Why doesn't ANOVA Method take the specification into account when determining GR&R %
John SB
The ANOVA method doesn't take the feature specification / tolerance into account when determining the % GR&R. Why? I performed na ANOVA GR&R for a production burst test stand and got a GR&R of 96%. When the same data was put into the avg. / range form with the specification of 98psi to 250psi I got 29%. It seems to me that this could be huge in determining if the measurement system is truly acceptable or not for the product. On top of all of this, the results are not really the weld joint failing but the parts parent material breaking apart. Just trying to learn more about ANOVA method and when / how to apply it. Thanks.
Re: Why doesn't ANOVA Method take the specification into account when determining GR&
could you post your data?
You should validate both of these worksheets using the Ford Validation data set because neither result is correct.
Using Minitab, the correct result for ANOVA is 18.92% and for Xbar/R is 19.14%.
On a side note: Is your (burst) test a destructive test? If so, you should be performing a Nested R&R study. The standard ANOVA and Xbar/R formats are crossed studies.
John SB
The avg / range form had 2 operators, 3 trials selected. Once I chose 3 operators, 3 trials the results came in at 19.34%.
Yes, the burst test is destructive and I thought this form was a nested form not crossed (grabbed it from the site).
Thanks Miner!
Do you have a Nested Form in Excel I could use?
No. All Excel-based forms that I have seen are all Crossed. The math involved in a Nested analysis is ANOVA-based and is even more complex than the crossed ANOVA. I use Minitab to perform any Nested Analyses.
John SB
Do you have a Nested Analysis form in minitab that you could send me?
I cannot. Minitab is statistical analysis software, not a spread sheet. While the data are entered the same way, the analysis is different.
See this overview of a nested ANOVA from the University of Wisconsin.
John SB
"Using Minitab, the correct result for ANOVA is 18.92% and for Xbar/R is 19.14%.
On a side note: Is your (burst) test a destructive test? If so, you should be performing a Nested R&R study. The standard ANOVA and Xbar/R formats are crossed studies. "
I have minitab now and am attempting to perform the ANOVA analysis. Above you mentioned the ANOVA result of 18.92%. What type of ANOVA did you perform? I would like to simulate it. Also since this is a destructive test it should be a nested ANOVA (as you pointed out). Could you perform that and tell me your result so I can also attempt that? Thanks.
I attached the Minitab Project containing all three analyses (i.e., Crossed ANOVA, Crossed Xbar R, Nested ANOVA) in sequence. To duplicate this, go to Stat > Quality Tools > Gage Study > Gage R&R Study (Crossed)... or Gage R&R Study (Nested)...
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
G Supplier doesn't accept the complaints Supplier Quality Assurance and other Supplier Issues 20
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
D IEC 60601-1 - Essential performance doesn't make sense IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
S DFMEA when the supplier doesn't have design responsibility APQP and PPAP 15
S Risk Approach doesn't address External Issues (Auditor's Comment) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
B Our NB doesn't accept new clients for MDSAP Canada Medical Device Regulations 8
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna ASQ apparently doesn't know ISO does not issue ISO 9001 certificates? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
H ISO 9001:2015 Cl. 9.3.1 - General Director doesn't participate in Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L Toyota doesn’t use Six Sigma Six Sigma 1
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
A Toy Company Doesn't Conform With CE Marking Requirements CE Marking (Conformité Européene) / CB Scheme 9
Q What to do when a Notified Body doesn't respond? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 8
A Cytotoxicity Testing - FDA doesn't like the Filtration step 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Owner of Company Doesn't Understand Corrective Action.... Quality Manager and Management Related Issues 12
M Minitab 16 doesn't like perfect data for Cpk & Normality? Using Minitab Software 5
bobdoering William A. Levinson speaks on When the Bell Curve Doesn?t Fit, Part 2: Non-Normality Statistical Analysis Tools, Techniques and SPC 0
P Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
R Medical Device Contract Manufacturer doesn't know ISO 14971 3.4 a) Life Cycle Phases ISO 14971 - Medical Device Risk Management 3
AnaMariaVR2 Jason Fried: Why work doesn?t happen at work Career and Occupation Discussions 3
ScottK This is why I'm glad iOS doesn't support Flash After Work and Weekend Discussion Topics 3
P Internet service that doesn't cost over $50/month After Work and Weekend Discussion Topics 23
A ISO 15883: What if my washer doesn't disinfect? Other Medical Device Related Standards 6
Marc Saying "I only had one beer" doesn't mean much any more Coffee Break and Water Cooler Discussions 3
S Is it a nonconformance if its outcome doesn't affect the customers? Nonconformance and Corrective Action 16
B Do I evaluate my supplier when he doesn't have delivery in that month? Supplier Quality Assurance and other Supplier Issues 10
J Procedure doesn't define the process - 7.1 Planning of Product Realization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
C ISO 9001:2008 Contract Review for a business that doesn't have formal contract review Contract Review Process 11
M Minitab 15 - READ, SET from keyboard or file doesn't work in my macro Using Minitab Software 4
P Supplier doesn't think drawings need to be controlled Document Control Systems, Procedures, Forms and Templates 34
J Customer rejection because he "doesn't like it." - No specific rejection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
Sidney Vianna Tough talk on Detroit Three doesn't consider suppliers World News 0
Marc Telcos: The Internet Will Collapse If The Gov't Doesn't Gives Us Lots Of Money After Work and Weekend Discussion Topics 0
R LEAN Difficulties - Why a company doesn't want to do LEAN Lean in Manufacturing and Service Industries 36
ScottK ASQ re-cert by exam... doesn't give you three years from exam date? Professional Certifications and Degrees 11
G Sample Approval by Customer - Customer doesn't send/return their approval IATF 16949 - Automotive Quality Systems Standard 10
Q FMEA vs. Kepner Tregoe Struggle - Management doesn't want to use FMEA FMEA and Control Plans 16
B What are Work Instructions for? Company Owner doesn't like Work Instruction Document Control Systems, Procedures, Forms and Templates 7
J Auditor doesn't like Quality Manual Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
T Management doesn't want process audits? Internal Auditing 19
P Architect's Client Doesn't Know What He Wants - Contract Review Process Contract Review Process 17
D Company doesn?t design product - Exclusion of clause 7.3 Design and Development of Products and Processes 14
A Classification column - PFMEA - Customer doesn't identify any critical characteristic FMEA and Control Plans 16
R How to Solve Missing Items Issues? Floor Control Software doesn't allow adjustments Manufacturing and Related Processes 11
Q Quality Manual vs. ISO9001:2000 Standard - Quality Manual doesn't address all of 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Conundrum - Why doesn't water burn? Funny Stuff - Jokes and Humour 35
R Incorporating new products into work order system...current system doesn't really fit Document Control Systems, Procedures, Forms and Templates 2
F Customer Satisfaction - Survey doesn't reach end user ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
