CharlieUK
Earth Bonding impedance and test current is completely unrelated to touch current
Earth bonding test current is typically the larger of 25 A or 2x rated current of the equipment.
The 0.1 / 0.2 ohm values have been in use for decades - I don't know where they originate, but a properly bonded connection should be < 0.02 ohm
Typically tested with a few volts dc.
Earth leakage current is the AC current that would flow in a specified test circuit (simplest one is a 2000 ohm resistor) that was placed between chassis and ground with the equipment ground disconnected. This is tested at rated mains voltage
