Why Cpk 1.67 and Importance of Cp?
bobdoering
Stop X-bar/R Madness!!
#11
In the previously attached article by Kotz and Johnson, they stated "Unfortunately, mistrust of PCIs, and especially of their estimators, when based on the meager data often available at factory level, is still not uncommon. Resistance to accompanying a single estimated PCI value by an estimate of its variability (be it confidence interval, standard deviation, or whatever) is still very pronounced, even though accepted statistics, such as sample mean and standard deviation, perform essentially the same function."
Guess what...we still mistrust them for precisely the reason you state: "the meager data often available at factory level". This is especially true when the index is calculated on a 300 pc capability run is expected to represent future variation with other raw materials, operators, etc. - variation not captured by the study. This is the assumption one would make to "approve" such a process based on the Cpk. No number of triple integrals can resolve that problem, gentlemen. The struggle between the academics and the practitioners rages on...
I was amused by the statement: "However, there seems to be, in some quarters, an assumption that the measured characteristic should have a normal distribution (at least, approximately), although it is difficult to see why a good industrial process must result in a normal distribution for every measured characteristic." (My bold emphasis) So true....so true...
Another good point: We finally quote from the Editorial (Nelson (1992)) in the issue of JQT devoted to PCIs: “in fact, it is clear from a statistical perspective that the concept of attempting to characterize a process with a single number is fundamentally flawed.” See
also Herman (1989). This is, of course, equally valid for any summarizing statistical measure used without any qualms. Nevertheless, the statement that “process capability indices are here to stay” (Kotz and Lovelace (1998, page 16)) appears, fortunately or unfortunately, to also be true."
I agree - this fundamentally flawed notion is here to stay...for now. I must admit - this is the first time I have read this article, but I have arrived at the same conclusion as Nelson.
#12
JQT (the acedemics) resoundingly repudiated the capability index craze in the October 1992 journal. (I still have original copy) Unfortunately since then the managment craze - led by the automotive industry - has driven strongly towards that single number and away from true understanding. Managers (including the customer's quality manager and SQE) just want to take the easy way out. Laziness is the root of this evil. (In my fertile imagination, THIS is the reason Deming decided to not stay here on earth with us mere mortals)
Stijloor
#13
Friends,
No (financial) Management Executive in a clear state of mind, wouldn't even think, wouldn't even dare, to express the financial performance of an organization with a single number to the stockholders. :mg:
Yet, it's perfectly acceptable to express the performance of a process with a single (meaningless) number. :frust: :frust:
Stijloor.
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Convincing Management Cpk without Stability is Meaningless Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
L Cpk after Data Transformation - How to Transform LCL /UCL to get Capability Report Capability, Accuracy and Stability - Processes, Machines, etc. 8
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
