Writing our Standard Operating Procedures - Examples wanted
JaneB
#21
Mr Brahmaiah,
Here's a suggestion - why not post your own definitions of these (with examples) to add something to a debate, if it you really are interested in debating it. I'm sure a person of your calibre has a firm view.
Otherwise, as has been said:
This issue has been discussed many times...
It seriously doesn't matter what they're called, nor whether one person's 'procedure' is another's 'work instruction'. As far as I'm concerned, you can and could call 'em maps, guidelines, procedures, instructions, how to's, even yellow bikkies or whatever else takes your fancy.
JaneB
#22
I was also wondering if anyone had an example of a change control procedure example. Anything you have would be great. Thanks
More info needed, such as:
1. Have you first searched the attachments?
2. In what context? ie, what field are you in.
Also: you're much more likely to get a useful response if start your own thread with what you want in the title, and giving the kinds of info I've outlined above. Many people may have given up on this thread, and thus will never find this particular request of yours hidden away as it is.
brahmaiah
#23
Mr Brahmaiah,
It is not the same if you call an SOP A WI or a procedure.It is essential to define an SOP to make a distinction from a Work Instruction and a Procedure.I personally feel that an SOP is a readily understandable /readerfriendly chart displayed in a work place.
A work instruction or a procedure cannot be called an SOPas it is being called by many now.But an SOP contains information which may be found in both WI and procedure. I would select some examples next time after referring to my database.
I thing it we can not conclude this topic by saying "what is in a name?"
V.J.Brahmaiah
JaneB
#24
Why?
A work instruction or a procedure cannot be called an SOP as it is being called by many now.
Why not?
Interesting. The nub of it is that this is what you think it is. Others can, do and will think differently. That's why the 'what's in a name?' point : opinions do vary, and I don't see this as a difficulty on this particular subject, providing that in any one particular organisation everyone's working off much the same understanding.
An interesting definition you've provided, and unique ("a readily understandable /readerfriendly chart displayed in a work place") - many might call that a WI. Or a work aid. Or a process aid, or any one of a dozen other terms.
This definition I suspect would be hotly contested by others. Mind you, I could wish that more things people call SOPS were readily understandable and/or user friendly, so I'm with you there. (And glad to see you're presenting it as an opinion rather than a mandated fact)
Assuming you're saying one can't conclude a topic by saying 'what's in a name', why not?
brahmaiah
#25
Why?
Why not?
A definition for a Technical term is a must if we go ahead in documenting a process.No doubt SOP is a work instruction and also it can be a procedure.But it is a unique thing called 'sop'.So it should have a specific definition.Because a work instruction should not be called an SOP and a procedure shoulld not be called an SOP.
Well you may still defuse the tension by saying 'WHAT,S IN A NAME'
V.J.Brahmaiah
Peter Fraser
#26
V.J.Brahmaiah
SOP = "Standard Operating Procedure", so it is by definition a type of "procedure". To my mind, the use of the words "Standard" and "Operating" add nothing, since i) if a procedure isn't standard then by implication you may or may not have to follow it, and ii) I can't think of an example of a procedure which describes how not to do something (ie "operate").
And I find that "Work Instruction" is normally used to describe in more detail how a specific task should be carried out.
Helmut Jilling
Auditor / Consultant
#27
My advice would be different. I have seen so many procedures over the years, and they often provide little value. I would advise you to simply define one procedure for each process you defined in your system (ref. ISO cl 4.1). Then, you and the process owner should discuss what you want to say to your audience for each process. Let it contain things to do, things not to do, who is responsible for which activities, links to other key processes, best practices and lessons learned over time. Plan to add content frequently, as you think of additional things. ISO does not require any specific format. If you do this, then one day, it might be YOUR procedures that people will use as an example.
JaneB
#28
V.J.Brahmaiah
I disagree that SOP is a 'technical term' or even a 'unique' thing. What's technical or unique about it? Nothing to my mind.
A Standard Operating Procedure is, as Peter points out, a type of procedure. Adding 'Standard Operating' to the start of that just adds words - after all, don't we want or expect people to follow procedures in any case? Not to mention the unpleasant SOP acronym! I suspect this may well be more 'technical' and 'unique' in particular environments - perhaps particularly the automative manufacturing ones you appear to be very familiar with. Many of my clients would sooner die than have things called 'SOPs' to contend with - well not die, perhaps, but they don't like the term and don't want it.
because a work instruction should not be called an SOP and a procedure shoulld not be called an SOP.
