Who is responsible to initiate a Supplier Corrective Action?
U
useridpain
Who is responsible to initiate a Supplier Corrective Action when a non conformance is found?
howste
Thaumaturge
Re: Supplier Corrective Action
You're not providing much detail. There is no single answer to your question that will apply in all situations.
How was the nonconformity found?
Do you have a company policy/procedure about supplier management and such issues?
Who has done this in the past in your organization?
U
useridpain
Nonconformity is found at in coming inspection.
Yes, there is a procedure. Seems like it is not followed and the expectation is that someone "in quality" is responsible.
In the past and currently it might be initiated by incoming inspection, or it might be initiated by the Project Manager, or it might be initiated by the Quality Systems Coordinator, or it might get passed to the Supplier Quality Coordinator.
My understanding, in my previous job, was that the person who found the non conformance would initiate the SCAR since they have first hand understanding of what the requirement is (hardness for instance) and how the part does not meet the requirement.
RoxaneB
Change Agent and Data Storyteller
There is no correct answer to this question. What works for one organization may not work for another.
The person who discovers the nonconformance could be an operator or an hourly inspector, and perhaps is not in a position to work with the supplier. Still, they should have the authority (and responsibility) to identify the nonconformance to an individual who can work with the supplier for resolution.
This individual could be quality or could be purchasing or could be receiving...again, there is no RIGHT individual for this as long as it is done.
In my own experience, however, I like to leave with Receiving (which was often a sub-department of Purchasing). Why? Because they're in the trenches...they're the ones doing the job and recording the results. That said, in my experience, Receiving then brings the results of supplier conformance (or lack thereof) to Purchasing so that supplier evaluation AND negotiations can be done with the necessary information at hand.
N
ncwalker
So here is a little bit of a rant and hopefully something to make you think....
First the rant: Someone in receiving inspection finds a problem. And the feeling is that "someone in quality" is then responsible. For writing it up.
Definitely "someone in quality" needs to FOLLOW the issue and ensure corrective actions make sense and all your procedures, whatever they may be, are met. But let us talk about writing it up ....
Does the person in receiving inspection NOT communicate the issue to the quality department? How does this communication happen?
Now, go download an 8D. Heck, download 5 different ones. And look at steps 1 through 3 of an 8D. This is what we expect our suppliers to give back to us, but really look at steps 1 through 3. A LOT of information in these steps must come from the customer, the receiver of the bad part. Simply because the supplier doesn't know it. Heck, just consider "description of the problem."
Now think about this - we all look at our "lean" efforts. And we all know that double handling product = a very bad thing. It's wasteful.
How about double handling data? Think about it. Why would I email you, my supplier, a problem and then want you to transcribe my problem onto an 8D? That's double handling the data. Why don't I fill out an 8D for you with the stuff I know, send you this, and have you fill in YOUR part of it?
And ... that's my suggestion.
When your receiving inspection has a problem, the notification to YOU should be a partial 8D. Not an email. Not a problem report. The portion of an 8D they know - what is the problem and what's the details (how large is the hole, the hardness was to by X and it is Y, here's a picture of the broken part, etc, etc, etc) Then, you can fill in more of it (containment, how many parts you have, etc) and send it to the supplier to fill his portion.
If people are complaining about filling it out. Saints on Bikes, they are either typing it or writing it anyway to tell you. Doing the exact same work but "containerizing" it on an 8D isn't more work, it's new habits. That are lean, eliminating double handling. There is no reason not to.
P
PaulJSmith
Then, this is how is should be handled, ideally. Follow the procedure.
So, here is an opportunity to flush out the aforementioned procedure. Why is it not followed? Is it wrong? Has it evolved over time? Either your company is not following its own procedures, or they are not up-to-date. This is a wonderful opportunity for your Quality department to shine, and fix this.
There is a question bigger than "Who does it?"
That is, "Why doesn't anyone/everyone know who does it?"
Sidney Vianna
Post Responsibly
Once a nonconforming product is discovered, it has to be dispositioned (e.g., though a Material Review Board MRB team). Most organizations have an established process to accomplish that, and, in some cases, it involves a cross functional team.
Keep in mind that, SOMETIMES, the nonconforming situation is NOT the supplier's fault. So, it would make no sense to request a SCAR when the supplier did no wrong. When and if the MRB team decides an SCAR is justified, than the process should clarify who is responsible to communicate with the supplier. Most of the organizations I know of require someone in purchasing to be the primary point of contact with the supplier. For technical reasons, typically people in quality and engineering will assist purchasing when dialoguing with the supplier's rep.
by the way, from an ISO 9001:2015 perspective, if people don't know who is responsible for this important aspect of a QMS, top management failed to comply with the first paragraph of 5.3:
Top management shall ensure that the responsibilities and authorities for relevant roles are assigned, communicated and understood within the organization
Risky. Based. Not thinking.
randomname
Technically, whoever your procedure designates.
