Will these Quality Objectives cover the Product Requirements?
jzengj
I'm currently working together with the management of my company to better define our quality objectives. One of the ISO 13485/9001 requirements for the objectives set is that they should cover product requirements. The objectives we have are:
1) Meet customer or regulatory requirement(s) and customer's satisfaction
2) To improve project schedule adherance and ensure project completion within budget
Will these likely be sufficient to cover the product requirement?
You really have four or more objectives here. The first part of #1 is the main one that deals with product quality.
It helps greatly to keep from having complex objectives. Have a few more and keep them separate, instead of making them compound.
How are you going to measure meeting customer and regulatory requirements? Some typical measures are warranty returns (pretty much a big no-no in medical devices), first pass yield (how many items make it through final inspection the first time without re-work), scrap rate, rework rate, both as a result of final inspection and as a result of problems found at any other inspection point.
Some overall guidance on coming up with objectives are that the data is easy to gather and the results are useful. Element 8.4 provides some guidance on what to measure as well, where it tells you to determine, gather, and analyze data that tells you the health of your quality management system and aids you in making improvements. It then goes on to say that there are four topics to cover 1) customer satisfaction (not a topic for medical devices, but a topic for ISO 9001) 2) product quality 3) process performance (often measured by on-time delivery), and 4) supplier performance.
Tara Monson
Those are a great start!
I agree with BIG JIM. You really want something you can measure so progress can be tracked.
EXAMPLE:
Your objective, "Meet Customer Satisfaction."
Restated, "Obtain 75% customer satisfaction on Customer Satisfaction survey."
On-time delivery..."Meet an OTD rate of 90%."
Those are just some examples. You want to have a goal that is measurable.
Good luck!
Mallya
I believe u have put forward draft proposal, apart from being complex, they are not SMART, Importantly make sure they are measurable, time frame, realistic and achievable depending with u situation on ground. Check Tara's examples on previous post.
Regards
Benny
H
Hodgepodge
You can track the scrap rate of manufactured product (how many parts manufactured meet product requirements?). This is something that can be measured objectively.
jzengj
Thank you all for the replies! So can I say only this objective "Meet customer or regulatory requirement(s)" is the one that deals with product requirements?
What i also gather so far is that the objectives have got to be measurable. We do have measurable targets for each year, but our practice is have targets written into a separate document, while we define the objectives within the QM. However, the one issue we are facing is finding the right data to measure, as our product usually stops at the design transfer stage and they are varied being of research nature.
drgnrider
... One of the ISO 13485/9001 requirements for the objectives set is that they should cover product requirements. The objectives we have are:
It looks like what you are creating here are the high-level business goals and then creating more targeted objectives to reinforce those goals, and that your "product" is a design.
Both of your goals can be product-related and have some of the same targets. An 'on time delivery' objective covers both 'Adhering to design schedule' and 'customer satisfaction'; as stated earlier, just need to quantify the target.
jzengj
Thanks drgnrider! It seems like what I need to do is to quantify the targets better in this case.
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
M Root cause for lack of quality objectives for HSE Dept. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
J Quality Objectives and resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
I Quality Policy and Objectives examples Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 5
M Specific Values of Quality Objectives Benchmarking 7
Q Quality Objectives Not Met - Resources promised by investors ISO 13485:2016 - Medical Device Quality Management Systems 4
V What plans have been put in place to achieve quality objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Objectives in Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Farley.0 QMS Sales Goals & Quality Objectives Manufacturing and Related Processes 22
qualprod Annual SWOT for 4.1? I plan to revise quality objectives and strategic route ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
V Discussion of ISO 9001:2015 - "Quality Objectives" term ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Quality Department Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
R ISO 13485:2016 - Quality Objectives Regulatory Requirement Examples ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Additional KPI to Top Management beside Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Examples of Quality Objectives related to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Identifying Objectives & Targets for Quality Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
dubrizo If Quality Objectives are not known to employees, is it a Nonconformance? General Auditing Discussions 7
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Corrective Action for Quality Objectives which are not Measureable Nonconformance and Corrective Action 7
T Best place in QMS to manage Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Quality Objectives for Quality Control and Quality Assurance functions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Are Quality Objectives applicable on HSE Department? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Presentation for tracking Quality Objectives across sites Preventive Action and Continuous Improvement 3
M Quality Objectives - Acceptable Levels and Functions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
H ISO 9001 Quality Objectives Scorecard or Matrix template to share ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Setting Quality Objectives for Service, Repair and Sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
L Changing Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Where to document Quality Objectives ISO 13485:2016 - Medical Device Quality Management Systems 6
J Quality Objectives for Engineering Department and R&D Quality Manager and Management Related Issues 5
A Quality Objectives 5.4.1 - KPI SOP - ISO 13485 Audit Observations EU Medical Device Regulations 6
A Are Explicit Quality Objectives Required? Quality Management System (QMS) Manuals 8
G Defining Quality Objectives for Product Realization and Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Quality Objectives - Telephone Calls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Quality Objectives for Aerospace Chemical Conversion & other Surface Treatment Plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Determining Quality Objectives for the Finance Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
