CliffK,
Unfortunately, probably so.
The issues related to this post resulted from an internal audit in which the 'process owner' argued against the nc using the explanation /logic that the auditor "didn't understand the process". Now, if the trained and papered internal auditor couldn't understand the process and evidence was offered and documented during the audit from interviews and observations made during the audit that floor workers didn't understand the process, then it's very likely that the process is ineffective.
We're probably facing re-writing most all of our documents to simply the system and get away from the "ISO Speak Techno Jargon" which is more similar to Code of Federal Regulation sort of construction. Keep in mind that the entire company is 20 people.
Should we torch it and start over?
My previous post was going in at the same time as your last one.
Ok, given your follow-up, here's my Rev 1 thought process. Do the floor workers not understand the process map, or not understand the process? To me, there is a difference.
Set aside the process map for a second. I guess I am trying to determine how this place runs. Do they make good product? Are they following their written guidelines/procedures? Is the organization striving towards improving their quality system?
The extent of the revision is up to you. If they have a good system in place, the process map may do good to mimic what is already working, as opposed to some theoretical model out of a book. Or, a new process will improve this situation. Regardless, management should be on board for this venture.
Quality systems are about making good product and increasing profit. How you think this process map situation would work towards that end is the best solution.
