Why are type K and type E thermocouples not pemitted to be recalibrated ?
G
ggdjr
ams 2750D states that type K and type E t/c cannot be recalibrated after use over 500F
anyone know why that is?
or why type J and N need to be calibrated twice as often as the noble types (s,r,b)
thanks,
GD
Jerry Eldred
Re: Why are type K and type E not pemitted to be recalibrated ?
I am not at all familiar with the document you mentioned AMS 2750D). Could you tell me it's full title and who issued it?
Regarding Type K and E, Type K is rated to 2282 Deg F, and Type E is rated to 1652 Deg F. so I can't imagine why either of them could not be recalibrated after use over 500 Deg F. The only thing I could GUESS would be that because there likely is some drift in their emf (mV/Deg F or c), that some local policy may prescribe that to ensure they maintain some high level of accuracy (certainly more strict than their normal specs). Or... if this document prescribes use in some sort of caustic or oxidizing environment, perhaps there is evidence they degrade above that temperature in those more challenging environs.
Regarding why Type J or N have to be re-calibrated twice as often as B/R/S, the only guess I would have is the same as above. As J and N are lower max temperatures (similar to K), I don't understand why the interval would be shorter on them than on B/R/S T/C's. Matter of fact, many places don't even calibrate J/K/T/E (due to the lower temperature ranges, and drift being precipitated from oxidation and/or outgassing that occurs at higher temps). In the lab I used to work in, we had B and R on typically 6 month intervals; and replaced wire with new wire each six months (didn't use S - although its similar to R).
My thought would be J/K/T/E/N would likely be on at least 12 months (unless they are exposed to high temperatures). If exposed to high temperatures, I would gather and analyze some data as to drift rate versus calibrated spec, and assign an interval based on 2 or 3 sigma confidence of remaining in spec. Or even spec the interval based on hours and temps exposed to.
I would definitely like to see some data as to change in exposure to >500 F. I personally don't believe that is an extreme temp for J/K/T/E/N. However, if exposed to >500F for months, I could see that it might deteriorate.
G
ggdjr
jerry,
i was hoping you would help out.
the standard is Aerospace Material Specification 2750 Rev D. It involves Heat Treating of Steel, mostly, and the sensors/instrumentation/recording and monitoring systems that are involved.
It gives specs on life of sensors based on temp used, length of use at certain temps, and the cal intervals (if applicable)
thanks,
GD
G
ggdjr
an excerpt (in its infancy)for a seminar i'll be giving on these and related topics
i was hoping that some folkes here might know the 'why' behind some of these specs (besides self serving modes to drive more business)
- Calibration frequency:
- Recalibration after use above 500F for type K and type E are prohibited
- TUS and SAT T/Cs
- B, R, and S – before first use and after 6 months
- J and N – before first use and after 3 months
- others – not permitted
- Control, Recording and Monitoring T/Cs
- Before each use
- Load T/Cs
- B, R, and S – before each use and after 6 months
- Others – not permitted
Jerry Eldred
Based on the statements below, and considering the nature of the application, my GUESS would be that this is somehow based on a high reliability requirement. It is definitely true that all thermocouples age when exposed to high temperatures. The relative impact of that aging is a factor of the
a. thermocouple type (i.e.: what metal alloys are used in the thermocouple)
b. maximum temperature exposure
c. exposure time.
After reading your quote below, it does make a little more sense. The noble T/C's (B/R/S) all have the longest interval (which matches that seen in the semiconductor industry; although I can't actually cite anything for proprietary reasons).
The base metal thermocouples have shorter max intervals. However, in normal, knowledgable use, base metal T/C's are used at MUCH lower temps and are more stable (at those lower temps) for longer. It almost seems they expect the T/C's to all be used at the same max temps.
If it were me, I would definitely HAVE to presume these numbers are based on a combination of application and collected reliability data. If I were nit-picking, I might even disagree with the policy about B (as I am somewhat an "Anti-Type-B" person: in my recent thread I detailed how my experimental work on B T/C's showed they have an unpredictable decay in emf after long term high temp exposure (become non-linear across their operating range as well as decayed).
It appears this is a known set of factors for this application, and (based on prior history - in my opinion) produces a known level of reliability for the process. Most probably a high reliability standard (as the limits are so stringent).
- TUS and SAT T/Cs
- Before each use
- Load T/Cs
Hershal
Metrologist-Auditor
Jerry is correct, in that the thermocouples are well within the requirements.....
Based on subsequent replies, this may be a regulator requirement.....if so, smile, and do it.....
S Uncertainty Estimation in Temperature Measurement by K type Thermocouples Measurement Uncertainty (MU) 7
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Are EC type examinations still being conducted under MDR? EU Medical Device Regulations 5
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Marcel DS GOST-R (Type approval for Vehicles in Russia) Other ISO and International Standards and European Regulations 0
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
P Surgical masks ( type IIR) - Cleanroom Requirements EU Medical Device Regulations 3
W Insulation requirements of BF type infant skin temperature probe IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
N Infant radiant warmer - Heater Quartz Element type Other Medical Device Related Standards 0
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
M SI #7 8.4.2.1 Type and extent of control_supplemental IATF 16949 - Automotive Quality Systems Standard 3
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
K F-TYPE APPLIED PART IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
I AS9100 8.4.2 Type and Extent of Control - External provider test reports Manufacturing and Related Processes 24
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
R In this type of Legal Manufacturer-CMO arrangement, what happens to the DHR? ISO 13485:2016 - Medical Device Quality Management Systems 1
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
T Type BF or CF (Direct conductive contact with the heart) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P IVDD - IFU related requirements - Type of information/statement expected EU Medical Device Regulations 1
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
P Definition Business Type - Definition of what we do-Business Type Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
L Valid reasons to omit an "ear-tag" type label on a cable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P 2x MOOP for type B AP - Therapeutic device - Heater/cooler with pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Complying with IATF 16949 Cl. 8.4.2.1 - Type and extent of control IATF 16949 - Automotive Quality Systems Standard 1
P DMF (Drug Master File) type V for Sterilization Processes for USFDA Submission Other US Medical Device Regulations 3
E IATF 16949 Cl. 8.4.2.5 - Supplier Development Type and Extent IATF 16949 - Automotive Quality Systems Standard 2
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
S Number of MOPP for Type BF Applied Part (Medical Device Electronics) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M For a Type 1 Gage R&R I want to use 1 unit and measure it 30 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Test Specifications based on Vehicle Type Various Other Specifications, Standards, and related Requirements 0
N Recommendation of Supplier Program type Training Training - Internal, External, Online and Distance Learning 4
Q CE Mark Requirements for Components - Solenoid Actuator Type Devices CE Marking (Conformité Européene) / CB Scheme 3
