Withdraw NCR Request - External QMS Audit is In Progress
joshubob
A 2 days external QMS audit is in progress, the first day the auditor has raised a Major NCR. Our QMR asked the concerned department to write a corrective action procedure and they have written. At the closing meeting our QMR will request the auditor to examine the procedure and also to withdraw the NCR. How the auditor will respond?
Stijloor
Re: Withdraw NCR
Do you mean, there was no Corrective Action procedure written?
If there was no procedure, and no active and effective corrective action process in place; then it is a major nonconformity!!
A (corrective action) process can not be implemented in a few days.
I am surprised that your organization missed this. :mg:
Stijloor.
samsung
Re: Withdraw NCR
Stijloor.
IMO the OP's MR intends to influence the auditor to withdraw the NCR on the premise of corrective action taken by the organization before the closing meeting.
:agree1: if it's a major NC, it's unlikely that it can be closed in a day. But it depends on how the CB has defined it.
Big Jim
I can't speak for Certification Bodies other than the one I mostly work with, but currently they do not permit an NCR to be closed during an audit.
Up until a few years ago, they did. I suspect that it was due to the fact that an NCR that was rushed to close before the end of the audit usually had poor root cause analysis and a resulting poor corrective action. I also suspect that no longer accepting NCR responses during the audit was driven by the Accreditation bodies, but I don't know that.
On a slightly different tone, there is nothing wrong with discussing an NCR, even down to the last few minutes of the audit. There is nothing wrong with providing additional (already in existence, not newly fabricated) information to strengthen your position. I saw this recently, when the auditor was ready to write an NCR over lack of validation of a special process. The client was able to successfully defend his position that the process in question was not a special process, that is, that the outcome could be fully verified and validation was not necessary.
It sounds like you need to take the hit and then work on an effective root cause analysis with an accompanying effective corrective action.
Sidney Vianna
Post Responsibly
If this is a question from an auditing exam, you answer that the NCR stands as reported since there is no evidence of "closure" and effectiveness. If this was a real world scenario, the same thing applies.
If this was an audit against AS9100C, AS9110A or AS9120A, the auditor would be PROHIBITED from reviewing anything related to that NCR, during the course of the same audit.
Jen Kirley
Quality and Auditing Expert
I expect the auditor will respond in that the NC has been raised, and the response-correction-follow up will commence as is normal in any NC that an auditor raises. Getting the fix underway during the audit is fine, but no registrar should omit the NC based on speed to respond. The issue was, after all that a major discrepancy was found during the audit. That does not change.
somashekar
By now your 2 day audit must have been done and NC's firmed up.
Not knowing the situation as you have experienced, it is always good for the MR (QMR) to discuss this out with your auditor, if they are willing to see a correction to the noticed situation, and reconsider the NC by the closing meeting.
If your QMS is otherwise good and that auditor agrees a correction evidenced will set the matter right, he may be willing to have a look and give you that opportunity.
Please note that I have used the word correction, and not corrective action. If the noticed NC still needs a corrective action based on the auditor's assessment, you may still have to do more than just providing a procedure.
qusys
If accepted by the auditor, I see this only as a "patch", a containment action.
This action cannot be accepted as a corrective action , because the root cause is not fixed yet. Your organization shall approach this non conformity applying the tools of problem solving and shall demonstrate that the entire activity is perfomed as per what established.
I think that the non conformity will remain open and the auditor will perform a follow up within the timeframe set as per registration body rule. He will visit you again within 90 day ( usually this is time frame) , in order to verify if the plan to correct the ncn is ok. The verification of the effectiveness will be checked in the next surveillance audit. If the follow up is negative, this could jeopardize your certification.
Hope this helps.:bigwave:
P
PE-2011
Instead of NCR (Non Conformity Report) noways seeing CAR (Corrective Action Request). I feel by meaning both are same. Is it?
Maheswari
M Informational The ANSM decides, as a precautionary measure, to withdraw from the market macrotextured breast implants and breast implants with polyurethane-coated s Medical Device and FDA Regulations and Standards News 0
W How to withdraw a cleared (but never sold in the US) 510(k) Medical Device? Other US Medical Device Regulations 7
M Does FDA allow you to withdraw a CAR once it is in your system Nonconformance and Corrective Action 3
K Compelling reasons for a certifying agency to withdraw a ISO certificate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
K My question is, what/when is a nonconformity? Therefore what requires an NCR? Nonconformance and Corrective Action 9
L How to write a proper defect description in a NCR Nonconformance and Corrective Action 4
qualprod When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
M Issuing NCR for improper method statement submissions Internal Auditing 10
A Scrap is NCR or not - What regulation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
Q Interaction of Processes IOP NCR Process Maps, Process Mapping and Turtle Diagrams 7
W Surveillance report along side an NCR program Nonconformance and Corrective Action 2
A NCR, NCMR, CAPA, Deviations - Medical Device Distributor Nonconformance and Corrective Action 2
D Can an AS9100 auditor issue an NCR a month after the audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K AS9100 - No NCR's or CA's during Stage 2 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
K NCR or CA? We're taking any issue we have and saying its a nonconformance Nonconformance and Corrective Action 11
S Re-validation NCR - In which cases re-validation of processes is required Oil and Gas Industry Standards and Regulations 6
Pancho United Airlines NCR Nonconformance and Corrective Action 43
Q Practical Way to raise NCR's in an Assembly Workshop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
W NCR Performance KPI Monitoring in an Industry like Construction Nonconformance and Corrective Action 1
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
N Any comment, if a supplier raise an NCR to the Client? Oil and Gas Industry Standards and Regulations 5
W Auditor Remorse for not issuing an NCR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
I NCR for Customer not updating their drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
R How do you perform verification of a NCR (Nonconformance)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N New to ISO 9001 - NCR for every defect? Nonconformance and Corrective Action 5
B Combining a CAR, an NCR, and an Accident Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Validity of Using NCR's to evaluate Performance Nonconformance and Corrective Action 7
P Differences between an NCR and CAR Internal Auditing 9
N NCR and CAPA in the FMCG (Fast Moving Consumer Goods) Industry Nonconformance and Corrective Action 1
T Do Customer Returns = NCR and CAR? Nonconformance and Corrective Action 5
K Nadcap (AC7107/7 C, paragraph 6.1.b) NCR - Machining Tensile Specimens AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L How to track the NCR (Quality Notification, Services Notification) Nonconformance and Corrective Action 2
F AS9100 Management Review NCR help - Output of the MR is not Adequate AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q ECR (Engineering Change Request) or NCR (Nonconformance Report) in Fabrication? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q NCR before the Product is delivered to the Customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Is an NCR required in this Customer Complaint scenario? Nonconformance and Corrective Action 6
W Process Effectiveness NCR's (Nonconformance Reports) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Internal Auditing Checklist - Major NCR because the Checklist was not Completed Internal Auditing 17
S Is an 8D Report and a NCR (Nonconformance Report) the same? Nonconformance and Corrective Action 10
N NCR (Nonconformance Report) Combined with Corrective Action Report? Nonconformance and Corrective Action 1
B Format for Discrepant Material Report (DMR) - Nonconformance Report (NCR) Document Control Systems, Procedures, Forms and Templates 1
C AS9100 8.3 Procedure for Non-Conforming Parts - When should an NCR be filled out? Nonconformance and Corrective Action 5
J What is the time limit for an auditor to respond to NCR's and submit audit report? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Customer NCR - How to respond to a non-applicable NCR? Nonconformance and Corrective Action 7
C NCR (Nonconformance Report) Root Cause - Cause Code AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q How raise en ECO starting from a NC - ECO after NCR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
