Whose fault is it? Our quality department gets blamed for anything!
  • Thread starter Thread starter nutzz
  • Start date Start date
N
nutzz
Hello All,
I need some help from all the wise members of the Cove. Our quality department gets blamed for anything and everything that goes wrong. We usually hear that "we should know better".
My question is.... how would you respond to this?
Any input would be helpful.
:thanx:
Dawn (nutzz)
Well, Dawn, it would help to have some examples, but I have some ideas initially.
If you have a QMS in place, and it includes corrective and preventive action, those should include who actually does the CA/PA - and most of the time it shouldn't be QA. If you have issues that are cropping up again and again, then there is a problem in how these have been approached/executed.
Also, you can address many issues as part of management review.
Finally, I really dislike the "finger pointing" approach to problem solving. Maybe using a structured approach is an option? What kind of support do you have from top management?
First, thank you very much for you help.
Unfortunately, it is upper management that is pointing the finger. We utilize CA/PA but how many can you issue before it just gets old?
Several examples of “we should know better”
1 Material shipped without being certified even though we issued a bench certification that was distributed to all parties involved.
2 Skids were moved out of the Quality HOLD FOR DISPOSITION which is clearly labeled in big bold letters and a neon orange sign stating the same is put in the traveling folder.
Ok, #1 sounds like a communication issue. Who gets copies of the certification/notice it has been issued? Make sure the one(s) squaking the loudest is(are) on the list. Answer any further complaints with "notification was sent via attached email(or other coorespondence) sent HH:MM:ss xx/xx/04" and make sure it is circulated at least 1 level above them. Make sure you document everything like the certification to those above you. It is just CYA good policy. Even if it is the top manager, it won't take too many embarassing "here-it-was-moments" for them to get the message.
When delivering the message, it is very important for you to mention that it is your usual procedure (once it has been) for the information to be delivered the way you sent it. Ask the "offended party" if the method of communication is not working, and if it is not, what better way would they suggest? Remember, it is your goal to inform, and the lack of communication is the issue here, not personalities. However, once it is seen that you are communicating, then pointing a finger at you, when they had the data all along, will be something they will want to avoid. Attack the communication problem. The people will likely take care of themselves. Just to be sure it is the problem you are attacking, not the people. Even if it is the top person.
Number 2. We use cheap plastic marking ribbon (marking tape), the type surveyors use, to wrap around suspect pallets. Cheap, quick, easy to see, and NO EXCUSE for moving it by unauthorized people. If the pallet checks out OK later, remove the tape (there is no adhesive on it) and ship the pallet out. We keep rolls of it around where the key people always have a roll when they need it. Make sure you outline who can put on/remove the tape.
Hope this helps.
Hi Dawn,
You're actually in a great position of changing gear and redefining your quality system and internal auditing strategy.
May I suggest you take a look at this link within the Cove forums:
https://elsmar.com/elsmarqualityforum/threads/7678/
I get the gist of your issues without you offering much more examples. It may indeed boil down to plain old training. Employees (Including myself) tend to do what we want if there are no system constraints put in place that, force us to look at the whole system as processes that are supported by procedures, that must be followed. Yeah, it sounds too simple, doesn't it? yet within many organizations that have a formal quality management system in place, they just do it the way it's happening at your location.
Take a look at what Ford use internally to enforce and measure task process capabilities. SQDCME: Safety, Quality, Delivery, Cost, Morale and Environment.
Also have a look at this thread too: https://elsmar.com/elsmarqualityforum/threads/7647&highlight=SQDCME
Hope this gets you off to a new start.
Wallace.
:thanks:
First off, thank you both Wallace and Craig for your help, I am indeed hoping to change the “mentality” (I use that term loosely) here. Unfortunately, it is the manager of our materials department that we seem to be having the most problems with. He just doesn’t get it. :confused: The tools that you have suggested look promising and I will be looking at how I can implement them here.
Thank you again,
Dawn
The key people in your organization are responsible for your system:
President
Quality Manager
Production Manager
From just what you say it sounds like your organization is more than likely production driven and quality is not everyones responsibility. I may be wrong but I have experienced this too some extent at previous employment. It will be a long battle but keep on pounding.
1. who is responsible for shipping and the certification?
2. who is responsible for the hold area?
Is everyone trained in their processes?
Make it Go Away!
Nutzz:
Since your senior management seems to think the quality group is to blame for human error, think about how to eliminate the human error. I always like the mistake proofing approach. We sometimes call it idiot proofing, as long as we don't offend anyone when we say it out loud! For example, Craig's suggestion to use the non-adhesive tape to wrap around the skids is a way to communicate to the "idiot" not to use this product. You need to come up with solutions to eliminate the possibility of human error.
As an example of mistake-proofing, think about the hand-pushed lawn mower. Recall that a while back, the manufacturers put on a safety bar. Once the mower starts, the user has to hold down the bar, or else the motor disengages. This was a mistake-proofing solution to help combat the "idiots" who turned over the mower while it was running in order to clear out something stuck under the mower.
How do you get there from here?? I like to flowchart the work process and then take each step in the flow and do something called a process activity diagram (picked it up in one of those classes from long ago). You can see a diagram in the attached file. Look at the Notes view. Then with a team of the people who know the process, you make process activity diagrams for all the process steps, and fill in the controls and the resources. Then you brainstorm all the possible ways that the controls could be used incorrectly -- and think of ways to make the controls mistake-proof. You can also look at the resources and think about ways to better prepare the human resources, or ways to make equipment less prone to human error when in use.
Yes, it's difficult work! If you want a more formal approach, FMEA can be used. Regardless, it's not quality's fault. Good luck!
--Jodi
Hi Dawn,
I like to believe that a Quality System is just a Business Operating System. That is, Quality is not something that is different or an add on to what great business already do.
Unfortunatly, I have some of the same issues that you do. And, I would guess that a majority of Quality Professionals have faced your situation at some time.
My suggestion is that through Internal Audits and Surviellance Audits you can only look at so much of the big picture at a time. Quality can only catch so many things each time. In our procedures, we specifically state that managers, directors, or even the president are responsible for the procedure, for training on the procedure, and making any revisions/additions etc. to the procedure. That way they can't blame QA. They have to blame themselves for not making the Quality System part of their job. Sure, the Quality Dept. is responsbile for helping the managers write effectivce procedures and work instructions, but it always comes back to management being responsible. Period.
Good Luck
It seems that your top management believes that the quality department should baby sit or, even worse, police the rest of the organization, based on the two scenarios that you just mentioned. If that is the case, and they can not understand that quality and customer satisfaction can only be economically achieved as a collective effort, I am sorry to tell you, but the situation is hopeless.
Try to make them understand the financial implications of people failing to follow the processes. For example, you could say that you will have a locked area for the skids waiting to be dispositioned, to minimize the chances of someone further processing the product that should be ON HOLD. But there are monetary consequences, besides disrupting the lay-out and process flow. And sure you can try to implement corrective and preventive actions to deal with the situation, but at the end of the day, it boils down to your top management true understanding of effective (quality) management processes.
A key word in any management system is accountability. Your department can not be held responsible for other’s lack of discipline.
