Why is Cpk = lower of (USL-Xbar)/3sig & (Xbar-LSL)/3sig ?
K
krishna_sadas
We are considering Cpk=(USL-Xbar)/3sig , CpK=(Xbar-LSL) which one is the lower value in our SPC study,
What is the reason for choosing the lower value?
Pl. help me
Manix
Get Involved!!!
Re: cpk
Pl. help me
You choose the lower value because this is the actual capability of your process. Depending on where your process is centered you may not be able to fit 3 std deviations between the Xbar and and the lower spec limit which would result in non-conformance and hence your process is not capable. Visa versa, you may not be able to fit 3 std deviations between the Xbar and USL and again, this means the process is in capable. You need to be able to fit 3SDs with room to spare between your USL and LSL in order for the actual process capability (Cpk) to be high enough to have confidence.
antoine.dias
In fact, the lower of the two gives an indication of the highest risk of producing parts outside of tolerance.
Best regards,
Antoine
Stijloor
Pl. help me
A picture is worth a thousand words.
Look at this simulation Cp & Cpk that Marc (the owner of this site) put on the very bottom of this page.
Stijloor.
Darius
Why?:confused:
Simple....., just because where the cpk is lower, you are farther from the middle of the spec limits (that could be your target), desto easer to have non conforming parts.:D
In such indicator, there is no pretention to measure, but to penalty your process capability (Cp) for such behabiur.:whip:
you know I have the same question as the OP. (perhaps for a different reason)
Why take just the lower value? what if you have parts out of spec both high and low? are the defects that are less frequently out of spec not of any importance? won't they feel left out?
what if there are 2 machines making the same parts: both have the same Ppk value for the high end of the spec (.5) but one has a very good Ppk value (>2) for the low end of the spec and the other machine has a poor Ppk (.9) for the low end of the spec. How do we judge these two machines? They certainly aren't equal...
Darius
Parts out of Lower and Upper specs affect to the stdev, desto to Cp, not to the penalty of cpk calculations (both cpk formaulae have 3*stdev).
Are the defects that are less frequently out of spec not of any importance? won't they feel left out?
If it is the case your specs are wrong.
It's true that cpk is affected by two events; one is less variation, the other is the process position. This makes possible to happen this scenario. I take better cpmk (to penalty because of not centering your process to it's target).
Even going into the same direction, some guys say that it's better to chart the process than rely on the index (ie. boxplot or run charts), but is a standard, most of the companies expect a cpk..... And as I readed somewhere "If you don't measure you can't manage".
Darius - first I don't think my sarcasm came thru in translation.
of less importance is the fact that just because customers ask for Cpk/Ppk doesn't mean they are right.
and I do believe that you can't manage without measuring but poor measurements only lead to poorer decisions. I've stated my distaste for trying to reduce the beautiful complexity of variation to a single number in previous posts. Manager's who can't interpret simple charts like run charts, multi-vari charts and control charts need to be taught as do our customers. WE need to be intellectual leaders, not lemmings who follow the priests of simplistic off the cliff.
Caster
An Early Cover
Hi Bev D
Your questions seem designed to provoke a response, so if I was your customer I'd be "unhappy"
For parts out of spec I hope you are sorting (not shipping me the OOS) and working hard to get in spec or negotiating with me the customer to open up the spec?
For two machines it comes down to the overall out the door capability, and it will be pretty bad when you combine two processes, one targeted and high and the other targeted low.
The customer gets all these parts, so again I hope you are working to target both machines, or get customer relief on the spec....
All this assumes the customer even knows anything about capability and that they have actually put tolerances on the print that make sense.
Sometimes customers just copy old prints without understanding. It is always good to talk to them to understand.
Caster
An Early Cover
What is the reason for choosing the lower value? Pl. help me
I was taught the "truck and tunnel" approach to SPC
Your process is the truck, and it is not in the center of the road
Steer your truck (process) back to the center line for a safer trip through the tunnel
People seem to get this example easily
The center line of the road is the target, the rumble strips are your control limits, and the tunnel walls are the customer specs
The truck is your process, I'd rather drive a normal truck through a tunnel than a wide load
Good luck
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
S Cpk is lower because of Measurement Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Cpk with LSL (Lower Specification Limit) at zero? Statistical Analysis Tools, Techniques and SPC 3
F Ppk/Cpk value with 1-sided specification - Only given a lower specification Statistical Analysis Tools, Techniques and SPC 1
C Calculating Cp and Cpk for Product with only LSL (Lower Specification Limit) Capability, Accuracy and Stability - Processes, Machines, etc. 28
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
