Zero setting of correlation graph when plotting best fit linear regression
whtan02
Hello All,
Good day to all of you.
Can you please advise do we need to set intercept=0 when plotting best fit linear regression line at a scatter correlation graph?
Thank you very much in advance for your time & guidane.
Normally, you should only force the y-intercept to zero when there is a sound theoretical reason for doing so.
For example, take the first principle equation F=ma. If a = 0, then F must also = 0. The equation does not contain a +x (intercept), so you would force the intercept to zero.
If you do not have a theoretical basis for it, do not force a zero intercept.
Note: If you do force a zero intercept, you CANNOT use R^2 to evaluate the goodness of fit. The R^2 will always appear to be good. Some software packages will not provide an R^2 for this reason, but some still do so.
Darius
Hello All,
Piece of cake, you can use Excel (lotus, Works or any kind of worksheet), just remember what does least squares means..
(Y_estimate - Y)^2
being Y_estimate = Slope * X+ intercept
or in your case Y_estimate = Slope * X
Excel has something called Solver (IMHO the greatest tool in Excel), you can obtain the estimate for Slope using the solver, so that the sum of the squares is the minimum value or do it iteractively your self.
If you can give data, we can show it.
whtan02
Can you please explain further what is the reason that "If you do force a zero intercept, you CANNOT use R^2 to evaluate the goodness of fit. The R^2 will always appear to be good."
Thanks again very much.
Read the two links that I put in the last post. They answer those questions.
While I have not found any papers to back this up, my observations of the examples used in papers covering this topic, and my personal experience seems to indicate that for a legitimate regression through the origin, your independent variable must be a ratio variable, not an interval variable. A ratio variable is one where zero has real meaning (e.g., height, weight). An interval variable is one where zero is an arbitrary value (e.g., temperature in degrees C or F).
However, this is not a guarantee. In the fish length example in the paper provided by Darius, length is a ratio variable. However, regression should not be forced through the origin. Why? Because fish cannot start producing eggs until they reach a certain level of maturity, and they do not necessarily produce 1-2 eggs when they do begin laying. Forcing a regression through the origin would imply that they could lay 1 egg as soon as the are hatched.
N Setting AQL (Acceptable Quality Level) on C=Zero inspections AQL - Acceptable Quality Level 16
T Net Zero Miscellaneous Environmental Standards and EMS Related Discussions 7
C Can I reduce P1 to zero? ISO 14971 - Medical Device Risk Management 15
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Certifying a "virtual" company with zero employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Sam Lazzara Time Zero testing in med device aging studies Qualification and Validation (including 21 CFR Part 11) 3
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
WCHorn Changing Sampling Accept Number to Zero, Arbitrarily AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
F Zero to certification in 6 months! Covegratulations 5
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Can Cp and Cpk be zero? Capability, Accuracy and Stability - Processes, Machines, etc. 10
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Rounding Uncertainty to Zero on a Calibration Certificate Measurement Uncertainty (MU) 7
S Justifying the AQL for a Zero (C=0) Acceptance Plan (Medical Device) AQL - Acceptable Quality Level 6
L What is the Cpk for Zero Defects Six Sigma 4
optomist1 Differences and Advantages of using a Zero Positional Tolerance at MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Getting Zero for GR&R Reproducibility? Using Minitab Software 5
V C=0 Zero Acceptance Number Sampling Plan - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Zero Acceptance Sampling Plans 5th edition by Squeglia - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Zero Acceptance Number Sampling Plans for Isolated Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Minitab error: Zero or negative degrees of freedom Using Minitab Software 16
T Zero Failure Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M AQL (Acceptable Quality Level) for Zero Defects AQL - Acceptable Quality Level 13
C Can you change all your WI (Work Instruction) revisions back to zero (0) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Is "Zero Accidents" a realistic goal? Occupational Health & Safety Management Standards 101
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
M Cpk with LSL (Lower Specification Limit) at zero? Statistical Analysis Tools, Techniques and SPC 3
Q Zero-Based Sampling Plan - Governing document or main reference document Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Zero Acceptance Number Sampling Plans, Fifth Edition (e-Book) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Design of Lot Acceptance Sampling Plan - Zero Acceptance Number Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
P Definition S-type Tolerance - Unilateral tolerance where the desired value is 0 (zero) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
C AV equals Zero in Minitab - MSA with 2 Appraisers Using Minitab Software 11
U Zero findings!!!!!!!!!!! First visit back since our registration audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I R-sq Value is Almost Zero - Linearity Study Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D What does Zero Defects mean? TS 16949 Clause 7.1.2 AQL - Acceptable Quality Level 6
Y What is the confidence level for a given AQL in zero sampling plan AQL - Acceptable Quality Level 4
A Is zero defects possible? We are dealing with 25 to 30 parameters Quality Tools, Improvement and Analysis 21
D The difference between zero defect and zero defection? Statistical Analysis Tools, Techniques and SPC 4
J Zero Defect Dating Coffee Break and Water Cooler Discussions 37
G Stuck with Zero Defect target - Manufacturing Waste Target is Zero Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
Marc Ford bondholders zero in on cash, not recovery values World News 0
C Sampling plan/method that accepts on ZERO defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Marc Microsoft Excel zero-day vulnerability confirmed Excel .xls Spreadsheet Templates and Tools 2
Wayne Searching for Zero - The Definitive Dimensional Metrology Reference Book, Video, Blog and Web Site Reviews and Recommendations 7
Marc Zero Acceptance Number Sampling Plan - C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
D Zero Acceptance Sampling - Is anyone is actually using this? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
