Xbar - R Control Chart taking into account the Probability Limit
jp519
How do you construct the Xbar - R control charts taking into account the probability limit (alpha = 0.002)?
All help is appreciated.
reynald
Can someone help this new Member?
Thank you very much.
Stijloor.
Well here is my take on this:
for Xbar R, control limits are given as:
Limits = Xbar +/- A2*Rbar
now A2 is actually equal to 3/[d2*sqrt(n)],
where:
-- d2 is a constant that can be taken from SPC tables,
-- n is your subgroup size
-- 3 is the Z from normal distribution set such that alpha level is very small
There is where alpha level comes in. At alpha = 0.002 or (0.001 at each tail), Z is equal to 3.09025.
Factor that into the equation yields:
Limits = Xbar +/- 3.09025*Rbar/[d2*sqrt(n)]
Note: based on discussion from
Statistical quality control By M. Jeya Chandra 8.3.1.1
Regards,
Reynald
hmmm. mathematically correct, but technically a bad answer as SPC is not intended to be some 'exact' probability test, nor is it based on teh Normal distribution...
Reynald answered the OP's exact question, (I think - unless the OP just wanted to know which menu items to select and where to enter the alpha data in minitab...
However, this really begs the question: WHY would the OP want to chagne the limit from the 'standard' time tested and proven limits??
diav615
Like the OP, I would like the answer to this problem.
@ Bev - Is there a way to use Minitab to select the alpha value using the menus?
reynald
I totally agree with this, it's just that I encountered this problem in the academe (as a student) that's why im familiar in the approach. As a pratitioner now though I don't use this because I believe that simplicity is one of the selling points of control charting. :yes:
As for this, go to usual control charting menus:
STAT>>CONTROL CHARTS>VARIABLES>>Xbar-R
Then go to "XBAR-R OPTIONS" button:
A.) On the estimate tab-->Select Rbar
B.) On the S-Limits tab, you will see
"Display control limits at this multiples of standard deviation"--> input 3.09
C.) On the test tab, select 1 point > K standard deviations from center line
-->set K = 3.09
Then hit on "ok", then "ok"
diav615
-->set K = 3.09
Hi Reynald,
This worked! Many thanks for your help! :)
Hi Reynald,
just because you can doesn't mean you should.
WHY do you want to alter the 'alpha' level? are you a student who is being forced to do this (hopefully only so you see how the math works OR how futile doing it really is). I will repeat: anyone who wants to alter the alpha level doesn't understand SPC and certainly isn't using the approach appropriately. They are only fooling themsleves.
R XBar & R Chart Spreadsheet to apply a Control Process Statistical Analysis Tools, Techniques and SPC 1
Z Xbar/R control chart help (possibly a simple question) Using Minitab Software 1
A Variables control chart (XBar & R) template needed Statistical Analysis Tools, Techniques and SPC 2
S Seeking: Control Charts - Xbar R control chart Statistical Analysis Tools, Techniques and SPC 5
D Control limit calculation (Xbar R charts) using Minitab Statistical Analysis Tools, Techniques and SPC 14
A The difference between ANOVA and Xbar-R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
W Xbar R chart LCL and UCL in automotive Statistical Analysis Tools, Techniques and SPC 4
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
K What is the Beta RISK for S chart OF XBAR-S chart Statistical Analysis Tools, Techniques and SPC 0
B How to decide on a sampling size for Xbar-R charts Statistical Analysis Tools, Techniques and SPC 2
S REVERSED Xbar ?R CHART Statistical Analysis Tools, Techniques and SPC 5
I XBar-S A3, B3 and B4 where n>25 Statistical Analysis Tools, Techniques and SPC 4
G GR&R (Gage R&R) Anova versus Xbar Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S My Spread Calcs/Results for Xbar R Charts not Matching Minitab's Statistical Analysis Tools, Techniques and SPC 18
S Should I use Grand Mean or Target Value as the CL for Xbar-R, MA, CUSUM? Statistical Analysis Tools, Techniques and SPC 6
S What should I use for Variable Sample with Size 3, 4, and 5 - xbar-R or xbar-S? Statistical Analysis Tools, Techniques and SPC 4
S Taking samples in a 100 cavity mold for Xbar-R chart Statistical Analysis Tools, Techniques and SPC 1
P Xbar-R Chart - Need help with analysis Statistical Analysis Tools, Techniques and SPC 4
P Xbar-R Chart better than Xbar-S Chart when the subgroup size is small - Why? Capability, Accuracy and Stability - Processes, Machines, etc. 12
R When XBar-R wont work... Imported Legacy Blogs 0
K Why is Cpk = lower of (USL-Xbar)/3sig & (Xbar-LSL)/3sig ? Capability, Accuracy and Stability - Processes, Machines, etc. 20
D Variable sample size - Xbar-s charts - How to select A3 and B4 Statistical Analysis Tools, Techniques and SPC 11
D Xbar?R or Xbar-s Statistical Analysis Tools, Techniques and SPC 5
I Calculation of UCL and LCL for SPC charts (Xbar-s) with sub-group sample of 32 pcs. Statistical Analysis Tools, Techniques and SPC 1
D Normality Test Before the Xbar R Diagram is Made? Statistical Analysis Tools, Techniques and SPC 5
S Gage R&R Methods - ANOVA, AIAG, 6sigma Xbar/R, GM - Which to Use Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Xbar-R chart question - Wire Pull Test - Different Wire Sizes Statistical Analysis Tools, Techniques and SPC 12
A Removing the effect of special causes on Xbar-R chart - Centerless grinding process Statistical Analysis Tools, Techniques and SPC 6
T Gage R&R Excel .xls form and SPC Xbar and R template (lost it.. ) Excel .xls Spreadsheet Templates and Tools 13
L Does anyone use Median Charts instead of Xbar & R charts? Statistical Analysis Tools, Techniques and SPC 3
X Need help / feedback on Xbar/R charts and Cpk/Ppk applicability - Assemblies Capability, Accuracy and Stability - Processes, Machines, etc. 11
Casana Should I use Xbar-R chart? Statistical Analysis Tools, Techniques and SPC 2
C Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ?? Capability, Accuracy and Stability - Processes, Machines, etc. 13
Q IATF / AIAG: Control Plans and CC / SC requirements FMEA and Control Plans 1
Ashland78 IATF Process Control Plans not including customer name Manufacturing and Related Processes 13
M What should be measurement method in control plan if you are defining Control method as work instruction. Manufacturing and Related Processes 5
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
T Document Approver System AS9100 Doc Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Terms & Conditions Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Control of Externally Provided Processes, Products, and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Crimpshrine13 Bulk Process (Electroplating), Control Plan, and Process Change IATF 16949 - Automotive Quality Systems Standard 1
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Introducing a document control system benefits Document Control Systems, Procedures, Forms and Templates 5
N Effective use of a Risk Register - Bumper sticker or Mission Control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
L To control the essential design outputs Medical Device and FDA Regulations and Standards News 4
G Root cause for outsourced pest control service not in approved supplier list ISO 13485:2016 - Medical Device Quality Management Systems 4
A Digital Document Control - Revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 7
V Over 60 dimensions CMM measurement in control plan APQP and PPAP 7
