Would you Calibrate this Digital Hygrometer / Thermometer?
Q
QCALPINE
#11
Re: Would you calibrate this instrument?
Thanks to everyone for all the info. This is the first time I have posted a question and I can't believe all the helpful information I have received. While reading through one of our customers PO, it seems they require calibration including without limitation ISO-17025, ISO10012-1, and ANSI Z540. I have two that I am going to send out for ISO-17025 accrediated calibration. The three I have with just certificates of conformance I will use until I have the other two calibrated. Then I am going to place them side by side and see if how accurate the one's I just purchased are and hopefully document something to file that shows they were accurate.
It seems expensive $125 for an $18 instrument, but at least I won't have to worry about it. When I first started working here we had a calibrated one, stickered and all that was within it's window, but didn't read correctly I think it had been dropped. I tried to order one from VWR but they had none in stock and a 3 month estimated delivery date. So I bought the three cheap ones (they were in stock) so I at least had one that worked. I will check Fisher out next time I order. Luckily the broken one was hanging in place when an auditor went through. He checked to make sure it was calibrated and hadn't expired. I never volunteered the info it didn't work. Just replaced it as soon as I got the new ones.
Thanks again.
Thanks again
L
Libnani
#13
Dear all
I have a similar situation but my position is a bit different .
We are a laboratory and we are preparing to be accredited according to ISO17025 for the calibration of electrical parameters (Resistance , voltage ,..)
and we need a Temperature and humidity datalogger to take several values by day of the temperature in order to measure the variation of the temperature .
this variation wil be used in the calculation of uncertainty of calibration of a resistance .
My question , i receive from the supplier 2 options for the certifcate of calibration :
the first is a certifcate of calibration from an accredited laboratory
and the second is a manufacturer certificate of calibration which costs
5 times less .
As this instrument is used indirectly in my calibrations , can the manufacturer certifcate will be enough ?
thank you .
harry
#14
.....As this instrument is used indirectly in my calibrations , can the manufacturer certifcate will be enough ?
thank you .
The instrument may be used indirectly but its readings does have a direct effect on the integrity of the calibration results. Therefore it must be calibrated by an accreditated lab.
L
Libnani
#15
I know it should be calibrated , but my question :
is it necessary to be calibrated by an accredited laboratory or it can be calibrated by the constructor which is certified ISO 9001 (5 times less cost) .
BradM
#17
Need calibration from a lab accreditated to ISO 17025 standard.
Agreed.:agree1:
I realize you are trying to save money. I would see the 150725 being a little more costly (as the cliche goes, though, you get what you pay for), the cert for five times less would scare me. Do get a couple of quotations, though.
Dmokong - 2009
#18
Good day to all,
In my experience in calibration of Thermo-Hygrometer, I have encountered units which has error even though they are newly purchased. So I believed that your equipment for monitoring your temp and humidity should be calibrated. Even though they are certified by the manufacturer, this doesn't mean that it is functioning properly or accurately after they are shipped out to distributor/retailer. Also, the thermo-hygrometer sensors are very sensitive to contamination.
P How to Calibrate a HP 3458A Digital Multimeter with Fluke 5080A calibrator General Measurement Device and Calibration Topics 1
D How to Calibrate any Digital Sphygmomanometer under use for 2 years in a Hospital Forum News and General Information 1
V Calibration of a Digital Vernier - Need to check/calibrate/validate all 3 functions? General Measurement Device and Calibration Topics 9
D Special techniques when you calibrate digital micrometers? General Measurement Device and Calibration Topics 2
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
I Can I Calibrate On Demand? General Measurement Device and Calibration Topics 9
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
F Crimper Calibration - How do you Control & Calibrate your crimpers? Calibration Frequency (Interval) 13
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
K New Kilogram - The process we use to calibrate the standards General Measurement Device and Calibration Topics 6
L Re-calibrate after software update? Calibration Frequency (Interval) 3
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
N Calibrate temperature on refrigerated Centrifuges? General Measurement Device and Calibration Topics 2
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
D Lesser expensive to calibrate various test weights General Measurement Device and Calibration Topics 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
P How do you calibrate a VNA (Vector Network Analyzer) cal kit? General Measurement Device and Calibration Topics 4
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
bobdoering Who says you can't calibrate a steel rule! Funny Stuff - Jokes and Humour 14
S How can I Calibrate a Biosafety Cabinet? General Measurement Device and Calibration Topics 1
C How to Calibrate a Viscosity Tester General Measurement Device and Calibration Topics 3
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
C How to Calibrate a Medical Infrared Thermometer General Measurement Device and Calibration Topics 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
J What do you use to Calibrate 40" Calipers General Measurement Device and Calibration Topics 10
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
C Tolerance Estimation of a Load Cell I want to Calibrate General Measurement Device and Calibration Topics 9
D Procedure on How to Calibrate a External Micrometer General Measurement Device and Calibration Topics 1
B ISO/TS 16949 Section 7.6.3 - Use of Manufacturer to Calibrate IATF 16949 - Automotive Quality Systems Standard 21
W How to verify/calibrate a Neptune Water Meter General Measurement Device and Calibration Topics 4
N Laboratory that is able to Calibrate Dew Point Meter up to 60?Cdp - Needed General Measurement Device and Calibration Topics 1
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
C How to calibrate or control patterns for fiberglass General Measurement Device and Calibration Topics 4
N Scale with Internal Calibration - Do I need to calibrate? How to document this? Calibration Frequency (Interval) 8
I Need help finding an Accredited Lab that can Calibrate Brunson 76-RH Survey Transits General Measurement Device and Calibration Topics 5
M Controlling Temperature and Time - Do I need to calibrate the thermostat? IATF 16949 - Automotive Quality Systems Standard 4
D How much Tolerance do I use to Calibrate a 150kgs capacity Scale? General Measurement Device and Calibration Topics 5
M To Calibrate or Not to Calibrate various Weight Scales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
N Thermocouple Inhomogeneity - Need to calibrate a roll of 50m thermocouple type K General Measurement Device and Calibration Topics 3
J Calibrate before use required? Inspection Gages and Measurement Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Traceability for Mercury Argon Calibration Source to Calibrate a Spectrometer? General Measurement Device and Calibration Topics 5
P How to Calibrate Laser Micrometer when no Calibration Company in the Country? General Measurement Device and Calibration Topics 3
S 3 Point Calibration or Calibrate to Extreme High and Low? General Measurement Device and Calibration Topics 9
C Seeking a holder/jig to calibrate large OD micrometer calipers (up to 23") General Measurement Device and Calibration Topics 8
