Who should define and own the Design and Development Plan and how to maintain the updates and revisions.
v9991
1. per my understanding, it should be owned by "project / program manager", and shall be defined in consultation with the key stakeholders ( viz., technical lead and regulatory etc); also certain references.,
https://alvintai.com/wp-content/uploads/2015/01/Design-Control-SOP.docx
2. as these documents are alive and evolve with the product development, there are two options
a. to revise and version them through the life cycle. ( with appropriate change management/controls from set stage viz., D.Input can be updated without change control till Design Verification Plan; but any changes later should be put through formal change control)
b. to update through addendums, and integrate the details at a set milestone viz., for D.Input, integrate before Design verification.
per my understanding, 2.a is right choice. as per FDA's guidance.
https://www.fda.gov/media/116573/download
Eventually, the design input must be reviewed for adequacy. After review and approval, the design input becomes a controlled document. All future changes will be subject to the change control procedures, as discussed in Section I (Design Changes)
pl guide with clarification and reference
yodon
There's nothing prescriptive about who should "own" (or even approve) the Design & Development Plan. Obviously it should be coordinated with applicable stakeholders and generally the project manager is probably in a good position to do so - so the project manager is probably a good choice but not required.
I got a little lost on your second question. The Design & Development Plan is independent from the other documents (e.g., Design Inputs). The Design & Development Plan should, indeed, be updated as the project progresses. The means for update are not specified. Once approved, though, updates should (per basic Document Control requirements) be approved by the same roles that approved the original (there are a few caveats but that's the gist).
The question of when to put things under change control is always a difficult one to answer. To me, design inputs provide the foundation for the rest of the work so I push for the initial baseline (approval) early. Changes to the Design Inputs always have a ripple effect and if those aren't managed well, you can end up in chaos. If you're informally modifying design inputs, you could end up with developers going in the wrong direction.
Ronen E
Problem Solver
Moderator
Maybe straying off topic, however -
I think control over changes (in contrast with "change control") goes without saying on pretty much everything once you go under Design Control, which is normally when "research", "feasibility", "proof of concept", "market probing" and all that jazz ends (there should be a formal, documented cut-off). I couldn't agree more about Design Input changes. The really hard question (and one a lot of orgs are pondering) is when to start applying the regulatory element "Design Change", i.e. when to start applying the Design Change SOP or WI.
The approach I usually follow is: after the successful conclusion of the first Design Verification round (i.e. after its Design Review). If that round is unsuccessful (i.e. some design elements need changing, including possibly some design inputs) the design should still be considered "liquid", and the initial design development controls should suffice. I think this is important, so as to not over-encumber the initial design/engineering work with processes that consume resources, slow down progress and add little value overall.
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
T How should I define a process-The use of the Active Voice Process Maps, Process Mapping and Turtle Diagrams 14
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
