Would like to remodel our QA Layout Laboratory - Your ideas appreciated
jager
Where do I start as far as design ideas, cabinet choices, the whole nine yards. I've been asked to help come up with ideas. I've been in the QA lab myself for about 20 years. It's basically the same, but over the years we've added cabinets, taken them away, added tables, taken them out, and put in a great vision system and comparator which take up most of the space. Now upper management has decided it is time to remodel and make the old lab look modern. I could use some ideas. Thanks!!
SteelMaiden
Re: Would like to remodel our QA Lab
Best thing we did in my last job was to use regular lab quality (acid resistant) counter surfaces.
jager
We are in a metal stamping company and this is a layout lab. Any ideas sure help. Thank you for that.
Duke Okes
- Use google images and see what you might find.
- Contact someone in another organization who you know has a layout lab and see how theirs is organized.
- Look in a magazine related to inspection (e.g., Quality Magazine).
Rand T
Who will be working in the area? If it was me, I would make sure that I asked my layout techs what they would like to see done to make their jobs easier.
SteelMaiden
Exactly, look at what work needs to be done, what the order is, look at your ergonomic requirements to perform that work with the least amount of shuffling the work around, etc. I don't know what is done in a layout lab, so beyond that, I am not much help.
jager
The lab is basically a 25x40' room with a large comparator, a cmm (vision rather than touch probe currently), surface plate, computer, desks, file cabinets, storage cabinets for gages and parts, work tables for working with blueprints, and the basic measuring tools like calipers, gage pins, radius gages, gage blocks, etc. We'd just like it to look more professional than it is. I'm checking some websites of companies that sell lab furniture and supplies. Some have some pictures of labs.
tomvehoski
I would really worry more about what works than what looks "professional". Fancy counter-tops and cabinets are not going to look too professional two years down the road if they are all beat up by steel parts, tool scratches, etc.
Look at what works or does not work right now. I'm in a similar setup. The owner talked about bringing in new cabinets, work benches, etc. that really would not help. I actually prefer to avoid cabinets because it allows for too much hiding of stuff you really don't need.
Our biggest flow issue is parts coming in from the shop floor for first and last piece inspections. Right now they get set on a workbench, so sometimes we may not notice a first piece is waiting, and holding up a machine. My plan is to move the file cabinet and tool drawers from the corner near the door to the "miscellaneous garbage" corner. The corner by the door will get a 4' wide shelf with dedicated places for first, last and hot incoming parts.
JAltmann
I would suggest a nice floor, either tile or epoxy paint, freshly painted walls. New cabinets/storage for all tools. People precive quality it things look nice, although i know know this does not mean quality.
As others have mentioned work with the end-users as to what they would like/suggest. Look at work flow paths, work areas/stations, etc. Take advantage of the opportunity being offered.
jager
Your places sounds a lot like ours. Thanks for the input. I do a lot of first piece and other production checks while doing annual PPAPs and new tooling layouts, multi-tasking like you probably do.
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
M Microbiological Testing Lab - Layout & Standards Other Medical Device Regulations World-Wide 0
E Layouts : Can you "verify" things that are not visible (such as loctite present, internal dimensions) in a layout ? APQP and PPAP 2
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
MDD_QNA Changing the Layout of Medical Device Label(s) CE Marking (Conformité Européene) / CB Scheme 3
A IATF 16949 Cl. 8.3.5.2 e) - Manufacturing Process Flow Charts & Layout IATF 16949 - Automotive Quality Systems Standard 5
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
M Annual Layout requirements for PPAP/Control Plan FMEA and Control Plans 6
D Implementing 5S for Multiple Shop Floor Layout Workstations Lean in Manufacturing and Service Industries 2
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
E ISO 17025 Compliant Laboratory Layout ISO 17025 related Discussions 3
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O Make Layout Higher Resolution? Using Minitab Software 1
O Matlab Layout Command to Increase Size Using Minitab Software 1
M Reporting Composite FCF on Layout (GD&T) Various Other Specifications, Standards, and related Requirements 4
Q Is there a recommended lab layout for a ISO TS requirement? General Measurement Device and Calibration Topics 3
N CMM Layout Data Dispute between two CMM Laboratories General Measurement Device and Calibration Topics 8
T Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001 Design and Development of Products and Processes 7
T Industry Standards for # of parts for Capability Study and Layout FAI's? APQP and PPAP 4
B TS 16949 PPAP/ Layout Inspection Frequency Requirements APQP and PPAP 8
Q Best tools to use to determine the best layout of a given area (Office) Process Maps, Process Mapping and Turtle Diagrams 9
L TS 16949 Clause 8.2.4.1 Layout inspection - Should we pay for this ? APQP and PPAP 4
N General Microbiological Laboratory Layout and Required Equipment General Measurement Device and Calibration Topics 6
C Warehouse Layout Design Lean in Manufacturing and Service Industries 11
I Layout Audit Requirements vs. Batch Inspections IATF 16949 - Automotive Quality Systems Standard 3
R Layout Inspection and Functional Testing - "Product" in 8.2.4.1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Howard Atkins Official TS answers from SMMT- Layout, System Audits, MR and Doc Control IATF 16949 - Automotive Quality Systems Standard 9
B Help with Submitting Part Layout Dimensionals - My first ever PPAP (to GM) APQP and PPAP 5
O The Layout of Dimensional Results and What to Provide the Customer APQP and PPAP 16
B Laboratory Layout - Please comment & give ideas on my proposal General Measurement Device and Calibration Topics 9
Z New Inspection Department Layout - 5S, Lean, etc... Lean in Manufacturing and Service Industries 4
H Lean Office and Office Layout - Sales, customer service, marketing, accounting, HR Lean in Manufacturing and Service Industries 4
S Plant Layouts - What should be in a Plant Layout? IATF 16949 - Automotive Quality Systems Standard 8
P Document Layout - Different layouts for documents depending upon the author Document Control Systems, Procedures, Forms and Templates 7
M 2 versions (different layout) of the same Quality Policy Document Control Systems, Procedures, Forms and Templates 3
L 'U-Shaped Flow' layout of a manufacturing plant Misc. Quality Assurance and Business Systems Related Topics 6
I Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
I Facility Planning and Layout Programs - Corolap & ALdep software? Design and Development of Products and Processes 2
S Layout inspection - product family approach? IATF 16949 - Automotive Quality Systems Standard 2
S Layout of the Manual of procedures Document Control Systems, Procedures, Forms and Templates 12
M Minitab macro vs. Layout tool Using Minitab Software 9
D Layout Inspection - Sound systems to a German car manufacturer IATF 16949 - Automotive Quality Systems Standard 2
V Plant Layout System from Scratch (AutoCAD) Manufacturing and Related Processes 4
R Layout Inspection Format and Improvement Document Control Systems, Procedures, Forms and Templates 1
C Layout Table (very large surface plate) Manufacturer Options - Warranty Hub Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
D Layout Of Management Review Meeting Form Management Review Meetings and related Processes 23
M How to use Excel to track files for PPAP or annual layout due dates Excel .xls Spreadsheet Templates and Tools 2
S Layout and Dimensional Inspection Training Training - Internal, External, Online and Distance Learning 0
