Why new clause (7.1.6) in ISO 9001:2015?
qualprod
Hello everybody
Why the standard added a new clause 7.1.6 to address something what is been considered in the past?
The knowledge, normally which was identified as value , was integrated to procedures, job descriptions, training, etc.
The same way, when a "lesson learned" (something good or bad) was detected, turned in a corrective action or in an improvement, which finally were integrated into the management system.
Needs for new training were also addressed.
So Lesson learned , IMHO shouldn´t be mentioned as additional actions to what existed in the standard.
or why have to be considered in a different way?
What is your perception in this issue?, dont you think that lesson learned is what we were doing in 2008 version?
Please give your comments
Tagin
It seems to me that it is about capturing the broader "braintrust" of an organization. For example, there may the case where someone knows what to do, but until they retire or leave, there were no issues, so no 'lessons learned' were recorded from that person's skills. But once they leave, the organization realizes they've lost some important knowledge.
Where capturing 'lessons learned' is reactive, capturing organizational knowledge is proactive.
From TS9002:2016:
"Organizational knowledge is the specific knowledge of the organization coming either from its collective experience or from the individual experience of its persons. This knowledge is or can be used to achieve the organization’s quality objectives or its intended results.
The organization should consider how to determine and manage the organizational knowledge required to meet its present and future needs. Persons of the organization and their experience are the foundation of organizational knowledge. Capturing and sharing such experience and knowledge can generate synergies leading to the creation of new or updated organizational knowledge
John C. Abnet
Teacher, sensei, kennari
Good day @qualprod
I can't tell you definitively why the authors "added" this clause. However, based on my past experience I can certainly assume why this was added. I believe we have all heard (or said!) ..."well, we used to do it that way but stopped doing it when Suzie retired", or...."Larry's the only one who knows how to do it and he's on vacation today" or....etc..etc.e.tc...
The auditors hear this type of responses also, and they feed this back to certification / oversight bodies.
As we know, ISO 9001 no longer requires any procedures , however, it does require ...
- 7.5.1 b) documented information determined by the organization as being necessary...-
7.1.6 does not require that we accomplish via documentation, however, in practice most organizations capture "organizational knowledge" via work instructions, curriculum, etc..etc... This is often a viable way to address 7.1.6 (i.e. show a link between roles [organization structure/process owners] and any documentation/curriculum utilized to train/move people into those roles.) so that even when Suzie retires or Larry is on vacation, there is a strategic approach to sustaining the knowledge they had.
Hope this helps.
Be well.
An example: In a place I used to work, it was discovered one day that the welding gas had run out and no one had reordered. Purchasing was queried as to why the gas hadn't been replenished and the answer was "We don't order welding gas. We don't know who does." It turned out that the task, some years before, had been delegated to a particular manufacturing engineer. No one knew why, but no one questioned it because it had never been an issue before. The engineer left the company abruptly, so no replenishment order had been placed. Lines were down for several hours as a result.
Sidney Vianna
Post Responsibly
Excellent example, but I fear, however, that the overwhelming majority of ISO 9001:2015 certified organizations have potential time bombs such as this one and compliance with the standard will not increase an iota of chances of they not incurring in a similar problem. It is humanly impossible for all of tribal knowledge to be captured and managed. Things will fall through the proverbial cracks; what differentiates a learning organization from the dysfunctional ones is the triggering of an investigation if similar issues still exist in the organization.
I agree. A dedicated effort to identify instances of undocumented tribal knowledge will always fail on some level.
qualprod
Sidney
For this, in project management there are practices which help to improve the lesson learned practice, by applying other levels
of actions. take a look at here Lessons Learned
EDIT: 404 link fixed.
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Which ISO 9001 Clause applies to "Procedures are outdated"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
A ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
B Clarification of ISO 9001:2015 Clause 8.5.6 Control of Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001:2015 Clause 8.2.1 e) - Requirements for Contingency Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Application of ISO 9001:2015 Clause Interpretations for Service Industries Service Industry Specific Topics 2
J Organizational Knowledge Requirements - Meeting ISO 9001:2015 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 60
