Work Instructions - Conflict? Toyota's method for creating work instructions
tony wardle
Registered Visitor
#11
Actually, "the standard" doesn't recommend work instructions, only that they are "available" as an option. If the work instruction isn't followed word by word, what's the point? Too many people DON'T follow the instructions word for word, because the work instructions are often poorly written or written by someone who has never done the work. Good, effective work instructions should be capable of being followed word by word!
I think Andy has it right.
My first round of WIs - I did the whole verbose thing. Explained things in detail, and like the McDonalds story had my staff follow the instruction to the T.
The problem here is common cause variation - the more things stay the same, the more they change. As a result - some may say the instruction wasnt well written - and for the most part they were not.
So, my solution was to put the detail into a training manual.
I change my WIs to a flow diagram protocol. The decision steps are the thinking steps (a diamond shape). These are the steps where human input can cause an oops.
The square blocks - or doing steps are quite vague. The doing step will refer to other documents ... to the detail.
Example - start the machine (ref training manual). Check temperature (ref specification). The WI is a general process overview with specifics being contained elsewhere.
What I figured was most important in a WI, is to tell the operator what to do when things didnt go as planned. If everything went as planned, why do you need the instruction? Chances are - operators do the same job day in and day out - they know the shortcuts - the second factory so to speak.
Those decision steps are where you need detail IMHO.
And yes, I am also a Taiichi Ohno fanboy - but - the Toyota Way is also subject to Kaizen.
Kronos147
#12
I'm turning around the order of your comments.
I really like this idea. I do it often. Many prefer pictures to words.
So, my solution was to put the detail into a training manual.....
IMO, that makes it tougher. Do you audit the training manual? Doesn't that make it easy for the Work Instruction and Training Manual to get out of sync? If the Training Manual and the Work Instructions are separate, will the operator ever see the Work Instructions? Will the Auditor have a finding that Work Instructions were not available at point of use due to the lack of knowledge of the operator?
I prefer to have a work instruction, and to train to the work instruction, and to audit the process referencing the work instruction, and check that training records reflect the work instruction.
There is a balance point between too detailed and too general. If a need for work instruction has been determined, it needs to be detailed enough to get the job done.
A side note, many of us vendors are further driven by the Boeing Production Readiness Assessments and the Business Continuity Planning requirements therein. That requires a certain amount of specificity in the work instructions, IMO.
Eric
tony wardle
Registered Visitor
#13
The training manual is not a closet document in our case.
Every operator earns a ''license'' to operate by doing training annually.
The training manual - although so called, is the statement of how we operate, and is ammended with lessons learned, machine, process, material changes - so its a living document.
The sync - is really just pointing to the training manual.
Example - we learn to drive, but dont need a WI to operate the vehicle everyday. We may need to retake our license annually though.
Same principle.
The other interesting thing is that here in South Africa, we have 11 different languages, and most people are not schooled in their mother tongue. I found this system to be most effective in our situation - and indeed have seen similar implemented in Germany at one of our sister companies.
We equally look at our systems and take the view - they must satisfy us first and the auditor last.
John Broomfield
#14
We tend to think of work instructions being a document that instructs a member of a process team how to complete a task.
But that type of document could more usefully be a record of the best known way of completing a task.
The former are audit criteria. The latter are used to manage knowledge.
Procedures (the documented kind) are used this way too.
Better to train people well and to invite them to discover new and improved ways than for the "we know best department" to stifle innovation.
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
U Intended Users in IFU (Instructions for Use) EU Medical Device Regulations 5
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
M User manual / instructions for use for class II device always required? Medical Device and FDA Regulations and Standards News 3
L MDR - Information in the instructions for use - clausole 23.4.(z) EU Medical Device Regulations 2
S ISO 18223-2 Temperature symbol in the Legend table in the Instructions for Use Other ISO and International Standards and European Regulations 4
S Providing IFU (Instructions for Use) in multiple languages EU Medical Device Regulations 0
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
Z IFU (Instructions for Use) Symbol - 7010:M002 - can it be in black? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
N Electronic Instructions for use (eIFU) EU Medical Device Regulations 2
Marc Elsmar Xenforo Software Instructions #2 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
Marc Elsmar Xenforo Software Instructions #1 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
M Batch record supersedes all other instructions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Updating class I device IFU with instructions to use class II cleared device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
K IATF 16949 Cl. 8.5.1.2 - Requirements of Work Instructions and Documents IATF 16949 - Automotive Quality Systems Standard 2
J Work Instructions - We have approx 1,000 work instructions from over the years Document Control Systems, Procedures, Forms and Templates 8
Ajit Basrur Incoming Inspection for Instructions for Use (IFU) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Product Instructions (IFU) - Placement Requirements - ISO 13485:2003/2016 Other ISO and International Standards and European Regulations 2
C Manufacturing Process Work Instructions - Format Manufacturing and Related Processes 4
D 207/2012 Update for MDR (?) - Instructions for Use (IFU) EU Medical Device Regulations 9
R How to Control Videos as part of the QMS Documented Procedures and Instructions Document Control Systems, Procedures, Forms and Templates 2
D eQMS/ERP System Admin Work Instructions - Where do they fit? Misc. Quality Assurance and Business Systems Related Topics 5
R ISO 50001 - Manual and instructions Sustainability, Green Initiatives and Ecology 8
C Following Order of Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 23
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
V Suggest Packing Instructions for Electrical Control panel Document Control Systems, Procedures, Forms and Templates 4
Q Allowed no manuals, technical instructions traceability in products ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Video Screencasts for Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Process Changes, but Work Instructions/Process Maps are not updated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
O Regulatory Notification for IVD IFU Instructions Revision ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Help sections in Software Programs as Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Should we have Work Instructions for HR or not Document Control Systems, Procedures, Forms and Templates 5
M Who should write Departmental Work Instructions Document Control Systems, Procedures, Forms and Templates 6
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
T Work Instructions for Assembly vs. Disassembly Misc. Quality Assurance and Business Systems Related Topics 11
S Do Work Instructions have to be in harmony with the related Control Plan? Document Control Systems, Procedures, Forms and Templates 1
Q ISO 9001 Requirement(s) for the Review of Work Instructions Document Control Systems, Procedures, Forms and Templates 11
M AS9100C Document Control for Machine Set Up Work Instructions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J IFUs (Instructions For Use) - EU e-Labeling 207/2012 EU Medical Device Regulations 15
T What to do when Employees are not following Instructions Human Factors and Ergonomics in Engineering 65
Q Symbols - Consult Instructions for Use Other Medical Device Related Standards 9
M Machine Shop Process Instructions (Traveler) question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