Ideally, Purchasing. After all they're the primary contact with suppliers.
RoxaneB
Depending on the size of the organization, a Material Review Board may not exist...and not all incoming nonconformances are related to the actual product (i.e., sometimes it's the paperwork, such as an incorrect certificate, that is the issue). Still, the nature of possible nonconformances, associated disposition measures, and those responsible for following through on the disposition measures (and corrective measures) should be identified. In my experience, this is done through a controlled document, easily read if in matrix form.
T Who's responsible for verification of customer specifications? IATF 16949 - Automotive Quality Systems Standard 17
K Process FMEA responsible For "Make to Design Parts" (Inhouse or Suppliers ?) FMEA and Control Plans 3
S Training for PRRC (person responsible for regulatory compliance) EU Medical Device Regulations 3
S Changing UK Responsible Person UK Medical Device Regulations 0
J Quick question on responsible person's experience requirements UK Medical Device Regulations 3
qualprod Can a consultant be audited instead of QMS responsible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
chris1price Notified Body responsible for product safety under MDD? EU Medical Device Regulations 4
M Brand owner or manufacturer responsible for Basic UDI-DI and UDI-DI? EU Medical Device Regulations 8
N UK Responsible Person - Termination UK Medical Device Regulations 2
E MDR PRRC "jointly responsible" EU Medical Device Regulations 1
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
F UDI Registration - Who is responsible for Registration of the Device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
J Management Representative and PRRC (Person Responsible for Regulatory Compliance) ISO 13485:2016 - Medical Device Quality Management Systems 12
P MDR PRRC (person responsible for regulatory compliance) and personal liability EU Medical Device Regulations 3
E Company A supplies pharmaceuticals to the MOI - Who is responsible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Informational Update from GOV.UK – Regulating medical devices in the event of a no-deal Brexit – UK Responsible Person Medical Device and FDA Regulations and Standards News 0
dgrainger MHRA - Creation of new UK Responsible Person section with added content. Medical Device and FDA Regulations and Standards News 0
K Does company who manufacture but does not design or carry out clinical trials is responsible for CE marking for single use medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 4
K Packaging and Damaged Parts returned from a Service Provider (Anodize) - Who is Responsible? Manufacturing and Related Processes 20
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
C Advice on becoming a AS9100 Auditor - Need to audit organizations that are Design Responsible AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
C Person Responsible for Regulatory Compliance - The RA guy/girl Employment Act EU Medical Device Regulations 4
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
I Who is responsible for signing the Declaration of Conformity and what is their liability Imported Legacy Blogs 0
D Responsible for regulatory compliance (Article 15 of MDR 2017/745) Quality Manager and Management Related Issues 4
M Prescription Devices - Who is Responsible / Liable? Other US Medical Device Regulations 9
J Not Design Responsible - Can we exclude all or parts of AS9100 clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Functional group / area responsible on a Control Plan IATF 16949 - Automotive Quality Systems Standard 1
A Selling our own class 1 (EU) devices worldwide - Who is responsible for registration? Other Medical Device Regulations World-Wide 7
Jen Kirley Shared responsibilities in Responsible Care 14001 ISO 14001:2015 Specific Discussions 2
insect warfare New home for the R2 (Responsible Recycling) standard Miscellaneous Environmental Standards and EMS Related Discussions 2
H Different Plants responsible for different parts of the TS16949 Standard IATF 16949 - Automotive Quality Systems Standard 4
Ninja Blind Gopher Auditors Comment - Who is responsible? Registrars and Notified Bodies 23
insect warfare New R2:2013 (Responsible Recycling) Standard has been Released Miscellaneous Environmental Standards and EMS Related Discussions 6
N Who is responsible for conducting Root Cause investigation? Problem Solving, Root Cause Fault and Failure Analysis 8
M Corrective Action not being done by the responsible person Misc. Quality Assurance and Business Systems Related Topics 5
M Design & Development - Only 1 Engineer - Who is responsible for Approval? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Should HR Job Titles match Procedure Responsible names? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Integrating ISO 14001 and EPA Responsible Recycling (R2) ISO 14001:2015 Specific Discussions 4
Q Definition Design Responsible - Good Definition in the context of AS 9100 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
Q Assigning Responsibilities - Responsible Department or positions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Design History File Maintenance - Who is responsible for the Design History File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
V Where to get NAID and EPA Responsible Recycling Certification Training? Training - Internal, External, Online and Distance Learning 7
B Who is responsible for Translation Compliance EU Medical Device Regulations 6
T Does person responsible for standard have to be the Managment Representative? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Who is responsible, the department head or people under him? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
E Who is responsible for RoHS Declaration? RoHS, REACH, ELV, IMDS and Restricted Substances 3
B Who is responsible for cleaning medical devices before return for repairs? Other US Medical Device Regulations 13
K Which Department or Process is Responsible for Leading the PPAP Process? APQP and PPAP 3
