Work Instruction vs. Reference Only document - Computer software use instructions
E
eohara - 2008
#11
Re: Work Instruction vs. Reference Only document
Ok, I have an idea on how to keep this simple.
I create the templates, and the authors document their instructions within my template. They become the ONLY approver. But, I keep the instructions in a central, controlled location.
Typically, my Work Instructions require 3-4 approvals, but in this case, the author is really the only approver. That keeps the whole process simple.
Hmmm...this just might work!
U
Umang Vidyarthi
#12
Hello Emily,
The 'instructions' given by the out going person can also be controlled by stamping it 'UNCONTROLLED' (as is being done on Engg.drawings), and the new incumbent can revise and endorse it by showing 'Rev.- 01'.
Hope this helps
Umang :bigwave:
Perhaps I was not able to put across my point properly. Let me retry. We use three stamps to mark our Drawings/documents, id-est :
1. CONTROLLED - Document currently in vogue.
2. UNCONTROLLED - In the process, may/may not qualify as a controlled document, but is good for reference at this point of time. viz :Engineering Drawing is being 'prepared by'....'checked by'....'approved by'.... different people at different point of time. During this journey it is stamped 'uncontrolled' and becomes a 'controlled' copy only after the final approval. Same applies to a lot of documents, like 'Inspection report' etcetra.
3. OBSOLETE - Not in vogue since superceded, yet retained, since may be revived in the future. Again good for reference only at this point of time.
So the 'Uncontrolled' too needs to be 'Controlled', that is the point I was trying to communicate.
Hope the doubts are cleared.
Umang :D
Wes Bucey
#13
Umang :D
Not for me. The definition of "uncontrolled" is faulty. Documents in the creation/approval phase are as much controlled as ANY controlled document. The point of control is primarily to assure an obsolete or as yet unapproved document is not used to perform any process within the organization, especially one which may then result in nonconforming product or service being created.
Helmut Jilling
Auditor / Consultant
#14
Excellent! - Simple, elegant, would work for most most, non-complex, not regulated industries. :applause:
Helmut Jilling
#15
...The biggest value of a controlled work instruction which is followed by each and every worker performing the task is that it provides a baseline for determining root causes of nonconformance AND simultaneously provides a baseline for potential improvement of the methods used in the process.
The biggest value I see is:
  1. SOP documents should describe the best practices and methods we know about a particular process.
  2. Requiring people to follow those SOPs is simply so we standardize around those best practices.
  3. Controlling the information (documents) is needed to ensure everyone is using the same information.
This combines and satisfies ISO and Lean into a simple concept. I think we ought to add these three sentences to our Doc Control Procedure, under "Purpose" - they would finally explain the intent.
U
Umang Vidyarthi
#16
Umang :D
You have re-iterated what I have already stated. May be, you perhaps missed the punch line in my post.
Umang :cool:
#17
Umang :cool:
I don't think he missed anything; you're saying that something that is controlled is stamped "uncontrolled." It's self-contradictory and makes no sense.
Wes Bucey
#18
Precisely! The stamp is the clinker in the grate.
U
Umang Vidyarthi
#19
["Documents in the creation/approval phase are as much controlled as ANY controlled document." - Wes Bucey]
During the creation/approval phase, these documents can not be stamped as "CONTROLLED". That is why they are being marked as "UNCONTROLLED", yet they are needed to be controlled at par with a controlled document!! I and Wes have said the same thing, to the best of my understanding, and also to the understanding of some of my customers based in USA (TS certified).
You are welcome to hold your opinion, as you deem fit, that is your prerogative.
Umang
Wes Bucey
#20
Umang
The point almost all document management systems make is any document not in general circulation, which has no approvals stamped or signed on it should not be used in a process. A document going through the authoring and approval process is NOT in general circulation and does not have such approvals on it; so, ipso facto, it is not usable in the same way a copy of a document which was previously approved, but may now be obsolete, might find its way into the hands of someone performing a process who could mistakenly accept it as a current document. Stamping such an in-process document "uncontrolled" is absolutely unnecessary and may needlessly confuse folks who might think it could be used as a reference when it may contain one or more errors which have not been caught in the approval process, creating havoc for folks who believe "uncontrolled" and "reference" are synonyms.
