Work Instruction Authorization
Mr Roo
What is the general consensus concerning an authorization signature on work instructions?
I am of the opinion that a control number & revision level is sufficient, but a consultant has stated that their should be an authorization signature included in the footer of the document.
Please advise & thank you
Jean_B
TLDR; There is a requirement to demonstrate appropriate approval within the system, but not necessarily on the document. A total absence of approval needs to be justified within the system. For work instructions, I don't think you can.
Under the previous 9001 edition there was a need to approve documents for adequacy. There was no requirement that this needed to be on the document used, though you should be able to demonstrate the controls to ensure this. Thus, you could separate approval to a system side, while control distribution of documents to only be those approved for use.
Under the new 2015 edition this must also be ensured through 7.5.2 c. If you can show that your control number (presuming that is the unique ID) and the revision level was appropriately reviewed and declared suitable and adequate.
A clarification on what appropriate means is not given in ISO 9000 or ISO 9001, so i usually presume it is equal to that of ISO 13485, which was based on the previous 9001 edition:
When a requirement is qualified by the phrase “as appropriate”, it is deemed to be appropriate unless the organization can justify otherwise. A requirement is considered appropriate if it is necessary for:
— product to meet requirements;
— compliance with applicable regulatory requirements;
— the organization to carry out corrective action;
— the organization to manage risks.
Thus, you could try and justify for certain classes of document the absence of assessment as suitable and adequate as it would not be needed for any of the four points. Though those justifications will be very difficult for what is typically understood to be work instructions.
Sidney Vianna
Post Responsibly
Sometimes I question how can Industry move forward, when "consultants" can be so archaic in their thinking, such as in this case. The world is going digital, real-time, cloud-based systems and the consultant thinks it is critical to have a freaking signature on the paper:horse:...if this is an indication of the consultant's capabilities, that's scary. As beautifully stated before by Jean_B, the issues at hand are: approval, correctness, availability, relevance, etc... of the work instruction. Not a meaningless signature on a piece of paper.
Good luck.
Mr Roo
Thank you both for the insight as it pointed me toward a solution.
All documents relevant to our QMS are cataloged in a document master list spreadsheet with hyperlinks to the specific document.
Going forward, I will record the authorization information (name, title, date) in the master list and skip the approved by line on the document itself.
Jean_B
Be careful in how you ensure authenticity of approval, and how well it stands up to scrutiny. Secure that file and the linked files from unauthorized changes at the least. Then be aware whether you must commit to any further data integrity practices due to regulations or customer requirements.
Mike S.
Happy to be Alive
Digital signatures such as provided for in Adobe Acrobat work well. I have also used an emailed approval kept on file to show approval.
John Broomfield
Bunkum. Your “ISO consultant” seems not to understand the standard.
Approval signatures are not required but evidence of approval is.
So, when a document is issued for review and comment it could be under a letter revision control and as soon the document is approved for use it could be under numerical revision control.
Randy
I'm trying to find the requirement for a "Footer" to begin with, I might have missed something today while auditing document control as part of an initial certification audit. Did I miss the required signature part as well in the standard?
Jean_B
The signature as such is not required (though it is a typical method of implementation). Approval is. One could state that given a controlled set of rights to one person responsible for approval, the appearance of documents in a thus controlled location is also evidence of approval (would practically only work for the smaller companies). Though agreed, typically you would find some demonstrably authentic approval path, whether wet signature, digital signature or traceable system action.
The footer (or header) is an implementation of a recursive mark on succesive cohesive units supporting several aspects. The cohesive unit is something where a loss of integrity is self-evident. A page torn in half, even without further identifying marks, is clearly suspect for loss of information. If a document has two pages, but you lose the last this is not (always) immediately clear without aiding identifying marks.
This is meant for identification (9001:2015, 7.5.2 a), which supports suitability (9001:2015, 7.5.3.1 a) through control of changes (9001:2015, 7.5.3.2 c). This combined with the associated page of total pages it ensures loss of integrity (9001:2015, 7.5.3.1 b) could be identified.
