Zinc Phosphate Test Panels look bad - Need Help
timber
Help we have a 10 stage zinc phos. system with a pickle stage i can not get good looking test panels all mech. issues have been solved ie drydown, porr cleaning etc the tanks are all in chem spec. temps are good all the known aspects are good nut the panels are still bad crs,and hrs look streaking like drydown or prephos. no idea on it i have even recived the msds on lube used on the parts any ideas,
Wes Bucey
Prophet of Profit
My only suggestion is to call the factory supplying your zinc phosphate chemicals. Supply good quality digital photos of the observed streaking. There is a high probability they have encountered something similar and will have suggestions.
More intensive research can be expensive by involving metallurgists and chemical analysis.
You refer to "test panels" - what is the final product to be coated? Will it be used as is or additionally painted? Is this an appearance item or strictly functional rust preventative on non-cosmetic components?
Is this an in-house process on your own parts or are you a metal finishing vendor providing service to other customers?
diptankd
I had a simular problem. My cleaning tank was in spec but there was a build up of oil from the product in the tank causing streaking. I emptyed the tank and recharged it problem went away. You can try an activator in the rinse tank before it goes into the zinc tank that will help also. Good luck.
diptankd
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
S Engineering Material Specifications - Paint (zinc phosphate) and e-coat Manufacturing and Related Processes 11
D Zinc Phosphate problems - Green Bath has turned White Manufacturing and Related Processes 11
D Operator Training sheet for zinc phosphate/chromate Training - Internal, External, Online and Distance Learning 3
C Does a medical device active (zinc oxide) needs BPR registration in EU? Other ISO and International Standards and European Regulations 1
P Using Zinc Plated Steel in a Cleanroom Other Medical Device Related Standards 3
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
T Corrosion in Bores after Zinc Plating machined Iron Castings in VCI Bags Manufacturing and Related Processes 1
D How do you currently QC fastener coatings (zinc, wax etc.) at your company? Manufacturing and Related Processes 6
M AMS0320 - Electro-deposition of zinc - Anyone come across this spec? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Zinc Oxide as a Topical Application EU Medical Device Regulations 4
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
J Clear Zinc Plating Corrosion issue...Need some education Manufacturing and Related Processes 4
P Testing Zinc Coating on Expanded Metal Manufacturing and Related Processes 7
J Zinc Plating Process NADCAP Certification Guidance please AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
V Interpreting Zinc Plating Specification GMW 3044 - 6K96/48 APQP and PPAP 2
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
V PPAP Requirements including GMW 3179 Zinc Plating Specification Requirements APQP and PPAP 3
M Is Dental Impression Paste (Zinc Oxide and Eugenol) a Drug 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
R ASTM B633 Zinc Plating Specification - Transportation of parts by boat to China Manufacturing and Related Processes 1
J Salt Spray Test on 3 year old Zinc Die Casting Chromed part per ASTM B 117-03 Manufacturing and Related Processes 2
K Resistance welding process - Cold rolled and some zinc plated welding Various Other Specifications, Standards, and related Requirements 2
C Plating Problem - 12L14 steel - Zinc per ES-1030 - Yellow chromate per ES-1100 Various Other Specifications, Standards, and related Requirements 10
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
shimonv Test Method Validation ISO 13485:2016 - Medical Device Quality Management Systems 10
C Test compulsory for Sutures? Manufacturing and Related Processes 6
dgrainger Informational DRAFT: The Medical Devices (Coronavirus Test Device Approvals) (Amendment) Regulations 2021 UK Medical Device Regulations 0
K Identification test in ph.eur. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 6
R Cost per test tool/formula Oil and Gas Industry Standards and Regulations 1
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Burst Test Acceptability Criteria ISO 13485:2016 - Medical Device Quality Management Systems 2
A 60601-1 clause 8.11.3.6 Test Clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
