Work Instruction to Calibrate or Verify a Combination Square
jcschwartz - 2009
I was wondering if anyone could give me a work instruction for verifing a combination square. We use combo squares to check 90 degree angles and are spending a ton of money to get them calibrated outside. I want to do a verification in-house of all the tools that are verified and not calibrated. By this I mean tools that if found to be out of tolerance are thrown out since they cannot be changed. I can do the steel rule of the combo square but I do not know how to verify the 90 degree angle. We are a very small company but all of our shop guys have these squares. If someone could help that would be great.
SteelMaiden
Re: Calibrate or verify a combination square
What sort of resolution do you need? If you measure 3" on one leg of the square, 4" on the other, the Hypotonuse (sp??) will measure 5" (or any other unit of measure) I used to use this ratio for maintaining square in construction, we used feet instead of inches.
BradM
Welcome to the Cove! Might I say you provided an excellent first post! It is really appreciated when relevant information is provided. Thanks!
What is the history on these squares? You may can extent the frequency. I would not see the 90 changing that often.
Are you paying for as found/ as left data? Could you get by without that information? Have you shopped around at competent labs to see if you can get a better deal?
Do you have any visual/comparator equipment? What kind of standards do you have in-place?
While this may be a cost you would prefer to avoid, in the end, it may benefit you sending them out to a qualified lab.
Just some thoughts.
H
Howard Lee
Tape a piece of paper to a drafting table. Put the square on the straight edge of the table and draw a line on the paper. Reverse the square on the edge of the table and draw another line on top of or next to the first line. If the square is undamaged, the lines will be parallel.
If you've got a shadowgraph/visual comparitor, throw it up on that and check it out. You're going to get an accuracy of 4:1 or better which is key to making any claims about 'calibration' of the square.
harry
I use this method but we termed it as verification and so far there are no problems from the auditors.
F
fireonce
It depends the precision your require,you may verify the squares with a much preciser than your precision requirement.
H
Howard Lee
harry, it's been many years since I took geometry in high school, won't say how many, but I believe that this method can be tied to a "Proof" that we did in class. I would like to meet the auditor that would question the basic foundations of mathematics.
H
Howard Lee
On second thought, maybe that wouldn't be so hard. Once upon a time I assisted an engineer that changed Pi in a line of program to make a measuring device work. Don't tell anyone, though, I was sworn to secrecy.:cool:
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
Mr Roo Work Instruction Authorization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
F Label work instruction - Medical Devices Manufacturing and Related Processes 1
I 2017/745 (MDR) - Instruction for use (IFU) - manufacturer's website EU Medical Device Regulations 15
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
J Standard Work Instruction Languages (IATF 16949 8.5.1.2) IATF 16949 - Automotive Quality Systems Standard 8
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
M EU Regulations or Standards for instruction for use (IFU ) EU Medical Device Regulations 3
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
Q Product Instruction for Use Manual (IFU) - Obligation to list the standard used 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
W CPU BIST IEC 62304 - Embedded code has CPU instruction tests IEC 62304 - Medical Device Software Life Cycle Processes 2
M Standard work, standardized work instruction & work instruction: What are differences IATF 16949 - Automotive Quality Systems Standard 7
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
0 Safety Instruction Card and Safety Work Instruction Document Control Systems, Procedures, Forms and Templates 3
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
G SOP or Work Instruction for PFMEA? FMEA and Control Plans 5
Z Internal Memo used to document work instruction Document Control Systems, Procedures, Forms and Templates 2
T Handling of Obsolete Material Work Instruction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Mention "according to Work Instruction" in Control Plan FMEA and Control Plans 3
alonFAI SMI (Solder Paste Inspection ) Inline Work Instruction (Procedure) Manufacturing and Related Processes 3
G Work Instruction Performance Measures Misc. Quality Assurance and Business Systems Related Topics 3
M ISO 9001 Work Instruction Structure Document Control Systems, Procedures, Forms and Templates 1
W Control of Document - Working Instruction and Checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Steps to Complete Quality Control Plans and Work Instruction Manufacturing and Related Processes 4
A Should I call this ?Blank Template? a Work Instruction? Document Control Systems, Procedures, Forms and Templates 11
Q Referencing a Specification in a Work Instruction as a ?Guidance Document? ISO 13485:2016 - Medical Device Quality Management Systems 1
C SOP Work Instruction (Job Card) Template Revisions question Document Control Systems, Procedures, Forms and Templates 6
K Intended Use wording: What is suitable for the instruction manual? EU Medical Device Regulations 4
A Definition Technical Work Instruction vs. Method Statement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
M Orthopedic IFU ( Instruction For Use ) EU Medical Device Regulations 3
J Control of equipment instruction manuals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
I Document Control - Instruction Manuals and Service Manuals General Measurement Device and Calibration Topics 2
C SS-EN ISO13485 Work Instruction Requirements for Dentures ISO 13485:2016 - Medical Device Quality Management Systems 2
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
M Looking for a Powder Coating Process Instruction Manufacturing and Related Processes 3
J Setting up Performance Review Instruction Phrases in my Company Human Factors and Ergonomics in Engineering 11
W FDA Labeling Requirements - Instruction for Use Content 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L ISO 17021:2011 - The Application of Annex A - Work Instruction Details General Auditing Discussions 9
T AS9100C Work Instruction Clarification - How detailed should a Work Instruction be? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B Work Instruction Application (Software for Document Control) Quality Assurance and Compliance Software Tools and Solutions 2
6 Instruction Manual for the production of Deionized Water Manufacturing and Related Processes 2
M Procedure & Work Instruction Flow Charting vs. Turtle Diagrams AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Audit Nonconformance? Employee References Work Instruction Internal Auditing 17
S Work Instruction template for Automotive Component (Refrigerator) Manufacturing and Related Processes 11
