Zero Defect Sampling Plan Standards
marcusja2002
I've combed the internet and the cove and can't seem to locate the answer I'm looking for.
I looked through all of ANSI 1.4 and couldnt find a sampling plan for zero defects.
Most of the charts allow for some parts to be found as failures but still accept the lot. The problem is if I just say only accept on zero is the sample size would be larger than necessary.
Is there a standard out there for a zero defect inspection chart?
Thanks in advance.
Mark Meer
Not sure what you mean by "a sampling plan for zero defects". Do you mean that you want to be confident that there are zero defects in a given lot?
The only way to do this is by 100% sampling.
You say that an accept on zero (even with a low-risk verification level?) is still too large a sample size?
How do you expect to arrive at a high degree of confidence that there are "zero defects" without large - or 100% - sampling?
Mike S.
Happy to be Alive
I think you are asking about what is known as C=0 sampling plans. There are threads on here about this. Also look up ASQ H1331 or Nicholas Squeglia's Zero Acceptance Number Sampling Plans.
ScottK
Not out of the crisis
I use Squeglia's "Zero Acceptance Number Sampling Plans - Fifth Edition" you can get it from ASQ
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D The difference between zero defect and zero defection? Statistical Analysis Tools, Techniques and SPC 4
J Zero Defect Dating Coffee Break and Water Cooler Discussions 37
G Stuck with Zero Defect target - Manufacturing Waste Target is Zero Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
D Which Quality Approach - Standards, Six Sigma, zero defect, Continuous improvement Quality Tools, Improvement and Analysis 5
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Certifying a "virtual" company with zero employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Sam Lazzara Time Zero testing in med device aging studies Qualification and Validation (including 21 CFR Part 11) 3
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
WCHorn Changing Sampling Accept Number to Zero, Arbitrarily AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
F Zero to certification in 6 months! Covegratulations 5
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Can Cp and Cpk be zero? Capability, Accuracy and Stability - Processes, Machines, etc. 10
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Rounding Uncertainty to Zero on a Calibration Certificate Measurement Uncertainty (MU) 7
S Justifying the AQL for a Zero (C=0) Acceptance Plan (Medical Device) AQL - Acceptable Quality Level 6
L What is the Cpk for Zero Defects Six Sigma 4
optomist1 Differences and Advantages of using a Zero Positional Tolerance at MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Getting Zero for GR&R Reproducibility? Using Minitab Software 5
V C=0 Zero Acceptance Number Sampling Plan - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Zero Acceptance Sampling Plans 5th edition by Squeglia - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Zero Acceptance Number Sampling Plans for Isolated Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Minitab error: Zero or negative degrees of freedom Using Minitab Software 16
T Zero Failure Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M AQL (Acceptable Quality Level) for Zero Defects AQL - Acceptable Quality Level 13
C Can you change all your WI (Work Instruction) revisions back to zero (0) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Is "Zero Accidents" a realistic goal? Occupational Health & Safety Management Standards 101
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
M Cpk with LSL (Lower Specification Limit) at zero? Statistical Analysis Tools, Techniques and SPC 3
Q Zero-Based Sampling Plan - Governing document or main reference document Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Zero Acceptance Number Sampling Plans, Fifth Edition (e-Book) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Design of Lot Acceptance Sampling Plan - Zero Acceptance Number Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
P Definition S-type Tolerance - Unilateral tolerance where the desired value is 0 (zero) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
C AV equals Zero in Minitab - MSA with 2 Appraisers Using Minitab Software 11
U Zero findings!!!!!!!!!!! First visit back since our registration audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I R-sq Value is Almost Zero - Linearity Study Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D What does Zero Defects mean? TS 16949 Clause 7.1.2 AQL - Acceptable Quality Level 6
Y What is the confidence level for a given AQL in zero sampling plan AQL - Acceptable Quality Level 4
A Is zero defects possible? We are dealing with 25 to 30 parameters Quality Tools, Improvement and Analysis 21
Marc Ford bondholders zero in on cash, not recovery values World News 0
C Sampling plan/method that accepts on ZERO defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Marc Microsoft Excel zero-day vulnerability confirmed Excel .xls Spreadsheet Templates and Tools 2
Wayne Searching for Zero - The Definitive Dimensional Metrology Reference Book, Video, Blog and Web Site Reviews and Recommendations 7
Marc Zero Acceptance Number Sampling Plan - C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
D Zero Acceptance Sampling - Is anyone is actually using this? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Zero Acceptance Sampling Plan By N.L. Squeglia Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Can the Standard Deviation (SD) value be zero? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
