Writing our Standard Operating Procedures - Examples wanted
K
kev4791
#51
Just to follow up on previous. Wouldnt' these procedures already be outlined within your Manual, so do they need expanding and reiterating on separate documents?????
harry
#52
It seems to me that you are trying to fit what your organization does around the requirements of the standard - which shouldn't be the way to go.
For a start, why not identify the processes that a project goes through from enquiry stage to tender stage and then to completion (as practiced in your organization). We can help you from there on.
K
kev4791
#53
Hi Harry,
I have drawn up an outline proces map for both the tender stage and contract delivery, but this still needs finalising and the actual processes clearly identified/defined. Once this is done do I need to write up an individual document for each one???
harry
#54
Hi Harry,
If your processes are drawn up according to how your organization operates, you would generally have one or more procedures to cover each (or several) of them and within it identify how you meet the requirements.
Example, you will normally have an inspection & test procedure where you identify what you inspect, who, when & where and what equipments you use. Normally this is where calibration comes in. Work instructions to describe in more detail such as sampling of concrete and relevant forms to record data will come in next.
K
kev4791
#55
Harry,
I may be getting things wrong here, but...
Within my quality system manual e.g. under Procedure 04 Document Control 4.2.3 it has 2/3 paragrpahs which define where the master copies are stored, who has access, who issues documents, how drawings are marked/superseded etc etc.
Is this not sufficient without writing a separate procedure. Maybe my manual is in the wrong format but never had any issues previously.
This is possibly why my manual seems a bit long winded. Its roughly 40 pages long. Bear in mind I ain't no Quality Manager officially, just an engineer who is trying to develop a better system.!
harry
#56
..........Within my quality system manual e.g. under Procedure 04 Document Control 4.2.3 it has 2/3 paragrpahs which define where the master copies are stored, who has access, who issues documents, how drawings are marked/superseded etc etc.
Is this not sufficient without writing a separate procedure. Maybe my manual is in the wrong format but never had any issues previously.............
Document control will come in elsewhere also - such as construction control or operations or whatever you name it as well as contract management. For operations, you need to control the documents at 'site'. If it is not covered in your Doc. control procedure, just describe it in your your operations procedure. If it is covered, just referenced it.
JaneB
#57
Great - keep going on 'trying to develop a better system' and avoid the long-winded, verbose and over-documented monstrosities.
Harry's given you good advice. Keep going along the lines you're going...
There are way too many long-winded so-called 'Quality Manuals' around. Don't add to 'em.
Helmut Jilling
Auditor / Consultant
#58
Question....Can I combine our procedures and work instructions into one document and just call them WORK INSTRUCTIONS???.......
Sorry, I haven't had the time to read thru this thread to find my answer......:)
Thanks for your help!!
That is up to you. In many cases, it probably makes sense. It does not matter what you call them.
Helmut Jilling
#59
Harry,
While you don't want to be unnecessarily long-winded, don't make the number of pages your primary focus. It is irrelevant. Write what you want to say to your auditence, and keep improving content. That is the only thing that matters. The last manual I wrote was 30+ pages, but it had good content.
#60
This is good advice, imo--the manual should be as big as it needs to be, and if it takes 30 pages, that's OK. One of the problems I frequently see that leads to excessive volume in QMs is wordiness, however. Too many words are used to express a thought or requirement, often in the belief that using a lot of words somehow adds gravity to the text. It doesn't--it just makes it more difficult to read and understand, and diminishes the likelihood that anyone will use or read the manual.
To demonstrate, I picked a manual more or less at random from the Post Attachments list, and selected the following passage:
The company shall establish and maintain a documented procedure for the identification, storage, retrieval, protection and disposal of quality records. These quality records demonstrate conformance to requirements and effective operation of the QMS.
Individual departments or functions will be responsible for the collation, maintenance and disposal of relevant records. In general, such records are normally maintained for a defined retention period of 5 years. However where required for legal or knowledge retention purposes, this retention period may be longer.
This can be compressed as follows without loss of meaning:
We have a documented procedure for quality records that satisfies the requirements of the standard. Each department is responsible for maintenance and disposal of records. Records are maintained for five years, except in cases where business needs dictate a different period.
The passage has been reduced by half without losing anything meaningful. The manual from whence came the original runs to 32 pages; it could probably be reduced in size by half just by fixing the wordiness of it.
