Who does most of your inspection - QC or Production
How is Inspection Handled in Your Company
  • Production does it - Quality just reviews and Audits Production
    Votes: 14 23.3%
  • Production Does most - Quality helps with tough stuff and PPAP's
    Votes: 17 28.3%
  • Production does some - Quality does most Inspections
    Votes: 24 40.0%
  • I'm not even sure production knows how to measure!!
    Votes: 5 8.3%
  • Total voters
    60
Q
QualityNo1
#31
In our company (we make filtration systems) Production are responsible for production quality issues and also product quality. We do have a QCI in the factory to assist in resolving some of the 'fine line' issues where required.
Quality carry out goods inwards inspection only on the more complex components and final inspection, with production, on ready to go products.
Caster
An Early Cover
#32
Was going to say the same thing. Quality Control/Quality Assurance aren't even a part of the vocabulary. We do a lot of checking and inspecting but that is 100% a "everybody in production" responsibility.
Sounds like Deming would approve - are you hiring?
ducsuong
#33
In my factories, the production operators do most of our inspection in all of processes. QC only check or test some input materials and final products
W
Willem
#35
In our company each artisan/operator must check his own work. Once all parts are manufactured it will go to the in-line inspector for final inspection before it goes thru to assembly and teting. Our manual says that each artisan is responsible for his work done and after the parts are manufactured he needs to sign of the "Work In Progress" Job Card. By signing of the WIP he agrees that the parts as checked with calibrated instruments. :magic:
Q
qualitytrec
#36
I am not sure production knows how to measure agood part vs bad part. But I have been throwing a major hissy fit for about 6 months and the managers are starting to agree that their people should own quality. Now we have to train and better define what quality is for our product.
Mark Smith
P
Pazuzu - 2009
#38
At our facility, if:
  • the parts are repeat and common then production is responsible.
  • the part is brand new then production inspects through the process and QA (me) will perform a FAIR on the final part.
  • the part is extremely complex then production has stage gates in which a specified team is called to the floor to ensure everything is as expected before moving to the next process.
U
unclemook
#39
Hi Willem, Pretty much is what we do as well, We get ownership of the quality of their work when they sign off on the job workorder traveler. We use a final test dept to validate the requirements. You say "artisan" what is the work that they do? I ask 'cause we have a glass shop that employ's glass blowers. This to is what we call artisans[
:bigwave: mikey
QUOTE=Willem;215833]In our company each artisan/operator must check his own work. Once all parts are manufactured it will go to the in-line inspector for final inspection before it goes thru to assembly and teting. Our manual says that each artisan is responsible for his work done and after the parts are manufactured he needs to sign of the "Work In Progress" Job Card. By signing of the WIP he agrees that the parts as checked with calibrated instruments. :magic:[/QUOTE]
W
Willem
#40
You say "artisan" what is the work that they do? I ask 'cause we have a glass shop that employ's glass blowers. This to is what we call artisans:
[/QUOTE]
In our case it is a person that is a qualified fitter & turner. On our side they work on a conventional lathe, boring mill etc and turn parts from raw material.
Regards:cool:
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Does 21 CFR 820.80 (b) require a Supplier to have Receiving Inspection? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
K Does FMEA include Inspection Process? FMEA and Control Plans 11
E Blade Inspection - Does anyone use blade scaning software for a CMM or laser scanner? Design and Development of Products and Processes 3
L 8.2.4.2 First Article Inspection - Does every new part that is run require a FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
M Accuracy of Inspection Equipment - How precise does the measurment device need to be? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Does TS 16949 require inspection? Imported parts IATF 16949 - Automotive Quality Systems Standard 9
G Is 100% Inspection a Control or does a Process need another type of control? FMEA and Control Plans 9
R Construction: Does new Inspection and Measurement Equipment require calibration? General Measurement Device and Calibration Topics 22
J Receiving Inspection - Does anyone have a procedure they would be willing to share? Document Control Systems, Procedures, Forms and Templates 9
J Does GM require an Inspection Standard in the APQP process? APQP and PPAP 3
B Process FMEA Scope - Does PFMEA cover Incoming (Receiving) Inspection & Dock Audit? FMEA and Control Plans 8
J Final Inspections - Does 100% inspection really work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 4
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