You haven't offered any convincing argument here - clearly you prefer them all to be Very Different Things. Fine - go right ahead. But I doubt the rest of the world will follow or agree.
N Writing our Standard Operating Procedures for Dietary Supplement Co - Examples wanted Document Control Systems, Procedures, Forms and Templates 7
K SOP for writing/drafting SOP (Standard Operating Procedure) Document Control Systems, Procedures, Forms and Templates 7
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
S Brazilian Standard Compliance for Writing Instruments - Inmetro RoHS, REACH, ELV, IMDS and Restricted Substances 2
K What the industry standard is for attribute gage tolerances - In Writing General Measurement Device and Calibration Topics 7
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
S IAQG guidelines for AS9100 report writing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
I Writing a Cosmetic Criteria for Switches Document Control Systems, Procedures, Forms and Templates 1
N GDP - Having to provide a reason when writing N/A? ISO 13485:2016 - Medical Device Quality Management Systems 1
R MDR 745/2017 keynote - I'm a student and I'm writing a thesis EU Medical Device Regulations 4
Q Writing Reports - Releasing Data into our Documentation System Document Control Systems, Procedures, Forms and Templates 1
P Secretly Auditing - Writing an audit report with observations based on my experiences Internal Auditing 12
V Writing a Pre-Submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 47
A Self-study plan to improve fluency in English speaking, writing After Work and Weekend Discussion Topics 3
A Audit report writing course - Suggestions wanted Internal Auditing 9
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
dubrizo Audit Findings: Writing against Internal an ISO Clause Internal Auditing 10
A Writing an Internal Audit Report Finding for Employee Awareness of QMS Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Writing appropriate ISO 13485 Audit Report Findings Internal Auditing 15
J Technical Writing - Help Training Supervisors in the Basics Training - Internal, External, Online and Distance Learning 6
Pancho Writing, it is. How's this related to quality? The Reading Room 6
K Process Writing Software Suggestions for Internal Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Struggling With Writing PA (Preventive Action) Procedure Preventive Action and Continuous Improvement 11
x-files Procedure writing - Section - Related documents Document Control Systems, Procedures, Forms and Templates 8
insect warfare Guidance on Writing in Plain English Quality Tools, Improvement and Analysis 24
C Writing a Sterilization Procedure when the Process is Subcontracted - ISO13485 Quality Management System (QMS) Manuals 1
C Writing Quality Management Plans for a Tender Submission Quality Manager and Management Related Issues 4
M Writing a Manufacturing Recall Procedure Document Control Systems, Procedures, Forms and Templates 3
M Writing a Minitab macro that can manipulate data in all columns Using Minitab Software 3
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
D Writing Minutes (Records) from Management Review Meetings Quality Manager and Management Related Issues 11
V Where to add SOP of writing a Technical File in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
B Seeking help in writing marketing message Career and Occupation Discussions 12
G Writing up BRC audit non-conformance Internal Auditing 9
A Writing a Procedure for Validation of an Analytical Method General Measurement Device and Calibration Topics 5
AnaMariaVR2 Free Online 'Writing in the Sciences' Course Training - Internal, External, Online and Distance Learning 2
B Seeking help in writing an audit report that can stand on the court Internal Auditing 6
T Generic Guides for Procedure Writing Document Control Systems, Procedures, Forms and Templates 20
B Developing a Queue Management Procedure - Need some help writing a Proposal Quality Manager and Management Related Issues 2
Miner Writing Minitab Macros Using Minitab Software 6
B Writing a Customer Survey......Any tips? Customer Complaints 13
S Writing a Test Method Validation Procedure as well as Validation of Test Methods General Measurement Device and Calibration Topics 1
Moncia Writing a new Quality Manual for my new company - Need help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Having trouble writing a directive (procedure) that points to the right place ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C NON-ISO Laboratory Scope Writing (for the Fire Marshal) Design and Development of Products and Processes 3
F Starting a Quality Control Program and writing a Quality Control Manual Quality Manager and Management Related Issues 10
sagai What is CD writing considered as - for Device-Only SW? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
AnaMariaVR2 [White Paper] Writing & Enforcing Your SOPs for GxP Compliance Success Document Control Systems, Procedures, Forms and Templates 0
S HACCP for Animal Feed - Writing a form and report about Animal Feed Food Safety - ISO 22000, HACCP (21 CFR 120) 10