N Writing our Standard Operating Procedures for Dietary Supplement Co - Examples wanted Document Control Systems, Procedures, Forms and Templates 7
K SOP for writing/drafting SOP (Standard Operating Procedure) Document Control Systems, Procedures, Forms and Templates 7
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
S Brazilian Standard Compliance for Writing Instruments - Inmetro RoHS, REACH, ELV, IMDS and Restricted Substances 2
K What the industry standard is for attribute gage tolerances - In Writing General Measurement Device and Calibration Topics 7
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
S IAQG guidelines for AS9100 report writing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
I Writing a Cosmetic Criteria for Switches Document Control Systems, Procedures, Forms and Templates 1
N GDP - Having to provide a reason when writing N/A? ISO 13485:2016 - Medical Device Quality Management Systems 1
R MDR 745/2017 keynote - I'm a student and I'm writing a thesis EU Medical Device Regulations 4
Q Writing Reports - Releasing Data into our Documentation System Document Control Systems, Procedures, Forms and Templates 1
P Secretly Auditing - Writing an audit report with observations based on my experiences Internal Auditing 12
V Writing a Pre-Submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 47
A Self-study plan to improve fluency in English speaking, writing After Work and Weekend Discussion Topics 3
A Audit report writing course - Suggestions wanted Internal Auditing 9
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
dubrizo Audit Findings: Writing against Internal an ISO Clause Internal Auditing 10
A Writing an Internal Audit Report Finding for Employee Awareness of QMS Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Writing appropriate ISO 13485 Audit Report Findings Internal Auditing 15
J Technical Writing - Help Training Supervisors in the Basics Training - Internal, External, Online and Distance Learning 6
Pancho Writing, it is. How's this related to quality? The Reading Room 6
K Process Writing Software Suggestions for Internal Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Struggling With Writing PA (Preventive Action) Procedure Preventive Action and Continuous Improvement 11
x-files Procedure writing - Section - Related documents Document Control Systems, Procedures, Forms and Templates 8
insect warfare Guidance on Writing in Plain English Quality Tools, Improvement and Analysis 24
C Writing a Sterilization Procedure when the Process is Subcontracted - ISO13485 Quality Management System (QMS) Manuals 1
C Writing Quality Management Plans for a Tender Submission Quality Manager and Management Related Issues 4
M Writing a Manufacturing Recall Procedure Document Control Systems, Procedures, Forms and Templates 3
M Writing a Minitab macro that can manipulate data in all columns Using Minitab Software 3
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
D Writing Minutes (Records) from Management Review Meetings Quality Manager and Management Related Issues 11
V Where to add SOP of writing a Technical File in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
B Seeking help in writing marketing message Career and Occupation Discussions 12
G Writing up BRC audit non-conformance Internal Auditing 9
A Writing a Procedure for Validation of an Analytical Method General Measurement Device and Calibration Topics 5
AnaMariaVR2 Free Online 'Writing in the Sciences' Course Training - Internal, External, Online and Distance Learning 2
B Seeking help in writing an audit report that can stand on the court Internal Auditing 6
T Generic Guides for Procedure Writing Document Control Systems, Procedures, Forms and Templates 20
B Developing a Queue Management Procedure - Need some help writing a Proposal Quality Manager and Management Related Issues 2
Miner Writing Minitab Macros Using Minitab Software 6
B Writing a Customer Survey......Any tips? Customer Complaints 13
S Writing a Test Method Validation Procedure as well as Validation of Test Methods General Measurement Device and Calibration Topics 1
Moncia Writing a new Quality Manual for my new company - Need help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Having trouble writing a directive (procedure) that points to the right place ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C NON-ISO Laboratory Scope Writing (for the Fire Marshal) Design and Development of Products and Processes 3
F Starting a Quality Control Program and writing a Quality Control Manual Quality Manager and Management Related Issues 10
sagai What is CD writing considered as - for Device-Only SW? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
AnaMariaVR2 [White Paper] Writing & Enforcing Your SOPs for GxP Compliance Success Document Control Systems, Procedures, Forms and Templates 0
S HACCP for Animal Feed - Writing a form and report about Animal Feed Food Safety - ISO 22000, HACCP (21 CFR 120) 10
