Windows 11 is Coming--Is Your Computer Ready?
At the release of Windows 10 in 2015, Microsoft said that it would be the last version of Windows, and would get "feature" updates twice yearly. In June of this year, it was announced that Windows 11 was coming, and it would be probably be released at the end of this year. The release date, as it turns out (and unless it changes, or course) is October 5.
The big news on Windows 11 is new hardware requirements. It seems that Microsoft is constitutionally incapable of releasing a new Windows version without screwing it up somehow, and 11 is no exception. At first, an app called PC Health Check was released, allowing users to verify that their computers would be able to run the new version. Because the new requirements meant that many relatively recent PCs wouldn't qualify (including a few relatively recent Microsoft Surface devices), MS went back to the proverbial drawing board and eased some of the processor requirements, and withdrew the app until they can get their stuff together. As is often the case, a third party stepped into the breach with a free app called Whynotwin11 that's keeping pace with Microsoft's ongoing changes.
Right now, the sticking point is processors. The original requirement was at least a 10th generation Intel CPU, and Zen+ AMD processors. The AMD requirement hasn't changed, but now MS is saying that some processors going back to 7th generation will qualify. That still leaves a lot of functioning PCs in the lurch, including mine. I built a desktop PC in 2012 that has been humming along nicely since then, first with Window 8 and then on through all of the Windows 10 flavors since 2015. As I was already contemplating doing a hardware upgrade, I went ahead and replaced the motherboard, processor and RAM and added an SSD in place of the old mechanical hard drive. The SSD made a remarkable performance difference, btw. Cost of the upgrade was about US$500. If you have a proprietary desktop computer that doesn't qualify under the new requirements, you might not be able to upgrade it, and many older laptops will be left out in the cold as well.
Windows 10 will be supported until 2025 for those who choose to stick with it. Windows 8.1 will be supported until 2023, and support for Windows 7 ended in 2020. As with all new Windows versions, it will be interesting to see how business will react to the availability of Windows 11.
Exactly why I quit windows for Linux. Still using my 2008 Dell laptop that once had the Great XP on it, but finally I tried Ubuntu and liked it so much I never went back. After finding out the WINE application would let me run my old windows programs I kicked myself for not leaving sooner. Still cooking along on 32 bits as well.
blackholequasar
The Cheerful Diabetic
While I do prefer to dabble in Linux, I work with a workforce who can barely handle using Microsoft Word. Whenever there are updates, it causes bedlam at our facility... I'm not sure how Windows 11 will impact us, but something should probably be planned out prior to implementation!
It's not just the processor that's an issue for Win11, it is the requirement of having a motherboard that supports Secure Boot, which in turn requires that the motherboard support UEFI boot and has a TPM 2.0 module installed.
Windows 11 System Requirements
The first link in my post addresses the TPM/Secure Boot requirement. This will be a problem but not as big a problem as the CPU requirements. TPM may be implemented in the form of a piece of hardware that plugs into a socket on the motherboard, or it's often implemented in the firmware without the actual hardware. Such is the case with my new Asus motherboard, and Asus recently released a BIOS update that turns it on by default so people won't have to go looking for it. My old motherboard had the socket but not the module, and it was for a TPM version earlier than 2.0.
The bottom line is that there are a lot of PCs that won't meet the new requirements, and won't be upgradeable to meet them.
True for most OS, but Ubuntu, (or Mint for that matter), once installed (which is the slightly technical part, mostly having to with disabling secure boot) these systems are almost exactly the same as windows in how they feel and operate. And with much less worry about viruses than windows machines. Other flavors of Linux are different, and different skill levels are needed to navigate those. The "Libre Office" suite is practically a duplicate of MS Office as well.
Ed Panek
QA RA Small Med Dev Company
I am getting the same message. I built a super rig in 2018 with an AMD 2990WX 32 core Threadripper, UEFI Boot capable ASUS Motherboard, 128 GB RAM, an Nvidia 2080Ti, and a 2 TB SSD with Windows 10. It says my PC isn't ready for Windows 11.
Maybe how they feel, but not how they operate. There are issues with app packages and dependencies that would be completely foreign to a Windows user, and there are still issues with availability of hardware drivers, although not nearly as many as there used to be. The command line structure is also completely different.
Your processor is listed as compatible. What source are you using that's telling you that your PC isn't ready? What does it say the problem is?
