X-Bar Chart - CQE Problem to Solve
Mehtap
Could anyone can tell me where I can find the information about this question below? I keep checking the books but I can not find the answer.
An x bar- R chart with n=5 has been plotted for some time and has demonstrated random variation. Upon review of the last 30 plot points, the expected number of runs around the center line on the x bar chart is expected to be approxiametely which number?
K
kg209
When I was studying for my CQE I had the CQE primer from the Quality Council of Indiana. The answer to this question was in Chapter 10 if I remember correctly. If you are studying for your CQE I highly recommend QCI primers. I studied hard but with the primer's help I was able to pass on my first attempt.
KG
Tim Folkerts
If I had to make an off-the-cuff answer, I would say 15 runs.
If the data is random, then whichever side of center the current point is, there is a 50-50 chance the next the next point will be on the opposite side of the center. So there is a 50-50 chance that the next point will start a new run on the other side of the center. That would suggest 15 runs.
Or try with smaller numbers and look for a pattern.
With a single point, there can only be one run :)
With two points, you get either 1 or 2 runs. They could be symbolized as
·· .. (1 run)
·. .· (2 runs)
The average is 1.5 runs
With three points, you can have
... ··· (1 run)
..· .·· ·.. ··. (2 runs)
·.· .·. (3 runs)
the average is (1+1+2+2+2+2+3+3)/8 = 2
By extension, it appears the average is (n+1)/2.
So 30 points would have an average of (30+1)/2 = 15.5 runs.
bobdoering
Stop X-bar/R Madness!!
Unless you define a "run" using Western Electric Rules of 7 above, 7 below, 7 going up and 7 going down. Also, in the same vein, if it was random you would not expect any "runs", as you expect it to be "in control" from the expected data extrapolation from how the process behaved in the past.
Probably not a very well worded question...especially for those who like to over-analyze things!
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
L The ARL for an X bar Control Chart (n = 5) Statistical Analysis Tools, Techniques and SPC 5
G I-Chart and X bar Chart Control limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O Main difference between X-bar sigma chart / X-bar range chart Statistical Analysis Tools, Techniques and SPC 4
M What is the difference between X Bar - R Charts and Average Chart? Statistical Analysis Tools, Techniques and SPC 7
S What decision rules should be applied for x bar-R chart? Statistical Analysis Tools, Techniques and SPC 10
I I-MR Chart vs. X-bar & R Chart - Differences Statistical Analysis Tools, Techniques and SPC 8
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
R X Bar R chart - Interpretation in MSA study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Individual x Chart - Why use the equation is barX+2.66 bar(MR) Statistical Analysis Tools, Techniques and SPC 6
S Validity of Craig Hane's Global Local Index for X-bar R Chart Assessment Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q X-bar R chart question from CSSBB - QCI CD Professional Certifications and Degrees 2
A Monitoring Out-of-control situations on X-bar and R chart Statistical Analysis Tools, Techniques and SPC 15
S Creating X bar R Chart using XYZ coordinates Statistical Analysis Tools, Techniques and SPC 4
D X Bar Chart - How can I deal with missing values in subgroups Statistical Analysis Tools, Techniques and SPC 12
D x-BAR, p or U chart? Plastics compounding line Statistical Analysis Tools, Techniques and SPC 1
K X bar & R Chart Result - Analysis of the Graph Statistical Analysis Tools, Techniques and SPC 28
W Warping / Flatness SPC - X bar-R chart - Control is Max 0.15 Statistical Analysis Tools, Techniques and SPC 5
K Formulas for X bar & R Chart with one sample size Statistical Analysis Tools, Techniques and SPC 7
R X bar s chart template / form for Excel .xls Excel .xls Spreadsheet Templates and Tools 2
S X bar R chart - Bushing reaming ID - 7 points above or below the center line Statistical Analysis Tools, Techniques and SPC 9
K Seeking: X bar R chart software - Or how to do one in Excel Statistical Analysis Tools, Techniques and SPC 6
K Control limit - How is table for x-bar & R control chart derived? Statistical Analysis Tools, Techniques and SPC 7
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
1 How to measure straightness on a HEX Long Bar Manufacturing and Related Processes 7
I Can subgroup size change daily? (X-bar & R) Capability, Accuracy and Stability - Processes, Machines, etc. 5
M CE Marking of Robotic Devices which use 5 Bar Pneumatics CE Marking (Conformité Européene) / CB Scheme 3
Jen Kirley How to evaluate hazards in using bar code scanners in chemical manufacturing Occupational Health & Safety Management Standards 1
A Bar Lights vs LED-606 in vision inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J SST .625 dia Cold Rolled 303 bar and Magnetism Manufacturing and Related Processes 6
J Determining if there is Tin Plating on an Aluminum Bar Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Interpreting X bar and R Control Charts Statistical Analysis Tools, Techniques and SPC 2
B New website for AIAO-BAR - Unaccredited Accreditation Body ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 33
smryan Does the NIST certificate that came with my new ball-bar have any value? General Measurement Device and Calibration Topics 8
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
Sam Lazzara Bar Sealer vs. Impulse Sealer for Medical Pouch Heat Sealing Qualification and Validation (including 21 CFR Part 11) 4
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B If I know x-bar, spec limits, and Cpk, can I calculate the control limits? Capability, Accuracy and Stability - Processes, Machines, etc. 16
C 1040 vs. 1040 Modified Bar Stock - Material Question Manufacturing and Related Processes 7
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
J ANOVA vs. X-bar/R Calculations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Writing the symbol for R bar bar (double bar) in Excel Excel .xls Spreadsheet Templates and Tools 3
D For Reference Only or Calibration/Verification - Tape Measures for cutting bar stock ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
S Medical Gas Pressure Regulators - Anybody had testing conducted at 450 bar? ISO 10524 Other ISO and International Standards and European Regulations 5
D Relying on Supplier Records for Material Traceability - Bar stock and forgings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
hogheavenfarm Subjective vs Objective Finish Issues - Stainless Steel Bar Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
M ANOVA / X Bar R Results are different - Why is the difference is so great? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
G S30100 steel bar spec - related specs, ASTM or AMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M CE Product Registration Bar Codes for each Product - Anyone? EU Medical Device Regulations 2
