Why Reproducebility shows 0%
P
Pudge 72
#11
So, just for giggles - what would happen if you ran this study to evaluate it as a % of Tolerance instead of standard Study Variation for the variable feature that you are measuring - what does the R&R come out to be in that case?
#12
It will be even better. the range of actual measurements is less than the tolerance zone (UNLESS there is significant measurement variation at the outer limits of the sepc range...this would be an interaction of the measurement system with the process)
The reason the reproducibility is so small (negative forced to zero?) is that the standard deviation for the differences in operators is very small while the measuremetn system std dev is very large. it's a simple math problem of squaring subtracting then taking a square root. try it by HAND instead of by minitab.
However, one thing you cannot see at all with the traditional method of gage R&R plotting is that operator 2 has extremely good repeatability, on the order of 19 distinct categories! I always recommend plotting the repeated measurements on a scatter diagram with a 45 degree line on it. thsi shows you a LOT more than the standard graphs and it can be done in one graph instead of 4...
Q Project Tracker - Something that shows the status of each project Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
Marc Google Earth Timelapse update shows Earth from 1984-2016 After Work and Weekend Discussion Topics 1
Ajit Basrur New Study Shows Brain Benefits Of Bilingualism Coffee Break and Water Cooler Discussions 0
K New Gauges calibration certificate shows deviations from the measurement uncertainty IATF 16949 - Automotive Quality Systems Standard 5
S Excel spreadsheet shows weird CPK outcome Quality Assurance and Compliance Software Tools and Solutions 10
L Device shows an Error message - Malfunction or not? Other Medical Device and Orthopedic Related Topics 12
A Plug Gauge Size shows increase after use? Criteria for acceptance of the gauges? General Measurement Device and Calibration Topics 5
Hershal Reality TV shows..... Coffee Break and Water Cooler Discussions 7
hogheavenfarm Reference Distance - Print which shows "1.656 REF" as a dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Soldering Standard which shows good and bad soldering Document Control Systems, Procedures, Forms and Templates 5
D Harvard shows the way....... Imported Legacy Blogs 0
N Does Anyone have something that shows Correlations between ISO 14001 & AS 9100? ISO 14001:2015 Specific Discussions 9
Manix MSA Study for Highly Repeatable Parts shows need for MS Improvement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
Q Blueprint reading, Implied use? Drawing shows an implied orientation Manufacturing and Related Processes 17
A ASME Symbols (process Flow Diagrams) - GM-1805 (KCDS) shows different symbols APQP and PPAP 3
Marc Manpower survey shows worldwide "talent shortage" Career and Occupation Discussions 6
R What to do if your study shows the machine isn't capable? Statistical Analysis Tools, Techniques and SPC 7
Marc Survey shows that employee morale has taken a hit World News 3
S How do I construct a control chart that shows a changing average? Statistical Analysis Tools, Techniques and SPC 9
Hershal Movies and TV shows we like (or not...) Coffee Break and Water Cooler Discussions 109
Wes Bucey What? No FMEA at GM? Car clock shows the wrong day of the week! FMEA and Control Plans 29
W ISO/IEC 17025 vs. ISO 9000 Comparison Matrix which shows Differences ISO 17025 related Discussions 4
V Procedure that shows how to do Dock Audits? Document Control Systems, Procedures, Forms and Templates 3