Ninja Windows 10 100 % disk use after update Coffee Break and Water Cooler Discussions 33
G Windows 10 OS build Software Validation US Food and Drug Administration (FDA) 1
Claes Gefvenberg Windows 8.1 - Pros & cons, hints & tips. After Work and Weekend Discussion Topics 5
Jim Wynne Windows 8.1: No Security Updates Without Update 1 After Work and Weekend Discussion Topics 4
Marc Windows XP EOL scamware After Work and Weekend Discussion Topics 1
insect warfare IRS pays Microsoft for Windows XP support After Work and Weekend Discussion Topics 2
insect warfare Windows XP support ends today (April 8, 2014) After Work and Weekend Discussion Topics 2
T Will the End of Windows XP Support affect anything in AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K COTS Validation: Should we validate Windows after each Update? IEC 62304 - Medical Device Software Life Cycle Processes 3
G When to use a flyscreen on windows? Food Safety - ISO 22000, HACCP (21 CFR 120) 8
Jim Wynne Have you tried Microsoft Windows 8? After Work and Weekend Discussion Topics 25
Marc The "I am calling you from Windows" telephone scam After Work and Weekend Discussion Topics 13
Z Tutor For Windows--CMM Software--Is anyone familiar with it? Calibration and Metrology Software and Hardware 2
D Windows CE Operating System - Implantable Blood Pump and a Software Accessory Device IEC 62304 - Medical Device Software Life Cycle Processes 8
Stijloor Importing Address Books (Thunderbird and Outlook Express) into Windows Live Mail After Work and Weekend Discussion Topics 3
Marc 66% of All Windows Users Still Use Windows XP After Work and Weekend Discussion Topics 19
Stijloor Briefcase on Windows 7... After Work and Weekend Discussion Topics 29
S Google phasing out use of Windows over security concerns After Work and Weekend Discussion Topics 0
Claes Gefvenberg Microsoft Windows users: Which windows version are you using? March - April 2010 After Work and Weekend Discussion Topics 37
S Software changes (windows 2007 compatible) notification to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Jim Wynne February 2010 Windows Update Causes BSOD for Alureon Rooted XP Users After Work and Weekend Discussion Topics 8
J Google Offers Peek at Operating System, a Potential Challenge to Windows After Work and Weekend Discussion Topics 2
S Does Windows Service Pack (SP-3) upgrade need supplementary 510(k) submission?? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Marc FSF Attacks Windows 7's "Sins" In New Campaign After Work and Weekend Discussion Topics 1
F Is self-serve password reset for Windows considered for validation under CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 2
A If you use Magic Windows Professional SPC Software. Please Reply Quality Manager and Management Related Issues 1
Marc Cloning a Windows XP drive and Booting from a Firewire Clone After Work and Weekend Discussion Topics 4
DanteCaspian Looking for Windows Media Player Help After Work and Weekend Discussion Topics 3
bobdoering From MS: Guidance on Windows Deployments for Business Customers After Work and Weekend Discussion Topics 0
Stijloor Microsoft's Ballmer: Windows 7 is nearly final After Work and Weekend Discussion Topics 13
A Critical Windows Patch - All Version - 24 October 2008 After Work and Weekend Discussion Topics 6
Marc NNTP Usenet Readers for Windows - Suggestions and Reviews After Work and Weekend Discussion Topics 4
ScottK Safari for Windows is out today. After Work and Weekend Discussion Topics 9
Stijloor The 20 (Mostly Free) Downloads for MS Windows Computers You Can't Do Without After Work and Weekend Discussion Topics 2
Claes Gefvenberg Upgrading the Windows OS PC? After Work and Weekend Discussion Topics 29
B Which Quality system? Company produces aluminum windows - No automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Claes Gefvenberg So, how about Microsoft Windows Vista? After Work and Weekend Discussion Topics 85
Marc Vinyl Replacement Windows - 'Weeping' condensation at Glass / Vinyl Interface After Work and Weekend Discussion Topics 20
J MS Windows XP Pro Hard Drive Defrag (defragmentation) question After Work and Weekend Discussion Topics 26
Marc CrossOver public beta: Allows Windows apps to run without Windows on Intel-based Macs After Work and Weekend Discussion Topics 0
Marc Another Windows Vista Feature Bites the Dust - PC-to-PC synchronization After Work and Weekend Discussion Topics 1
Marc Intel-Macs owners now have an official second OS option - Windows XP After Work and Weekend Discussion Topics 10
B Keeping your Windows PC running Smoothly After Work and Weekend Discussion Topics 18
Marc Extremely Critical Windows Security Hole - 29 December 2005 After Work and Weekend Discussion Topics 0
Marc Dell's Open PC Costs More Than Windows Box After Work and Weekend Discussion Topics 5
Q Windows vs. Linux - Just wondering if any Covers use or have tried Linux After Work and Weekend Discussion Topics 6
Marc What is the best 'Windows' laptop (notebook) computer? After Work and Weekend Discussion Topics 19
Marc Hackers Tune In to Windows Media Player - Two new Trojans After Work and Weekend Discussion Topics 4
Geoff Cotton MS Windows - Bagle-A Virus Alert - 18 Jan 2004 After Work and Weekend Discussion Topics 17
