Hi Marc..
Thank you very much for your quick response. I am looking for a Pensions Interface Testing. We receive the data in an excel file, which needs to be transfered into a notepad and then do a load on to our application using an interface. I was asked to prepare a work instruction document for the above process which includes step by step instruction.
Could you please provide a document if available one.
Thank You
Kumar.
Welcome to the Cove.
You receive an Excel file, and transfer the data into a "notepad." What do you mean by "notepad"? Are you referring to an ASCII text editor (e.g., Windows Notepad)?
From the "notepad," you transfer the data to your application, using that application's "interface." What is the application? Is there a custom database interface involved? If that's the case, we have no way of knowing anything about the application or its data entry interface, so it would be difficult to guide you.
If you know how the system operates, it should be a relatively simple matter to write down the steps of each operation as they should be performed, which will result in a work instruction. If you're not familiar with it, you should sit down with someone who is and work it out. You're not likely to find a WI that will address the requirements of a custom application.