I find it easy to believe some folks with an "uncontrolled" stamp in their hands (regardless of who they work for) might be eager to stamp it on everything in sight, but that does not make it correct usage as promulgated by most document management experts.
A Changes to QRI (Quick Reference Instruction)? What I can or cannot change ISO 13485:2016 - Medical Device Quality Management Systems 2
M How do you reference a WI (Work Instruction) to a procedure? Document Control Systems, Procedures, Forms and Templates 16
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
Mr Roo Work Instruction Authorization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
F Label work instruction - Medical Devices Manufacturing and Related Processes 1
I 2017/745 (MDR) - Instruction for use (IFU) - manufacturer's website EU Medical Device Regulations 15
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
J Standard Work Instruction Languages (IATF 16949 8.5.1.2) IATF 16949 - Automotive Quality Systems Standard 8
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
M EU Regulations or Standards for instruction for use (IFU ) EU Medical Device Regulations 3
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
Q Product Instruction for Use Manual (IFU) - Obligation to list the standard used 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
W CPU BIST IEC 62304 - Embedded code has CPU instruction tests IEC 62304 - Medical Device Software Life Cycle Processes 2
M Standard work, standardized work instruction & work instruction: What are differences IATF 16949 - Automotive Quality Systems Standard 7
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
0 Safety Instruction Card and Safety Work Instruction Document Control Systems, Procedures, Forms and Templates 3
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
G SOP or Work Instruction for PFMEA? FMEA and Control Plans 5
Z Internal Memo used to document work instruction Document Control Systems, Procedures, Forms and Templates 2
T Handling of Obsolete Material Work Instruction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Mention "according to Work Instruction" in Control Plan FMEA and Control Plans 3
alonFAI SMI (Solder Paste Inspection ) Inline Work Instruction (Procedure) Manufacturing and Related Processes 3
G Work Instruction Performance Measures Misc. Quality Assurance and Business Systems Related Topics 3
M ISO 9001 Work Instruction Structure Document Control Systems, Procedures, Forms and Templates 1
W Control of Document - Working Instruction and Checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Steps to Complete Quality Control Plans and Work Instruction Manufacturing and Related Processes 4
A Should I call this ?Blank Template? a Work Instruction? Document Control Systems, Procedures, Forms and Templates 11
Q Referencing a Specification in a Work Instruction as a ?Guidance Document? ISO 13485:2016 - Medical Device Quality Management Systems 1
C SOP Work Instruction (Job Card) Template Revisions question Document Control Systems, Procedures, Forms and Templates 6
K Intended Use wording: What is suitable for the instruction manual? EU Medical Device Regulations 4
A Definition Technical Work Instruction vs. Method Statement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
M Orthopedic IFU ( Instruction For Use ) EU Medical Device Regulations 3
J Control of equipment instruction manuals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
I Document Control - Instruction Manuals and Service Manuals General Measurement Device and Calibration Topics 2
C SS-EN ISO13485 Work Instruction Requirements for Dentures ISO 13485:2016 - Medical Device Quality Management Systems 2
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
M Looking for a Powder Coating Process Instruction Manufacturing and Related Processes 3
J Setting up Performance Review Instruction Phrases in my Company Human Factors and Ergonomics in Engineering 11
W FDA Labeling Requirements - Instruction for Use Content 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L ISO 17021:2011 - The Application of Annex A - Work Instruction Details General Auditing Discussions 9
T AS9100C Work Instruction Clarification - How detailed should a Work Instruction be? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B Work Instruction Application (Software for Document Control) Quality Assurance and Compliance Software Tools and Solutions 2
6 Instruction Manual for the production of Deionized Water Manufacturing and Related Processes 2
M Procedure & Work Instruction Flow Charting vs. Turtle Diagrams AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
