Writing Test and Inspection Procedures
ttwerp65 - 2009
I am currently researching Test and Inspection procedures for ISO9000:2001. I have "googled" to get some ideas on how it is being done, but I am still feeling I need more definition.
Our current quality policy states two levels of inspection. Our company policy at this time is that we inspect in accordance to what level the customer desires. When we have a specific requirement for levels of inspection we adjust price of parts accordingly. If it is not regulated by contract, we inspect an precentage of each lot to verify the conformity of our products.
The first question is can this policy be written into our ISO9000:2001
manual?
My second question deals with the documentation of tooling used to verify conformity. We at this time have not been asked to document tooling used, but is it required. Our current policy addresses the need for routine calibration checks to the standard, and we follow it to the letter. We have addressed competance issue and have documented who does the inspection and what skill/training they have, but is that enough?
Our inspection record document is compatible for tooling documentation and we are not opposed to doing this, but I know that if it is documented we have to do it. Do we have to open that door?
I would greatly appreciate some feedback.
thanks,
Terry:D
CarolX
manual?
Absolutely - unless you have specific contractual requirements, it is up to you to determine the sampling plan to use.
Does it work for you. There is no specific requirement that says you have to specify exactly which type of measuring equipment to use. For example - part of our inspection procedure for parts of the punch press states to measure material thickness. We do not say specifically what to use - i.e. a micrometer or caliper. But you must decide the level of detail needed for your procedures. My description above may not be sufficient for a manufacture of space shuttle components.
It is up to you. All depends of the level you need to control your process.
Hope this helps a bit.
ttwerp65 - 2009
Carol,
Once again, thanks for your feedback. All of the research I have done has appeared to confirm what you have stated. I was hoping that this was the case. Our company does work for farmer joe to aircraft, so having some flexibility helps.:thanx:
Coury Ferguson
Moderator here to help
What about recieving inspection??
Receiving Inspection would be handled the same way. If there is a critical need to ensure/control processes and that product received from suppliers meets drawing and specification requirements than document a Receiving Inspection instruction (even though there is no requirement in ISO9001:2000 that I am aware of). The sampling plan would be based upon known standards (obsoleted 105 and current ANSI), in my opinion.
ttwerp65 - 2009
Thanks pmwong,
your procedure is very closo to the one I have at this time. The only thing I see as diffrent is your refrences to the A.Q.L's. I appreciate your time. I am having our gap analysis today.:notme: I am actually looking forward to thia process. I have done alot of research and I have got to a point where I could use some further direction. The organization I have chose to work with has been very in formative. Also, this forum rocks! Elsmar cove and its participants have been wonderful. They have heped me get thru many "stuck" area's. Once again thanks and God bless!!:D
S Writing a Test Method Validation Procedure as well as Validation of Test Methods General Measurement Device and Calibration Topics 1
T Writing Test Procedures for Medical Devices Other Medical Device and Orthopedic Related Topics 3
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
S IAQG guidelines for AS9100 report writing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
I Writing a Cosmetic Criteria for Switches Document Control Systems, Procedures, Forms and Templates 1
N GDP - Having to provide a reason when writing N/A? ISO 13485:2016 - Medical Device Quality Management Systems 1
R MDR 745/2017 keynote - I'm a student and I'm writing a thesis EU Medical Device Regulations 4
Q Writing Reports - Releasing Data into our Documentation System Document Control Systems, Procedures, Forms and Templates 1
P Secretly Auditing - Writing an audit report with observations based on my experiences Internal Auditing 12
V Writing a Pre-Submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 47
A Self-study plan to improve fluency in English speaking, writing After Work and Weekend Discussion Topics 3
A Audit report writing course - Suggestions wanted Internal Auditing 9
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
dubrizo Audit Findings: Writing against Internal an ISO Clause Internal Auditing 10
A Writing an Internal Audit Report Finding for Employee Awareness of QMS Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Writing appropriate ISO 13485 Audit Report Findings Internal Auditing 15
J Technical Writing - Help Training Supervisors in the Basics Training - Internal, External, Online and Distance Learning 6
Pancho Writing, it is. How's this related to quality? The Reading Room 6
K Process Writing Software Suggestions for Internal Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Struggling With Writing PA (Preventive Action) Procedure Preventive Action and Continuous Improvement 11
x-files Procedure writing - Section - Related documents Document Control Systems, Procedures, Forms and Templates 8
S Brazilian Standard Compliance for Writing Instruments - Inmetro RoHS, REACH, ELV, IMDS and Restricted Substances 2
insect warfare Guidance on Writing in Plain English Quality Tools, Improvement and Analysis 24
C Writing a Sterilization Procedure when the Process is Subcontracted - ISO13485 Quality Management System (QMS) Manuals 1
C Writing Quality Management Plans for a Tender Submission Quality Manager and Management Related Issues 4
M Writing a Manufacturing Recall Procedure Document Control Systems, Procedures, Forms and Templates 3
M Writing a Minitab macro that can manipulate data in all columns Using Minitab Software 3
H Writing a Product Label Inspection Work Instruction Manufacturing and Related Processes 2
D Writing Minutes (Records) from Management Review Meetings Quality Manager and Management Related Issues 11
V Where to add SOP of writing a Technical File in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
B Seeking help in writing marketing message Career and Occupation Discussions 12
G Writing up BRC audit non-conformance Internal Auditing 9
A Writing a Procedure for Validation of an Analytical Method General Measurement Device and Calibration Topics 5
AnaMariaVR2 Free Online 'Writing in the Sciences' Course Training - Internal, External, Online and Distance Learning 2
B Seeking help in writing an audit report that can stand on the court Internal Auditing 6
T Generic Guides for Procedure Writing Document Control Systems, Procedures, Forms and Templates 20
B Developing a Queue Management Procedure - Need some help writing a Proposal Quality Manager and Management Related Issues 2
Miner Writing Minitab Macros Using Minitab Software 6
N Writing our Standard Operating Procedures for Dietary Supplement Co - Examples wanted Document Control Systems, Procedures, Forms and Templates 7
B Writing a Customer Survey......Any tips? Customer Complaints 13
Moncia Writing a new Quality Manual for my new company - Need help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Having trouble writing a directive (procedure) that points to the right place ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C NON-ISO Laboratory Scope Writing (for the Fire Marshal) Design and Development of Products and Processes 3
F Starting a Quality Control Program and writing a Quality Control Manual Quality Manager and Management Related Issues 10
sagai What is CD writing considered as - for Device-Only SW? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
AnaMariaVR2 [White Paper] Writing & Enforcing Your SOPs for GxP Compliance Success Document Control Systems, Procedures, Forms and Templates 0
S HACCP for Animal Feed - Writing a form and report about Animal Feed Food Safety - ISO 22000, HACCP (21 CFR 120) 10
J Acceptable Tolerance Range for Freezer - Writing an IQ/OQ for a Freezer US Food and Drug Administration (FDA) 2
