Work Instruction vs. Reference Only document - Computer software use instructions
BradM
#21
Re: Work Instruction vs. Reference Only document
The point almost all document management systems make is any document not in general circulation, which has no approvals stamped or signed on it should not be used in a process. A document going through the authoring and approval process is NOT in general circulation and does not have such approvals on it; so, ipso facto, it is not usable in the same way a copy of a document which was previously approved, but may now be obsolete, might find its way into the hands of someone performing a process who could mistakenly accept it as a current document. Stamping such an in-process document "uncontrolled" is absolutely unnecessary and may needlessly confuse folks who might think it could be used as a reference when it may contain one or more errors which have not been caught in the approval process, creating havoc for folks who believe "uncontrolled" and "reference" are synonyms.
I find it easy to believe some folks with an "uncontrolled" stamp in their hands (regardless of who they work for) might be eager to stamp it on everything in sight, but that does not make it correct usage as promulgated by most document management experts.
Agreed, Wes. Nice post. Stamps are a tool to communicate a status of sorts to individuals; a signal to let them know something they otherwise would not have know without the stamp. If you have documents in process or whatever, employees should be trained well enough to know what they are should they see it. All controlled documents in our case have form numbers and revisions. Anything people see without that is uncontrolled, reference only, etc.
I have always found better luck in training/supporting a simple (but effective) system and developing understanding of why control is important.
W
Watchwait
#22
Wow! What a great discourse! Exactly the type of idea/thought exchanges I so appreciate on the Cove.
As it happens, we too have an "ongoing" dialogue about something we call "Desktop Instructions". They fall into the exact description/operational category previously described. This was something I have on the back burner, but now you guys have all made me feel guilty to the point of having to actually go after this issue.
BTW...how big of an issue has this been in the past? I'm fully aware of the *potential* of the issue, but speaking from past actual experience, has anyone been called out by ISO or FDA auditors on this issue?
#23
Actually, the standard clears it all up for us. 4.2.1 tells us what documents must be controlled, and what doesn't. For local documents, look at 4.2.1d) “documents need by the organization to ensure the effective planning, operation and control of its processes.”
Simply put, if any document is necessary to get the job done, it has to be controlled. A “for reference only” document tells me that we can remove that document and there will be no detrimental effect on the process. If removing the document adversely affects the process, then it must be controlled.
Mustang
#24
That's a good, simple way to think of it, DB! I'll try to remember that the next time someone asks about the difference. :thanx:
Something to remember: If a process/task/etc. is fairly stable, once it's created, controlling it shouldn't be too difficult, as changes won't be very frequent.
And to avoid confusion when a "controlled" document is going around for review, we package the new copy (marked "proposed") the existing copy (marked "current") and the Change Notice (what we use for sign-offs). This seems to keep people from getting confused.
Caster
An Early Cover
#25
My 2 cents. Forget the auditors, they are the last reason to do anything.
There have been and will always be costly errors from people following an incorrect method.
That's what it's all about. That's why the requirement for "control" got into ISO in the first place.
I'm always amazed at the effort people put into "gaming" the ISO system (desk procedures, uncontrolled stamps, etc). It shows me they have lost touch with (or never understood) the intent behind "control".
And yes, we got a finding for uncontrolled documents. A copy of a work instruction at a machine was stamped uncontrolled (I don't even know where they got that stamp from - perhaps someone got it at Staples on their own time).
The hard copy was three revs old, and the current version was on the intranet at the computer at the work area. The hard copy was on the desk, just beside the keyboard. Our system states the computer version is the master. Despite all this someone had printed a copy and thought they had made it all OK by stamping it uncontrolled. Our procedure makes no mention of "stamping things uncontrolled".
A bit of a surreal experience to live through.
Helmut Jilling
Auditor / Consultant
#26
...I'm always amazed at the effort people put into "gaming" the ISO system (desk procedures, uncontrolled stamps, etc). It shows me they have lost touch with (or never understood) the intent behind "control".
Bravo! :applause: (...and that's coming from an auditor, even...!)
W
Watchwait
#27
Caster - great reply! Though - I don't know as I'd go so far as to say "forget about the auditors..." A bit too bold for my FDA-driven world..:)
amariepsu
#28
How do you ensure your 'reference only' documents aren't out of date?
