Who has had to move from ISO 9001:2015 to ISO 13485 and what were the challenges?
ISO_Man
Apparently there are some possible changes on the horizon which would make hand-held medical devices class 2 instead of class 3 which would allow FDA audits of suppliers for the parts. So if I have to move my company from ISO-9001:2015 compliance to ISO-13485 compliance what are the major challenges and can anyone suggest some good documentation on the topic so I don't have to buy the ISO-13485 standard yet?
yodon
Not sure how accurate your information is. First, FDA doesn't recognize 13485 (yet). Second, I don't see how downgrading a device to a lower class would prompt for FDA inspections ("audits") of a supplier. Third, "hand-held" devices can be in any class - depends on a number of factors but mostly risk.
All that aside, if you're not the legal manufacturer, the leap from 9001 to 13845 won't be that big. Much of the device-specific things will likely be not applicable to you. You also don't have all that "context of the organization" stuff from 9001.
Irrespective of the argument about the necessity to switch, you might want to consider holding both 9001 and 13485. It's a little more work and a little longer audit time but it might give you a competitive advantage.
This is something that is probably in our future as well. What would you define as the "legal manufacturer"? The manufacturer that delivers the final end component?
Mikilk
I would not say it is that easy and not sure if it can be considered "moving" or "Upgrade" as ISO 9001:2015 version is different than the concept of ISO 13485:2016 version. ISO 9001:2015 changes to a new structure different from ISO 13485: 2016.
ISO 13485 is not formally accepted by the FDA but the FDA's QSR is more close to ISO 13485.
I assume comparison matrixes can be found on the web, same as to abstracts / plain text of ISO 13485, but I disagree with my friends here that say it is easy to implement. It is a significant change and held different approach
as the responsible entity of medical device - you much meet all FDA requirements and if the GMP is part of it (not exempt), you should implement it in full without any further delays, and by doing that it will be worth to implement the ISO 13485 standard.
yodon
...as the responsible entity of medical device...
Maybe I was mistaken but I understood the OP to indicate they were a supplier, not the legal manufacturer. In this case, much of the uniqueness in 13485 is reduced.
I think going from 13485 to 9001 would be a bigger leap for a company than going from 9001 to 13485 for just the reason you mentioned (different structure).
ISO_Man
Maybe I got the numbers reversed but it's the re-classification of medical devices that makes me consider the 13485 since the FDA can just close the doors on me as a supplier for parts that go into medical devices if they find a major non-conformance during an audit.
Al Rosen
If your concern is FDA compliance look at CFR - Code of Federal Regulations Title 21 to see how it might affect you. You can integrate it into your current system without the additional costs associated with ISO 13485 registration.
J How to keep MDD certificate valid when legal manufacturer has liquidity problem EU Medical Device Regulations 0
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
Louddogsbark When your 13485:2016 certificate has been pulled ISO 13485:2016 - Medical Device Quality Management Systems 2
lanley liao What shoud i do if our company top management has been changed. Oil and Gas Industry Standards and Regulations 8
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
S Has anybody done IMS - Management Review Meeting ISO 14001:2015 Specific Discussions 8
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 15
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Z 510(k) usage - Company has 2 physically similar products Medical Device and FDA Regulations and Standards News 2
D Has anyone had sudden challenges from Korea-MFDS? Other Medical Device Regulations World-Wide 1
Sidney Vianna IAQG News IAQG has a new website - December 2019 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Richard Regalado ISO 22301:2019 has been published - Nov 2019 Business Continuity & Resiliency Planning (BCRP) 0
S FAIR - If we have not produced a part in over 2 years, but nothing has changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Nicole Desouza Who has to be compliant with REACH Declarations? REACH and RoHS Conversations 11
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Would an MRP system that has been in use for over 10 years require validation? ISO 13485:2016 - Medical Device Quality Management Systems 6
W Informational VDI 2017 - Medical Grade Plastics - German VDI has published a "Richtlinie" Other Medical Device Related Standards 1
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Has anyone heard of the 2 pan system? Manufacturing and Related Processes 6
N Technical File Reviewer has requested more testing to ISO 10993 Other Medical Device Related Standards 10
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
M Has anyone here assessed the latest Abbreviated 510(K) guidance document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
Sidney Vianna Informational UTC ASQR Rev.11 has a mistake; certification of distributors to IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
lilybef FDA and Biocompatability Testing - Reviewer has requested implantation testing Other Medical Device Related Standards 11
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
Sidney Vianna LinkedIn bug - Anyone has any idea of how to fix this? Posts not showing for me in a Group feed. Coffee Break and Water Cooler Discussions 2
M FDA News FDA Report - FDA Has Taken Steps to Strengthen The 510(k) Program Other US Medical Device Regulations 0
C Has an amended version of IEC 60601-1-6 TRF been released for use in conjunction with IEC62366-1:2015? Human Factors and Ergonomics in Engineering 0
planB ISO 10993-1:2018 has just been published Other Medical Device Related Standards 2
S ISO 13485 Consultant Question - The company has 5 part time employees ISO 13485:2016 - Medical Device Quality Management Systems 1
K Has anyone used QAI for training? Training - Internal, External, Online and Distance Learning 7
Q MHRA has released a new guidance document related to 'GXP' Data Integrity EU Medical Device Regulations 3
B FDA Philippines has no check or balance outside the health department Supplier Quality Assurance and other Supplier Issues 3
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
D Has anyone here had any experience with PQ-FMEA software? FMEA and Control Plans 1
P NPR Metric - What if Customer has relaxed measure? TL 9000 Telecommunications Standard and QuEST 1
D EU Harmonized Standards to which a company has declared compliance EU Medical Device Regulations 13
N Customer Survey Question Has Me Stumped - Compliance with Laws and Regulations Customer and Company Specific Requirements 4
B Records Destroyed - Hurricane Harvey has likely destroyed our Quality Systems Records Records and Data - Quality, Legal and Other Evidence 10
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
B Procedure Pack - KIT - Each has its own CE Mark CE Marking (Conformité Européene) / CB Scheme 6
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
