XBar-S A3, B3 and B4 where n>25
I
Inspector-71
I find myself having to produce control charts in excel to interact with our datalogger. So I need to calculate control limits manually for an X-Bar S charts. Unfortunately, the subgroup size will be 60 (readings every 0.5 secs average over 30 secs for up to 4 hours) and I can’t find any reference for she appropriate Shewhart constants for such a high subgroup size. Everything I can find ends at n=25.
Do they exist or is n=25 considered the maximum?
Bill McNeese
You can use values of C4 to calculate the control chart constants for the Xbar-s control chart as follows:
A3=3/(c4*sqrt(n))
B3 = 1-(3/c4)*sqrt(1-(c4)^2))
B4 = 1+(3/c4)*sqrt(1-(c4)^2))
The values of c4 require the use of gamma function, which is in Excel 2013 but no earlier versions (not sure about Excel 2010). The formula for c4 can be found here:
http://v8doc.sas.com/sashtml/qc/chapc/sect7.htm
The attached workbook has the c4 values up to 100 along with the values of A3, B3 and B4.
That being said, please remember rational subgrouping. You want to subgroup your data so that you explore the variation of interest to you on the Xbar chart and on the R chart. Taking data as it comes may not lead to rational subgrouping.
E
ExcelGuy
Please note that there is an error in the above attached worksheet. B3 is calculated incorrectly.
An If statement is used to return a blank for n values 2,3,4, and 5: The first part of the argument uses the correct equation for B3 when doing the logical check, but the value calculation incorrectly adds to 1 rather than subtracts from 1.
No biggie but it threw me for a loop.
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
K What is the Beta RISK for S chart OF XBAR-S chart Statistical Analysis Tools, Techniques and SPC 0
B How to decide on a sampling size for Xbar-R charts Statistical Analysis Tools, Techniques and SPC 2
S REVERSED Xbar ?R CHART Statistical Analysis Tools, Techniques and SPC 5
R XBar & R Chart Spreadsheet to apply a Control Process Statistical Analysis Tools, Techniques and SPC 1
G GR&R (Gage R&R) Anova versus Xbar Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S My Spread Calcs/Results for Xbar R Charts not Matching Minitab's Statistical Analysis Tools, Techniques and SPC 18
S Should I use Grand Mean or Target Value as the CL for Xbar-R, MA, CUSUM? Statistical Analysis Tools, Techniques and SPC 6
S What should I use for Variable Sample with Size 3, 4, and 5 - xbar-R or xbar-S? Statistical Analysis Tools, Techniques and SPC 4
S Taking samples in a 100 cavity mold for Xbar-R chart Statistical Analysis Tools, Techniques and SPC 1
P Xbar-R Chart - Need help with analysis Statistical Analysis Tools, Techniques and SPC 4
P Xbar-R Chart better than Xbar-S Chart when the subgroup size is small - Why? Capability, Accuracy and Stability - Processes, Machines, etc. 12
J Xbar - R Control Chart taking into account the Probability Limit Using Minitab Software 8
R When XBar-R wont work... Imported Legacy Blogs 0
D Control limit calculation (Xbar R charts) using Minitab Statistical Analysis Tools, Techniques and SPC 14
Z Xbar/R control chart help (possibly a simple question) Using Minitab Software 1
K Why is Cpk = lower of (USL-Xbar)/3sig & (Xbar-LSL)/3sig ? Capability, Accuracy and Stability - Processes, Machines, etc. 20
A Variables control chart (XBar & R) template needed Statistical Analysis Tools, Techniques and SPC 2
D Variable sample size - Xbar-s charts - How to select A3 and B4 Statistical Analysis Tools, Techniques and SPC 11
D Xbar?R or Xbar-s Statistical Analysis Tools, Techniques and SPC 5
I Calculation of UCL and LCL for SPC charts (Xbar-s) with sub-group sample of 32 pcs. Statistical Analysis Tools, Techniques and SPC 1
D Normality Test Before the Xbar R Diagram is Made? Statistical Analysis Tools, Techniques and SPC 5
S Gage R&R Methods - ANOVA, AIAG, 6sigma Xbar/R, GM - Which to Use Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Xbar-R chart question - Wire Pull Test - Different Wire Sizes Statistical Analysis Tools, Techniques and SPC 12
A Removing the effect of special causes on Xbar-R chart - Centerless grinding process Statistical Analysis Tools, Techniques and SPC 6
T Gage R&R Excel .xls form and SPC Xbar and R template (lost it.. ) Excel .xls Spreadsheet Templates and Tools 13
L Does anyone use Median Charts instead of Xbar & R charts? Statistical Analysis Tools, Techniques and SPC 3
S Seeking: Control Charts - Xbar R control chart Statistical Analysis Tools, Techniques and SPC 5
X Need help / feedback on Xbar/R charts and Cpk/Ppk applicability - Assemblies Capability, Accuracy and Stability - Processes, Machines, etc. 11
Casana Should I use Xbar-R chart? Statistical Analysis Tools, Techniques and SPC 2
C Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ?? Capability, Accuracy and Stability - Processes, Machines, etc. 13
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