Digitally though, you could replace this by checksums on the pagecount. In the analogue world pagecounts with 'this is the last page items' in a Table of Contents at the start. Ah the room a standard provides.
Randy
Jean, I was joking and being ugly, I've been auditing MS's about 20 years and taking a slap at that expert consultant. I see more MS garbage and krap that most here, especially "the flavor of the month", "pipe dream" requirements. It's generally those snatched out of the air requirements that jump out and say "please write the nonconformity because it ain't happened"..
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F Label work instruction - Medical Devices Manufacturing and Related Processes 1
I 2017/745 (MDR) - Instruction for use (IFU) - manufacturer's website EU Medical Device Regulations 11
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
J Standard Work Instruction Languages (IATF 16949 8.5.1.2) IATF 16949 - Automotive Quality Systems Standard 5
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
M EU Regulations or Standards for instruction for use (IFU ) EU Medical Device Regulations 3
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
Q Product Instruction for Use Manual (IFU) - Obligation to list the standard used 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
W CPU BIST IEC 62304 - Embedded code has CPU instruction tests IEC 62304 - Medical Device Software Life Cycle Processes 2
M Standard work, standardized work instruction & work instruction: What are differences IATF 16949 - Automotive Quality Systems Standard 7
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
0 Safety Instruction Card and Safety Work Instruction Document Control Systems, Procedures, Forms and Templates 3
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
G SOP or Work Instruction for PFMEA? FMEA and Control Plans 5
Z Internal Memo used to document work instruction Document Control Systems, Procedures, Forms and Templates 2
T Handling of Obsolete Material Work Instruction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Mention "according to Work Instruction" in Control Plan FMEA and Control Plans 3
alonFAI SMI (Solder Paste Inspection ) Inline Work Instruction (Procedure) Manufacturing and Related Processes 3
G Work Instruction Performance Measures Misc. Quality Assurance and Business Systems Related Topics 3
M ISO 9001 Work Instruction Structure Document Control Systems, Procedures, Forms and Templates 1
W Control of Document - Working Instruction and Checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Steps to Complete Quality Control Plans and Work Instruction Manufacturing and Related Processes 4
A Should I call this ?Blank Template? a Work Instruction? Document Control Systems, Procedures, Forms and Templates 11
Q Referencing a Specification in a Work Instruction as a ?Guidance Document? ISO 13485:2016 - Medical Device Quality Management Systems 1
C SOP Work Instruction (Job Card) Template Revisions question Document Control Systems, Procedures, Forms and Templates 6
K Intended Use wording: What is suitable for the instruction manual? EU Medical Device Regulations 4
A Definition Technical Work Instruction vs. Method Statement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
M Orthopedic IFU ( Instruction For Use ) EU Medical Device Regulations 3
J Control of equipment instruction manuals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
I Document Control - Instruction Manuals and Service Manuals General Measurement Device and Calibration Topics 2
C SS-EN ISO13485 Work Instruction Requirements for Dentures ISO 13485:2016 - Medical Device Quality Management Systems 2
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
M Looking for a Powder Coating Process Instruction Manufacturing and Related Processes 3
J Setting up Performance Review Instruction Phrases in my Company Human Factors and Ergonomics in Engineering 11
W FDA Labeling Requirements - Instruction for Use Content 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L ISO 17021:2011 - The Application of Annex A - Work Instruction Details General Auditing Discussions 9
T AS9100C Work Instruction Clarification - How detailed should a Work Instruction be? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
B Work Instruction Application (Software for Document Control) Quality Assurance and Compliance Software Tools and Solutions 2
6 Instruction Manual for the production of Deionized Water Manufacturing and Related Processes 2
M Procedure & Work Instruction Flow Charting vs. Turtle Diagrams AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
K Audit Nonconformance? Employee References Work Instruction Internal Auditing 17
S Work Instruction template for Automotive Component (Refrigerator) Manufacturing and Related Processes 11
Q Can a WI (Work Instruction) be alone without depending on a Procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Work Instruction Content and Machine Manuals Document Control Systems, Procedures, Forms and Templates 12
