQP and PPAP 1
Crusader Internal Auditing to ISO 9001 - How to schedule/plan and perform an ISO audit Internal Auditing 31
chris1price Is there a regulatory (MDD, MDR, FDA, ISO, etc) requirement to perform a mock recall? CE Marking (Conformité Européene) / CB Scheme 4
E Should companies that perform calibration services be ISO 17025 accredited? ISO 17025 related Discussions 13
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
H Finding an ISO 17025 accredited laboratory to perform calibration ISO 17025 related Discussions 14
R ISO Registrar Using Quality Authors to perform periodical or recertification audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
P Can I perform an ISO 13485 audit? I'm a registered RABQSA QMS and AS9100 Auditor ISO 13485:2016 - Medical Device Quality Management Systems 3
O I am looking for a US laboratory that can perform ISO 1628-4 testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S How many CBs have been accredited to perform ISO 13485:2003? ISO 13485:2016 - Medical Device Quality Management Systems 25
A ISO 14001 Clause 4.5.4 - Internal Audit - Must a company perform internal audits? ISO 14001:2015 Specific Discussions 5
M Must a company be 17025 accredited to perform internal calibrations? ISO 17025 related Discussions 7
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 7
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
M Informational How to perform a clinical evaluation of medical devices – Part 1 – Overview and sample of activities Medical Device and FDA Regulations and Standards News 0
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Perform a coating weight test within 3 hours of processing the parts Manufacturing and Related Processes 2
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
J Internal Audit clarification - How to perform the audits IATF 16949 - Automotive Quality Systems Standard 6
S When will notified bodies be ready to perform audit to the MDR? EU Medical Device Regulations 1
P Can CEO perform internal audit Internal Auditing 11
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
W DCMA and AS9100C - Dedicating a week and 5 auditors to perform a AS9100C audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
W How to perform validation for an epoxy curing station Manufacturing and Related Processes 3
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
E How do you perform a GR&R for system software generated values? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Do I need to perform Gage R&R on a Digital Temperature & Humidity Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
R Registrars offering to perform Second Party Audits - Have they failed their role? Registrars and Notified Bodies 112
M How to perform Chelex DNA Method Verification in the lab General Measurement Device and Calibration Topics 2
V Is it required to perform Process Validation for food or dietary supplements? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
R How do you perform verification of a NCR (Nonconformance)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Hiring an External Auditor to perform our AS9100 Compliance Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
A Do we need to perform Qualification and Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J How do you perform a S3 Stability Study for a Non-Replicable Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Do we need to perform Analytical Method Validation upon Relocation? General Measurement Device and Calibration Topics 5