N
naghee
#30
The biggest value I see is:
  1. SOP documents should describe the best practices and methods we know about a particular process.
  2. Requiring people to follow those SOPs is simply so we standardize around those best practices.
  3. Controlling the information (documents) is needed to ensure everyone is using the same information.
This combines and satisfies ISO and Lean into a simple concept. I think we ought to add these three sentences to our Doc Control Procedure, under "Purpose" - they would finally explain the intent.
I totally agree with you...
this tells the user why we need these documents afterall
A Changes to QRI (Quick Reference Instruction)? What I can or cannot change ISO 13485:2016 - Medical Device Quality Management Systems 2
M How do you reference a WI (Work Instruction) to a procedure? Document Control Systems, Procedures, Forms and Templates 16
D Work Instruction Question ISO 13485:2016 - Medical Device Quality Management Systems 5
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
A Read instruction manual - What Graphic Symbol must I use? US Food and Drug Administration (FDA) 7
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
Mr Roo Work Instruction Authorization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
F Label work instruction - Medical Devices Manufacturing and Related Processes 1
I 2017/745 (MDR) - Instruction for use (IFU) - manufacturer's website EU Medical Device Regulations 15
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
J Standard Work Instruction Languages (IATF 16949 8.5.1.2) IATF 16949 - Automotive Quality Systems Standard 8
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
M EU Regulations or Standards for instruction for use (IFU ) EU Medical Device Regulations 3
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
Q Product Instruction for Use Manual (IFU) - Obligation to list the standard used 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
W CPU BIST IEC 62304 - Embedded code has CPU instruction tests IEC 62304 - Medical Device Software Life Cycle Processes 2
M Standard work, standardized work instruction & work instruction: What are differences IATF 16949 - Automotive Quality Systems Standard 7
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
0 Safety Instruction Card and Safety Work Instruction Document Control Systems, Procedures, Forms and Templates 3
L TS16949 Work Instruction Requirements IATF 16949 - Automotive Quality Systems Standard 7
G SOP or Work Instruction for PFMEA? FMEA and Control Plans 5
Z Internal Memo used to document work instruction Document Control Systems, Procedures, Forms and Templates 2
T Handling of Obsolete Material Work Instruction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Mention "according to Work Instruction" in Control Plan FMEA and Control Plans 3
alonFAI SMI (Solder Paste Inspection ) Inline Work Instruction (Procedure) Manufacturing and Related Processes 3
G Work Instruction Performance Measures Misc. Quality Assurance and Business Systems Related Topics 3
M ISO 9001 Work Instruction Structure Document Control Systems, Procedures, Forms and Templates 1
W Control of Document - Working Instruction and Checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Steps to Complete Quality Control Plans and Work Instruction Manufacturing and Related Processes 4
A Should I call this ?Blank Template? a Work Instruction? Document Control Systems, Procedures, Forms and Templates 11
Q Referencing a Specification in a Work Instruction as a ?Guidance Document? ISO 13485:2016 - Medical Device Quality Management Systems 1
C SOP Work Instruction (Job Card) Template Revisions question Document Control Systems, Procedures, Forms and Templates 6
K Intended Use wording: What is suitable for the instruction manual? EU Medical Device Regulations 4
A Definition Technical Work Instruction vs. Method Statement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
M Orthopedic IFU ( Instruction For Use ) EU Medical Device Regulations 3
J Control of equipment instruction manuals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
I Document Control - Instruction Manuals and Service Manuals General Measurement Device and Calibration Topics 2
C SS-EN ISO13485 Work Instruction Requirements for Dentures ISO 13485:2016 - Medical Device Quality Management Systems 2
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
M Looking for a Powder Coating Process Instruction Manufacturing and Related Processes 3
J Setting up Performance Review Instruction Phrases in my Company Human Factors and Ergonomics in Engineering 11
W FDA Labeling Requirements - Instruction for Use Content 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L ISO 17021:2011 - The Application of Annex A - Work Instruction Details General Auditing Discussions 9
T AS9100C Work Instruction Clarification - How detailed should a Work Instruction be? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B Work Instruction Application (Software for Document Control) Quality Assurance and Compliance Software Tools and Solutions 2
6 Instruction Manual for the production of Deionized Water Manufacturing and Related Processes 2
M Procedure & Work Instruction Flow Charting vs. Turtle Diagrams AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
